Good call on chasing those threads Mike! But I would expect nothing less.
I had no idea that table lifted that high! I also like the L-track mounted on the side. Definitely a nice tool!
Last night I swapped out the fuel tank skid/cradle and replaced the fuel pump on the Jeep JKU. I discovered another very handy use for the AGA Tools powertrain lift table as it makes this job much less hated, especially when the fuel tank is full.![]()
Mike two things in life that are true 99.99% of the time are smoke detector batteries always die in the middle of the night, and any time a fuel tank needs to removed, it's always full.
Brother I didn’t mean to offend you. I thought it came that way from the manufacturer. So I was a bit baffled by the lack of penetration and burnishing.
**** I did it again…sorry bout that JF 🫢
We all have out strengths and learning curves. Me, I fish but I **** at it soooo![]()
Nice work Mike!Last night I swapped out the fuel tank skid/cradle and replaced the fuel pump on the Jeep JKU. I discovered another very handy use for the AGA Tools powertrain lift table as it makes this job much less hated, especially when the fuel tank if full.
Lift table in position and up against the fuel tank cradle. The fasteners were all broke loose and treated with penetrant for a couple of days now. Kroil on half and Knock-Er-Loose on the other half of the fasteners. I really want to say that the Kroil kicked ***, however, I unfortunately have to report that I saw no distinct difference between the two penetrants. My 3/8" impact with extension wouldn't even touch them, so I grabbed my good ole' trusty IR Titanium 1/2" with a 18mm wobbly and removed all of the fasteners. A couple came right out without hesitation, but the majority of them still were slow to come out. At this point I think all I can say is that in this scenario, some form of penetrant was better than no penetrant at all. One thing I did notice however, was that the Kroil seemed to wick its way up the threads just a couple more threads than the Knock-Er-Loose penetrant.
Fuel tank lowered and rolled out from under the Jeep.
At this point I realized I missed my opportunity. My son had just stopped by the shop after work to visit and he had just left when I lowered the fuel tank. I instantly realized my folly. I should have asked him to wait a few minutes so he could help me lift the fuel tank out of the old cradle and reinsert it into the new one. The tank was heavy and awkward and every time I lifted one end the other just slid around and neither end was coming out of the cradle.
After screwing with it for about 15-minutes I came up with a better solution. I parked it perpendicular to the Jeep right under the rear bumper. I raised the table up to within about 2' of the rear bumper and slid a couple of prybars under the poly tank and dropped a tie-down between the tank and cradle then fished it out with a magnet.
Then with it slung from either end of the tank, I lowered the table and cradle away from the tank. Even then it stuck occasionally and had to be assisted to drop away. Mainly due to a few dents in the cradle and the fact that it was packed with mud and debris which locked the two together.
With the tank out of the cradle, I cleaned off the underside of the poly tank. I didn't want to reassemble it into the new cradle with the possibility of a pebble or rock between the tank and the cradle which would wear a hole in it. I brushed the bottom of the tank off, then grabbed a wet towel and cleaned the bottom thoroughly before raising the new cradle up to capture the tank.
With the tank now married back with the cradle, it was time to tackle the fuel pump. I removed the lock ring and removed the old fuel pump.
Compared the new pump to the old.
Client supplied both a new O-ring and lock ring which was nice as these generally need replacing.
Once the mounting surface of the tank was cleaned, the new O-ring was treated with some Sil-Glyde prior to installation.
New O-ring in place.
More pictures to follow....
Nice work Mike!
I've only got to use Kroil a few times (it's not available here, but I managed to get hold of an almost empty can, after learning about this absolutely magical product from you). I have to say that I have NEVER come across anything near as good. I pester the Kroil people on a regular basis. So I hope that they will cave in and get a European distributor.
Any reason why you opted for the Napa silglyde over your usual AGS?
I only recently tossed one of my empty tubes of NAPA/AGS Sil-Glyde in the garbage can and I have to be honest, that was a hard thing to do. That tube was well marred and soiled, and we had a history. I had been squeezing the "last" of it for what seems like a year but finally couldn't get any more out of it, so I had to throw it away. I think I have one more tube of the NAPA labeled stuff before I go into the new tube from AGS. Well that has been a few days worth of relaxing and catching up on this thread!
As always. Love the detail and the progress photos of your vacations, jeepin adventures, and of course the different shop projects that come in.
Are you doing a gear change on the rear axle @zmotorsports ?
That is a neat bearing race punch/tool you got yourself there Mike.Finally back on the Jeep JKU again. I've been waiting for my 10 pound slide hammer that I had to order to be able to remove this axle shaft. Tuesday evening with the nice weather here along the Wasatch Front, I opted to trim some trees in the back yard as some of the neighbor's limbs have really grown over the fence and were hanging quite low over the past summer. I talked to him last weekend and made sure he was ok with me trimming them so a couple of nights ago I went at them to trim them a bit. My son loaned me his electric pole saw and it was a real time saver. Made it to where I didn't even need to get the ladder out, which made the wife happy.
When I arrived home from work yesterday the UPS driver still hadn't been by with my package but finally later in the evening my slide hammer arrived. After unboxing it, the size difference between the old Snap-on 3 pounder and generic one I have used over the years was incredible.
I have NEVER fought an axle shaft in all my years like I have this one. Usually I flip the rotor around, start a couple lug nuts and use the weight of the rotor to knock the axle out. It worked on the driver's side, but with a lot more force than normal. Nothing I had would touch the passenger's side however. My son even came out one evening to give me a hand and after about 20-minutes of his time we still couldn't budge it and I didn't want to start prying at the hub end and damage a reluctor ring, so I ordered this 10 pound slide hammer.
The shaft is massive.
Compared to my 3 lb. Snap-on slide hammer.
With only 4 smacks, the axle gave in. Granted, they were pretty good smacks, but nothing I tried over the weekend would even move it.
With the axle out of the housing, I removed the rusted brake backing plate and then removed the outer races from the housing.
With the housing tube empty of old parts, time to turn to the carrier for removal. OTC case spreader installed and case spread slightly.
Carrier out.
Then the yoke was removed as well as the pinion.
All of the parts out and on the bench.
In only about an hour I had the axle stripped down, parts on the bench and ready to start cleaning and prepping for assembly.
Thanks for looking.
Thom, most of what I used to do was called "Feeding" so maybe a lot like "Phishing." Even then I never got a Grouper''s password.They call it "Fishing" and not "Catching" for good reason......
What's the tool you used for popping those races out?
A sheer joy to enjoy your content (work) as always.
I've seen one of the other version of that tool that you describe, Mike. Hadn't seen the one that you used.
Ever used a really hot circular MIG bead to shrink a race like that? If you could tilt the housing it will fall out after that. That was how I was taught to remove hard seats from cylinder heads (about 125A- 150A with a TIG), and it works just as easy on bearing races.
Hot, burning gear oil is a definite downside!
Fellow on another forum with a very stuck race had never heard of that technique, and he was farm born and bred. Several other, experienced posters hadn't heard of it either. Made me wonder if it wasn't as well known as I thought it was.
Mike, I bought all kinds of penetrants over the years and most seemed to work OK. On October 26, 2012 I got an offer I couldn't refuse: Two cans of Kroil for $12.00 direct from Kano Laboratories in Nashville, TN. I feel really bad for how little I've used but when I need it, it always works. I haven't bought another brand since. I'm tooI have used Kroil my entire Industrial Maintenance Career as that is what the shop was using when I began back in 1988.
The smell of gear oil is bad enough, let alone the smell of burning gear oil stinking up my shop.![]()
Mike, I bought all kinds of penetrants over the years and most seemed to work OK. On October 26, 2012 I got an offer I couldn't refuse: Two cans of Kroil for $12.00 direct from Kano Laboratories in Nashville, TN. I feel really bad for how little I've used but when I need it, it always works. I haven't bought another brand since. I'm toocheapfrugal to throw out the full cans of the other stuff. One Kroil can resides in the garage.
It's direct center in the cabinet so I can grab it with either cabinet door open. You may notice there are a number of products in that cabinet that are 100% your fault and I thank you for that.
The second can of Kroil resides in a cabinet in the shed/workshop. It's in the middleish position in the row for no good reason.
The other penetrants are somewhat buried a row or two back on my shelf and nothing else has ever made it to my tool cart so I don't know why I keep messing with anything else.
Mike, a selection of BFSHs (Big ******** Slide Hammers) is as important as a selection of impact wrenches. When the 1/4", 3/8" and 1/2" Milwaukee M12 battery tools fail to do the job, out comes the air line and my Harbor Freight 1/2" Earthquake. That beast treats everything my stuff is bolted together with like it's on finger tight. Only drawback is weight.With only 4 smacks, the axle gave in. Granted, they were pretty good smacks, but nothing I tried over the weekend would even move it.
There is nothing that smells worse, at least that my nose has experienced. I always say it smells worst that Russian Wolf P*ssy!.![]()
The pungent smell of gear oil met us at the door, and it wasn't even the nasty burnt smelling gear oil, it was just normal somewhat used gear oil.
Matco's Part number was SP7 or SP205 (no longer made)What's the tool you used for popping those races out?
Siberian Snow Leopard is way worse...There is nothing that smells worse, at least that my nose has experienced. I always say it smells worst that Russian Wolf P*ssy!.![]()
