Chas Parker 974 , how old?
7.3444
Hey guys, The house we were working at today hired somebody to clean out a garage and I saw this vise and offered him $50. After some conversation he took my offer so hopefully I got a decent deal. Being that somebody painted it I'm sure that lowers the value some. Is there any way to tell how old this vise is? Searched online and couldn't find any definitive answers. Also there is a little bit of slop Where's the main screw bolts up to the moving jaw ( sorry can't remember correct terminology), I read that there is a way to fix this but nobody online said how to actually do it.
7.3444
For clarification, the slop on the main screw is not in and out, it's more up and down so wasn't sure if that is normal.
justintendo
pennsylvania
you did well the jaws look intact.. i only have one parker so im learning about them a bit, but they are well made. give it a nice bath in paint stripper and pressure wash
7.3444
Already started taking a wire wheel to it, it's coming out pretty nice. The front hold down screw is really stuck so I sprayed it with penetrent and no luck. I then took one of those old manual impact tools , The kind you hit with a hammer, to try and get it loose and it started breaking the screw so I guess I am s o l on that one. It's this screw here in the picture.
Lots of penetrating oil and patience should come before the impact driver. Anything that old and irreplaceable should be handled to Do No Harm first, not race to the finish. If you can’t turn it with a well fitted screwdriver, step back, and investigate your stash of penetrating oils.
7.3444
Anybody know what I can use for a dowel pin for the jaws? Previous owner put in a nail 🤦17348767417654589218859252892634.jpg
Josh Dekubber
Bothell Washington, Peoria Arizona
That's nice!! Really wish the previous owner didn't paint mine.
The paint can easily be removed with a wire wheel. I agree the Parker is such a work of art that it doesn't need paint. I was going to paint my 974 1/2 but changed my mind. Also just picked up a Reed 204 R that I am going to paint. Here are my newest 2 Screenshot_20241212_041529_Photos.jpg
7.3444
Very nice! I have been searching for a reed as well just haven't found the right deal yet. Vises in my area are at a premium price so it's had to find a good deal. The Parker is a nice solid vice, it's quite a bit larger than my Morgan Chicago 140. 17348815838822763816733079123573.jpg
Josh Dekubber
Nice Morgan!!
I just picked up that Reed 204 R from New York $120+shipping= about $150. Ship to Washington State. I go back and forth between Washington and Arizona. I'd like to get a bigger version of either of my two newest but I'm really liking the Parker more than I thought I would. So I'm thinking Parker 976 would be nice! I found one in Arizona but it's a bit rough.
7.3444
Finally got all the old paint off , everything lubed up and a nice coat of linseed oil. I have to say I'm a little disappointed in the pitting on the cast compared to my Morgan Chicago. Maybe the paint on the Morgan is covering up the pitting. All in all the Parker is a really nice heavy duty vise.17348965304155990668351319202540.jpg17348965667011233255443261304092.jpg17348965985974196464999011390820.jpg
Josh Dekubber
I think it looks fantastic!! Those parkers have become my favorite
Packard V8
Spokane, WA
OP mentioned the free play around the screw in the movable jaw. Somewhere in the distant past of this forum, I shared how I fitted a bushing and tightened up the front plate of my Parker. It's worth the effort and makes for a more precise feel when operating.
jack vines
7.3444
jack vines
Thank you Jack, unfortunately I'm going to have to leave it be. I tried getting the screw out several times with penetrant and then tried a manual impact with the correct size flathead bit and it started to separate the head of the screw where the flathead notch is. I didn't feel that I was being overly forceful but apparently I was. I stopped as soon as I saw part of the screw head moving so it is fine but still a bummer. Do you happen to know what people use for dowel pins to keep the jaws in place? The previous owner must have had one fall out and he used a small nail but I wanted to fix it correctly.
Someone just posted elsewhere that's it's just a std tapered pin.
Jayman17
Seattle, Wa
I have one too and it has roll pins holding the jaws in, not a tapered pin. I just punched them down from the the top side, came right out.
7.3444
Where do you guys at these pins? Does a hardware store usually carry them?
Jayman17
Seattle, Wa
I plan to re-use mine, they weren't damaged when I removed them. Probably available at hardware stores with a good bulk fastener section.
1982fxr
Phoenix
Is there anyway to date these?
When did it change from 974 to 974 1/2, or vice versa, for instance?
Banjorear
Essex Co., NJ
I think heat, penetrating oil and time is going to be on your side. Heat it, spray some oil, let it cool. Spray more oil. Repeat the process for a few days. Before trying to remove it again, heat it prior to giving it a whack. Heat does wonders for stuck parts.
