Some thoughts on benders based on my years of experience bending and rolling tube and pipe, take it for what it is. Free advice is worth what you paid for it.
The common types of benders you'll see are just plain hydraulic ram type benders and rotary draw benders. Roller benders are also used pretty commonly, but they're not really benders in the same sense of the word as they can create a somewhat infinitely variable radius bend or rolled section instead of an elbow shaped bend.
Like any machine, what you end up selecting will be influenced by what you intend to do with the bender. You have been extremely vague about the intended usage and that will cause a lot of people to recommend things that may or may not work for you. Just saying "heavy wall" doesn't really matter. What matters is the desired bend radius, the material and the quality of the bend desired. Budget and the space the machine takes up are factors, but there are workarounds.
Remember, tubing runs true to the named OD and you spec the wall thickness or ID as the second dimension. Pipe is a SYSTEM, designed to work with fittings, hangers, threading equipment, insulation, and tons of other pre-made products. It has an OD and ID that adheres to the IPS sizing standards for a given size and schedule. A 1" sch. 40 pipe will have an ID of approximately 1 inch, but it's a NOMINAL value and will vary a bit. The OD is held to a pretty tight tolerance, but that is so it will fit threading dies and fittings, but it won't be anywhere close to 1". In general, pipes are designed to convey some sort of material, whether it's liquid, air, chemicals or wiring and tubes are intended to build structures with. This is obviously not 100% always the case, as you can obviously build things out of pipe and use tubes to move materials, but in general, this is a good rule to follow.
Pipe schedules are a ratio of wall thickness to diameter, and as the schedule increases, the wall thickness increases. Schedule 40 is the standard, meaning the closest to nominal, but what this means is that a 1" sch. 80 pipe will have nothing on it anywhere that measures 1". Tubing has no schedule, and is simply measured by the OD and either the wall thickness or the ID, whichever is specified. It is entirely possible to have tubing with wall thicknesses heavier than a similar sized OD pipe, so if you care a lot about wall thickness for strength, don't think you're stuck with only pipe, as it's almost certain you can get a tube with better mechanical specs.
So the cheap hydraulic ram jack benders are designed to bend PIPE, not tube. You will struggle to get a nice, round bend on tube because it will not fit the dies, either too small or too big. Typically, you will only use these to make non-geometrically critical bends in pipe systems where a fitting isn't appropriate. Think a bend at a ridge of a roof or a sweep around a corner for an air line or conduit. The bend radius isn't critical, all it needs to do is not collapse or kink the pipe. If your designs can tolerate the fixed radius from the die and is made from pipe, a ram bender probably will work fine. They are simple tools, and have a pretty small window of what they can do well, but what they do they do pretty good. You might only be able to get up to a 90° bend on one, however, and you'll be limited on how close you can put bends to other bends and stuff like that. The benders are cheap and relatively compact, but they're also pretty limited on what they can do.
The other really common type of tubing bend is a rotary draw bender. This kind of bender is capable of doing a whole heck of a lot more than a cheap ram bender, as the tooling is much more varied. You can buy a die set for most common types of tube OR pipe, round AND square. You can also get different die radii and sweep lengths, so you can bend up to a 180° bend in the material. Also, depending on your bender, you can do a lot more intricate bending, like offsets and various rotation changes close to each other. The most common manual bender like this is the JD² model 3, but Hossfeld, Swag, and numerous others make a similar bender. In manual applications, the die remains stationary and the operator pulls the tube around the die. In hydraulic or CNC benders, the die rotates and the tube is drawn in around it, but the principle of how the bender works is the same. The die supports the wall from collapsing, and a set of shoes guides and bends the tube around the die. The primary downside to the rotary draw bender is their cost. The bender itself is pretty cheap, usually only a few hundred bucks, but the dies are several hundred each, and if you want to bend much variety, you'll end up with a few grand in dies pretty quick. The manual versions also require a large amount of floor space, as the tube needs to sweep through the bend. The hydraulic versions eliminate this problem, as the die does the moving and the tube stays straight, but at a significant increase in price.
Both versions of common benders will bend heavy wall tubing or pipe, it all comes down to how strong you are on the manual stuff. They use compound leverage to make the bend, and you can generate huge forces with that. I've not ever had a problem bending heavy wall DOM tubes up to 2" on my JD² model 3. A Hossfeld style bender would really struggle with that, as its just direct force, no compounding lever.
So TL;DR, if you want a cheap bender, are bending pipe, and you don't care about radius get a hydraulic ram bender. If you're bending tubing the radius is important or need more intricate bends, get a rotary draw bender.
