Ideas and direction for grow box wiring
toddt429
I am making a grow box to start early spring crops in. It will also double as a honey de-crystalizer.
It has 3 shelves. Each shelf will have 2 pair of lights. I'd like each shelf to be able to be turned on and off independently without multiple circuits.
I could simply put a power strip on the back of the cabinet and plug and unplug as needed, but I'd like to avoid that. It's, to me a little hack.
How could I plug the unit into a 20amp receptacle and then be able to turn each shelf on and off independently? Is there a switch type device I could use? If not, could I please get some ideas on how you would do this?
Thank You, folks.
Todd
no704
I’ve seen power strips with switches on each plug.
wyliesdiesels
Modesto, CA
a lighting contactor feeding a receptacle in each row, with a timer or wall switch controlling the coil in the contactor.
T
toddt429
I'm probably going to go with the power strip options for now as It is a bit time sensitive. Gotta get my seedlings started. Thank you for showing me the lighting contactor. I will definitely be using this in the future. I'll be saving your response as a reference on how to build the next 1. Thanks!
knobby
down by the river under a Jeep
Thank You, folks.
Todd
The most important question would be what are the two lights that you want controlled.
If they are low amperage the wireless controllers from post #2 would do it fine.
If they draw more than say 4 amps per pair post #8 would be the safe and reliable solution.
T
toddt429
I will check, but they are leds so I'm sure very low amperage. The heat mats and heat bulbs will all be on another 20 amp outlet.
hobie18
Seedlings now? Location?
I just pulled the canna lilies.
Not that I have any idea what to do with them...
T
toddt429
7b virginia. Brussel sprouts, carrot and onions. Anything that can handle down to low 20s in 8 weeks. I'll have row covers ready to go if needed. I always back up and start more a few weeks later encase of a catastrophic loss. I'm a market grower and like to try to have some produce by April markets.
hobie18
Thank you!
Different planet. We are lucky to be able to do garden clean-up this late. Should be frozen and covered until maybe mother's day.
T
toddt429
Thank you!
I moved 2 states south to get away from North East winter nonsense lol.
JCU
South East MN
AC infinity has a receptacle that can be controlled automatically. They released a new WiFi controller; the old ones are almost free when you buy an exhaust fan (inc temp/hum probe); and automation. I would add a fan to control air exchange and control temp and humidity. Links below.
Fan
Outlet
T
toddt429
Fan
Outlet
Thank You. A fan is included in my build. I will certainly check out that product. The one I'm building is sort of a prototype (2x4). If it goes well, I'll be making this on a much larger scale (like walk in type). Thanks for your valuable input on this.
  • Like
Reactions: JCU
