Mat for a work bench??
ChefRex
Years ago, 25? I got some mats from one of the guys from the shop that he got from an acquaintance that worked in a print shop, they can only use them so long and then go into the bin.
I have no idea what they are called or if still used but they work excellent, still using them in the garage and at work, if you have a print shop close it wouldn't hurt to ask.
Mr_B
Reading
attached is couple samples of horse rubber stall mat finish.
The light textured is nice for toolbox tops or benchtop, they do a smooth one which I like more for benchtops.
One large piece does a 72" toolbox.
You could make quite a few custom size small working pads from a clearance/seconds or offcut piece .
Used in a wagon as a rear loading area mat and ribbed etc good for that .
Is pretty easy way get various thickness (5/16 to 3/4 range) of heavy duty rubber mat at fairly low cost .
AEAdam
SE PA
Doesn’t like heat, but I’m gonna be using some drafting table cover
As a drafter, I always loved that stuff. It was self healing. So we could stick pins in it etc. I recall it being super expensive, but I'd guess it's very high quality for a work table.
In my first job as a real engineer, my drafting table had a few nasty cigarette burns in it. They had just stopped smoking in my building. It felt like 1967. One weird shared computer, we each had desk phones, the clothes my coworkers wore - looked like those pictures from NASA in 1969. Short sleeved shirts, thin dark ties. The haircuts - everything. Booze in the drawers, girly calendars. That was 1991 and old fashioned then. The drafters cuffed their long sleeves inside, which. never understood. Wore their belts sideways so the buckle didn't marr whatever part of the drawing was hanging over in the front.
Took us 30 years to get back to standing desks.
isb cornbinder
I still have my HAMILTON drafting table. It has the wide drawer for blueprints and a Hamilton small 3 drawer cabinet that is bolted to the frame. Years ago, I upgraded to a VEMCO and retired the cable drive. I have a Franz Kuhlman drafting machine. It is about 60 years old.
My daughter and I have used the Hamilton for leather upholstery layout
seber
Deep East Tx.
That would be offset printing mats. If I could find a source, my shop would be full of them.
J
johninct
I am looking to get a small mat for my metal work bench to protect things I am working on from getting scratched and sliding around like a carb. I need to get a mat that if I spilled something on it ( within reason) that it wasn't going to dissolve or fall apart. Any ideas?
Just an update. I went away for my Birthday and saw rubber mats at different bars, so I ordered this mat and so far, so good.
Banjorear
Essex Co., NJ
For more than 25 years I've been using a slice off a horse stall mat from Tractor Supply that has been indestructible.
I installed a 3'X4' Tractor Supply stable mat on my bench. Very happy with it considering it was reasonable at $37.00. Very substantial and heavy. Should last a long time.
mituzuna
I use interlocking PVC flooring tiles. They work great since they're designed for garage floors. You can configure/cut them in any shape you want. Oils and most solvents won't affect them and they are easy to clean and very tough. I'd highly recommend you get smooth with a very light texture:
Can you take more pics of these mats on your desk?
