Mr.zippy
Wyoming
But I don't have a 357, just the 38. Some of them are lead, some are FMJ, a few are those really old wad cutters that only stick out of the case about 1/8 inch. Then there are also some boxes of 45 and I think some 9mm mixed in there, the photo is just one of the boxes I was given.
In that case I can't say I blame you. Tear em apart!
PassnThru
Bowling Green KY
I dropped a screw. I was working on a laptop but that's not the point of what I was doing in my garage - finding the screw I dropped was the challenging part. I'm not the best at math - I know about gravity and I know about mass but I can't really do any calculations on the distance one would expect something with a given mass would travel when dropped. It's a moot point though - we all know that dropped fasteners always defy the laws of physics. I finally found this a little over four feet away from where it was dropped. Not thrown, no springs were involved, just dropped straight down. Actually it should have landed in the chair I was sitting in basically between my legs so I really don't know what happened. It wasn't in the chair - it wasn't on my pants - I searched before I stood up.
Energetic little fellow.
Wiz02
Southeastern PA
I know the feeling all too well and the older I get, the more often I drop things. How much time did you spend on your hands and knees searching? At least you found it.
XJSuperman
Central Iowa
I stood in there for a couple minutes this morning waiting for the truck to warm up outside. I measured to see what would fit in certain orientations yesterday and this morning. Maybe I'll try and get the yota inside when I get home today before the freezing rain hits later...
Guess I can update this: The yota is inside warming up.
DGersic
DeKalb, IL
Yesterday, we did a thorough cleaning of our house after discovering bed bugs, which really scared us. We’ve been spraying every corner of the home for the past three days. Unfortunately, we had to throw out our favorite bed—which I absolutely loved—because we were convinced the bugs were nesting in it. Literally this week was tough but now it's Friday! Happy Friday :)
Old Man Roger
Palm Coast Florida
If you were working on a car I could have told you exactly where that screw went. I’ve done the math, it’s a place I like to call true magnetic north. It’s directly in the center of the car, on top of some heat shield, that you can’t get to without disassembling at least 25% of the car.
And incase you’re wondering, this theory of mine has been tested repeatedly, the results were consistent within an infinitesimal amount.
:lol_hitti
kaymccampbell
Upstate New York
Worked late again - got to stop doing that - 77 days to retirement! - So not much time for garage - I brough the cans in from the street - PU Day - and power washed 2 of them, then used a fan to get them dry enough for use.
I hope you have a calendar, a task list, a plan, and the will to execute it. Without them, you'll wind up in front of the tube, dead within 6 months.
Thats not happening to me for sure, I have so many million projects, plans, writing, and the like, re-organizations, and things I want to do more - camping-fishing-hunting, etc... I may even start going to the races again.
A friend and I had this convo last Sunday. he said he's not worried about that happening to me at all. But I know exactly what you mean though, I've also seen guys that died within a year after they retired from "their life"... the go from being a key player, - even in their own mind, and suddenly they don't even run their own home.
I almost never watch TV unless it's a movie, - preferably with no commercials.
phred
NC
Stripped 4 layers of paint and primer off the inside of the doors for the 66 f100. This new environmentally friendly stripper *****. It took 2 heavy applications, scrappers and wire wheels to get the paint off. The old aircraft stripper would have eaten that off and left the metal pristine.
Jay__Dub
Cold Country, Canada
Honestly, in about 6 months, you will seriously wonder how you ever had time to work. At least that has been my experience, retired from a high stress, need it done yesterday place 8 years ago, after 42 years. I have never looked back. Plus, you can sit back down and have that 2nd cup of coffee. Good luck.
Jay__Dub
:lol_hitti
CoogarXR
I keep a little baggie of those microscopic laptop/watch screws in my toolbox "just in case":
CoogarXR
Finally finished up the Jetta suspension. Here's the carnage:
Two blown struts, one busted spring, both balljoints studs broke off, so I had to replace them too. Oh, and like I said in another post, I knocked the outer CV joint off the end of the axle, and decided to just replace it. It's back on the road, but there's still a clunk on the passenger side, which according to forums, is common and tough to find/fix. This sound was what I was trying to fix in the first place. I assumed the strut was causing it. It wasn't. Now it rides nicer, but it still clunks. So... yay?
rd65
Granite Falls, WA
Walked into the shop, grabbed screw gun and screws. Returned for a square piece of plywood. returned for a different bit for screw gun. Returned for a longer piece of plywood. Returned tool and screws. Repair should keep dogs in the yard while they are here, and hopefully keep coyotes out. This one arm work is a pita.
welder4956
Birmingham, AL USA
:lol_hitti
I respectfully disagree. The math would confirm that a black hole exists for each screw ever manufactured, as well as 10 mm sockets.
My theory is that the black holes exist everywhere in a dormant state, until they sense that sinking gasp as you just KNOW that screw or socket is gone, then it instantly comes out of dormancy, and ***** it in..
stonesfan68
Houston, TX
I started to change out the front control arms on the C70. I also changed an engine mount. It isn't a bad job, but it sure would have been easier on a lift.
The old adage that a simple job is one broken bolt away from a disaster is applicable here.
I followed the work instructions and broke the darn axle bolt! I should have done more research and questioned why Volvo wanted me to torque a 10mm bolt to 90 foot-pounds! Well, now I have to remove the drive axle and either attempt to remove the broken bolt or just order a new axle. The problem is that the axles are no longer produced and so I have to buy a ChiCom part that is hit or miss. The alternative is to go to a salvage yard and get a used one and put new boots on it.
I'm worn out and my muscles ache. It wasn't too long ago that I could have done this work with no side effects.
SMOKEYBEAR
Didn't get to it yesterday like I had planned, but wrapped up the jointer knives today with some test pieces. It cuts cleaner than it ever has, and its significantly quieter while cutting. The old knives were very worn, they cut on a bevel no matter how many times I checked the fence to table surfaces with the square. Here is the old machine..I'm happy with the results. I'm working on a chute extension to get the chips off the cart. It's designed so my floor jacks can be rolled under it for storage when neither are in use. My shop is fairly small, 18x30, but my bass boat owns the majority of the space. I work outside on the apron.
SMOKEYBEAR
Busy day - Carter's Mag fence, "F.A.S.T." and Jet miter gauge arrived today. Sorted it all out with some testing. The JET band saw plus the items from Carter significantly exceed my skill. Tried the new fence and miter with some scrap, zero complaints. Cleaned the table up after the testing and pictures.
The band saw and jointer projects are a result of the butcher block table I'm working on. The new to me band saw caused some shuffling of the shop, I knew it would when I made the purchase ...I have ran out of room.
Kent_B
MI
I finally wrapped up the rear brake job on my daughter's car. She blew a LR brake caliper so it got rotors, pads and a reman. caliper. Had a helluva time getting all the air out of it. She & I wound up doing a total brake flush. The good part was spending quality shop time with my favorite daughter. I'm afraid she isn't going to like the parts bill. No labor or shop materials, of course.
Dixie_Flatline
Tennessee
The band saw and jointer projects are a result of the butcher block table I'm working on. The new to me band saw caused some shuffling of the shop, i knew it would when I made the purchase ...I have ran out of room.
I need to get one of those for my band saw! Bought it used, came with no fence, and I kind of rigged something up in the meantime. Its an older Craftsman saw, but I like it and don't do enough wood work to justify something better.
