Forget about the marketing that manufacturers engage in,
I'm looking at a belt sander (craftsman) of some vintage rated at 1/3 hp w/a 6A rating and another I want to guess newer mode rated 2/3 hp w/a 4.3 A rating. As far as I know, AC motor efficiency hasn't progressed much in maybe 50 yrs+ (bearing vs bushing?) so doubt that's where my hp went.
6A*120= 720 W x .9eff ~ 648w / 0.87 hp (thinking older model)
4.3A*120= 516w x.9eff ~ 516 W / 0.69 hp ~ 2/3 (thinking newer "horsepower" model)
The 2/3 manual does say "peak" so running is likely less, so maybe 1/2 hp? The 1/3 hp doesn't make sense for the older one, but looking at full load amps is in the ball park, while running amps is also in the ball park. Why is running amps not closer to the 2/3, 4.3A load? Did manufacturers use to severely underate motor hp (would not make sense looking at load tables right now). Service factor?
www.engineeringtoolbox.com
Electrical Motors - Full Load Amps
Full load amps for single and 3-phase 460 volts, 230 volts and 115 volts electric motors.
