Last night I swapped out the fuel tank skid/cradle and replaced the fuel pump on the Jeep JKU. I discovered another very handy use for the AGA Tools powertrain lift table as it makes this job much less hated, especially when the fuel tank if full.
Lift table in position and up against the fuel tank cradle. The fasteners were all broke loose and treated with penetrant for a couple of days now. Kroil on half and Knock-Er-Loose on the other half of the fasteners. I really want to say that the Kroil kicked ***, however, I unfortunately have to report that I saw no distinct difference between the two penetrants. My 3/8" impact with extension wouldn't even touch them, so I grabbed my good ole' trusty IR Titanium 1/2" with a 18mm wobbly and removed all of the fasteners. A couple came right out without hesitation, but the majority of them still were slow to come out. At this point I think all I can say is that in this scenario, some form of penetrant was better than no penetrant at all. One thing I did notice however, was that the Kroil seemed to wick its way up the threads just a couple more threads than the Knock-Er-Loose penetrant.
Fuel tank lowered and rolled out from under the Jeep.
At this point I realized I missed my opportunity. My son had just stopped by the shop after work to visit and he had just left when I lowered the fuel tank. I instantly realized my folly. I should have asked him to wait a few minutes so he could help me lift the fuel tank out of the old cradle and reinsert it into the new one. The tank was heavy and awkward and every time I lifted one end the other just slid around and neither end was coming out of the cradle.
After screwing with it for about 15-minutes I came up with a better solution. I parked it perpendicular to the Jeep right under the rear bumper. I raised the table up to within about 2' of the rear bumper and slid a couple of prybars under the poly tank and dropped a tie-down between the tank and cradle then fished it out with a magnet.
Then with it slung from either end of the tank, I lowered the table and cradle away from the tank. Even then it stuck occasionally and had to be assisted to drop away. Mainly due to a few dents in the cradle and the fact that it was packed with mud and debris which locked the two together.
With the tank out of the cradle, I cleaned off the underside of the poly tank. I didn't want to reassemble it into the new cradle with the possibility of a pebble or rock between the tank and the cradle which would wear a hole in it. I brushed the bottom of the tank off, then grabbed a wet towel and cleaned the bottom thoroughly before raising the new cradle up to capture the tank.
With the tank now married back with the cradle, it was time to tackle the fuel pump. I removed the lock ring and removed the old fuel pump.
Compared the new pump to the old.
Client supplied both a new O-ring and lock ring which was nice as these generally need replacing.
Once the mounting surface of the tank was cleaned, the new O-ring was treated with some Sil-Glyde prior to installation.
New O-ring in place.
More pictures to follow....
