RickP330
Hey Gang,
I am a born again mechanic planning on starting an automotive project in a year or so while I finish up grad school. So I am going through my tool box taking inventory and re-stocking where necessary. I pulled out my old 4" grinder and become a little sad at all the abuse I put it through in the past 30 years. I had been accused of being stingy and should just buy a new one, but I have a tool list a mile long already - Plus this was one of the first real tools I bought myself back in the day. Of particular frustration was that I lent it to my best friend during that time and it came back with a taped up cord. Oh yea, just nicked it on you. Every time I put it away I cursed him for it LOL. also the detent in the switch lever broke very early on. Item 17 below. Probably very common.
Okay, so I bought a new SJ cord for the grinder and tried to find the switch lever but it is obsolete. I did find one parts warehouse that claimed to have it in stock but it backordered after I ordered it and I presume I'll never see it.
So the cord is relatively easy. To get the switch lever out requires total disassembly as it must have been the first thing installed. Pressing the stator out of the housing was the most difficult part. I thought I could do it with just a brass drift from the back end but I damaged a few of the laminations on the back of the stator in doing so, so I stopped. I made a cross bar and pressed it out properly. That Stator is really pressed in there.
So since I cannot seem to find the switch lever, I embarked on trying to restore it. The "detent" pad was worn flat. I put two small holes in it with a pin vise and carburetor jetting kit. Then I used a high performance epoxy (Loktite 9304) to build it up. I'll file it to size and cross my fingers. I mean it does work but you have to hold it in the on position. It would be nice if I didn't have to any more. Epoxy is drying now - 24hours.
Also I'll clean the years of grinding dust out of it and there is not much left to the brushes. I'll change those.
A question to the group. I did have to open the right angle gear case to take it apart. The old grease is solid as a rock and it's obviously running dry. I could use a synthetic wheel bearing grease. What should I put in there and how much?
I'll update on the completed project as I move forward. Please comments and suggestions welcome.
Am I nuts for wanting to restore an old faithful tool?
Rick
Rick
