Wilston vise breakdown
Sumboodie
AK
There a good place to find info?
I got this small bench the other day with a Wiltson vise that needs tore open and cleaned up, greased, bearings?
No idea what version it is or age.
Sumboodie
AK
I found a Google thing with a breakdown.
No bearings which is crazy.
The jaw tightening is metal on metal.
The horseshoe is chewed into so not sure why.
wrenchr
should be a washer, very thin between the spindle and vise body. Keep it lubed up.
Sumboodie
AK
I'll take a look when I get home at the end of the month.
Depending how it cleans up I may use it inside and put a shittier one I have outside.
paulsomlo
Northern Colorado
Nope, Wilton didn't see fit to put a bearing in there - either the hub bears on the horseshoe, or you shim in the pocket behind the horseshoe and shift the bearing surface to the inner part of the hub and the dynamic jaw's bore. I put a bronze washer in there for bearing and to take up the backlash. Some advocate for a needle thrust bearing, but on mine, there wasn't enough depth for the bearing and two hardened thrust washers.
KMScott
I’ve repaired several Wilton spindle’s that also involves machining the Dynamic counterbore. Once the pocket is machined then either a Bronze bushing recommend or recutting the Horseshoe washer groove after welding it up can fix the backlash issue. I like .015 clearance in the washer to the groove. A few pics that might explain what I’m writing about.
paulsomlo
Northern Colorado
Is that a CNC mill, or are you somehow rotating the dynamic jaw?
KMScott
My old CNC in my machine shop in Estes Park. I have moved and have a small shop in SC where I would have to do this repair on my Bridgeport. Having a big lathe would work also work.
