More valve grinders
WisJim
Menomonie, WI
After reading all the discussion about valve grinders in the garage sale and Lugzonia threads, I thought I'd post a pic of 2 of mine here, rather than add to either of those threads. These are both usable as combination valve grinder/breast drills-- Blanchard, on the left (US Patent: 963,986) and Mifco (Browne,US Patent: 1,017,242).
The Mifco paint job is the way I got the tool.
nadogail
Coronado, CA
IMHO, the above pictured items are drills. They drive the chuck in one continuous direction.
Valve lapping or grinding is an intermittent, constantly alternating motion.
Snip's
Nice... Interesting mechanism.... Pin on the crank handle (Blanchard unit), Switch contact with upper and lower pinion gears to change chuck direction.... Bet that would be fun to operate...
W
WisJim
Menomonie, WI
Please look closely at these two tools, and look at the patent info, to see how they switch between a straight rotary drilling motion and a regularly reversing oscillating action.
john.k
Brisbane Qld Australia
With these wind up grinders , soft cast iron blocks and valves ,guys would sink the valves by 1/4" without trying ....and the car wouldnt climb hills in first gear.....Ford generally had hard steel valve seats ,and they took a lot more grinding.
I remembered you posting them before, @WisJim, and I considered mentioning breast drills, in general, in our little study, but ended up taking a narrower, less than exhaustive and evolutionary approach. No service was more frequent than valve grinding/lapping in the early days except maybe carbon scraping, and breast drills - let alone the reversible combination models, are actually mentioned in all kinds of early automobile mags aimed at home hobbyists and private garages, including early issues of The Fordowner. And it's easy to see them being the inspiration for the lighter dedicated grinders that emerged, including from Goodell-Pratt, who, of course, made both. To be fair, it has to be said that it's also easy to see why they didn't last long for the service, though, too. They were heavy, and if there's anything that made valves worse than no lapping at all it was lapping done without a light touch. They were long, too. Access to the fourth cylinder was one of the main reasons why the early valve lappers had no crank at all, just a compact knob and a swing arm.
Very cool to see hanging in an extensive collection such as yours, of course! :thumbup:
john.k
De .cokeing a car was a regular chore pre about 1965 .........if you didnt de coke,your car would knock like crazy on hills and have no power .....and of course the famous Ford run on after you switched off the ignition.
