Above 1200 Sq/FT Swanny's Garage Expansion Project
zmotorsports
Northern Utah
Same thing happened to me Gary. I found a broken upper control arm bushing housing a couple of years ago on the Jeep. Killed a trip.
At least you found it in the shop and not out on the road, or worst, off-road like I did. 🤬
Swanny1953
Lucas, TX
I'm glad I found it when I did. I have no idea how long it's been like this - I'm sure I have put a few miles on it driving it this way. Last trip was to a car show down near my kids - 60 mile round trip on the freeway!!
Bob Heine
Boca Raton, Florida
Gary, I used to pull the wheels a lot more often. Might be time to put that chore back on my list, along with inspecting the rear drum brakes on the 22YO PT Cruiser now that it has 51,000 miles on it.
Xti04
Swanny, just finished reading thru here and you have an amazing setup! Beautiful bunch of cars in there as well. Love the pressure washer setup as well!
Mark
Swanny1953
Lucas, TX
Mark
Mark, thanks for taking the time to read through! Now that the setup is pretty well dialed in, it's time to start ticking off the projects that have accumulated for all the "toys"! I'll try to document here, but I find myself not very disciplined in the picture taking department while working on stuff!
Bob, it probably wouldn't be a bad idea for me to get underneath everything every few months to check for untoward items. This is the second time in the last year pulling wheels has yielded an "oops!" (the tire surprise on the ZR1)!
HogDude
Nebraska
Today I pulled the rear wheels off the Cameo for polishing. As I was walking by, something didn’t seem quite right -
Yes, the end link for the upper four bar disintegrated! Don’t know that I would have seen this had I not taken the wheels off! I found replacements on eBay and they should be here late next week.
Just another day in the old car hobby!!
I cut my teeth in a truck fleet doing PMs. Preventative maintenance. The whole idea was that while doing the proper level of service, intentionally look at everything. Amazing how much we found. Besides, the "over haul" bay did the really cool work. We wanted as much of those smaller jobs as we could find. You know the "kissed a lot of frogs"? Yeah, changed a lot of oil for a water pump, brake reline and the likes.
Swanny, well done young man.
Swanny1953
Lucas, TX
HogDude, thanks. Your comment, along with Bob's above, has spurred me to think about adding something else to my routine. I have a whiteboard which details the last time driven for each of the "toys" so I have a reminder of which I need to get out and exercise. I think I'll add a date for last inspection just to incent me to put everything on the service lift at least once a year and have a good look see. Most of them I don't drive far enough in a year to justify annual oil change, so this will be a good reminder.
Swanny1953
Lucas, TX
The saga with the rear 4-link in the Cameo continues. I removed the broken link ("dog bone" in Corvette terms!), but needed to remove the broken bushing from its mount. The shock absorber is in the way to easily accomplish this, so I decided to remove it. It would not easily come off, so I resorted to some "encouragement". Once off, I was able to pretty easily remove the damaged bushing.
HOWEVER, what I didn't realize at the time was that the transverse leaf spring at the back of the axle carrier was forcing rotation of the entire assembly, and the reason the shock wouldn't easily come off was that it had bottomed out from the force of the spring. When I encouraged the shock to come off, the assembly further rotated, putting the disc brake caliper at the top of the rotor. I had intended to remount the wheel so I could move the bridge jack out of the way for another project, but there wasn't enough clearance for the wheel to go back on the truck. I ended up using a scissor jack I have to apply enough upward force on the transverse leaf spring to rotate the assembly back to some semblance of normal, then cut a piece of 1/4" bar stock to wedge between the upper and lower shock mount to keep the assembly in place until I can replace the dog bone (coming later this week) and reinstall the shock.
The jacking process:
Bar stock in place:
This allowed me to remount the wheel and move on to the next project. I won’t be driving anywhere like this!!
It looks like I did drive this some with the damaged dog bone, as there is some minor scoring on the driveshaft where the lower dog bone mount contacted it during suspension compression.
Blackbyrd
TN
I have a large dry erase board that's got mods/shopping lists on it for mine for each car. I've also started keeping short lists for maintenance. Been toying with the idea of getting 1 of those small paper sized dry erase boards on magnets for each car. I keep one for my firebird as it helps keep it all straight since it doesn't see as much road time. That keeps it all at the toolbox and in front of me I find it helps now that i have more than 2 and I don't get to drive around as much as I'd like either.
Swanny1953
Lucas, TX
The other Cameo project is chasing down a small fuel leak. It's coming from the top of the tank, and drips to the ground from the back.
I thought I could remove the 4 bolts holding the tank to the frame and drop it down, but first have to get the exhaust out of the way. The exhaust system on this one is fully welded from the headers back. Step 1 was to support the exhaust tips while removing the hangers from the frame.
Because everything is welded, and the system passes over the transmission crossmember, just removing the hangers gave me next to no additional clearance. So, I used tie downs to force the exhaust to basically ground level. This would give me enough clearance. No pics of this redneck move!
After doing all this, I rolled around on my stool under the truck to determine the best way to drop the tank. I had my transmission jack at the ready, then discovered the lines and fittings at the front of the tank for fuel delivery come out over the top of the frame rail, which prohibits dropping the tank straight down. There's no real estate up there to "easily" remove the lines due to its proximity to the third member and I'd be doing everything blind. Furthermore, the tank is long enough and tall enough that I cannot drop the back of it and bring it out at an angle. Long story short, it looks like the only way to access the top of the tank is to remove the bed in its entirety! So, the exhaust is back in place, and this project is on hold until I can complete the suspension repair. Good news, it appears there are only 6 bolts connecting the bed to the frame, plus removing the bumper. Bad news, I cannot do this one myself as I'll need 3 others to help lift the box off, and probably one more as a spotter to get it back in place after the repair is completed. I should be able to rustle up the manpower, but like I said, this effort will wait until after the suspension repairs are completed.
Swanny1953
Lucas, TX
Can you not use your lift to pull the bed?
My lift isn't a 2 post, and there's limited clearance with the 4-post. I also have a mobile gantry crane - something to think about. I'd be a little worried about the fiberglass quarter panels on the bed. Again, something to think about.
HogDude
Nebraska
Swanny, man do I like the way you roll. I had an idea 10+ years ago for an Electronic Whiteboard. Basically a spreadsheet for just such instances. Columns, Tabs, Notes, Dates, Mileage etc. Maybe an old computer hooked up to a tv or monitor in the garage. One thing that came to mind from this situation of yours is tires. Maybe add a cell for the date stamped on the tires. Last time inspected etc. They can get dry rotted but usually shows signs.
LXCam
Gary, I've been there a few times so I unbolt the bed, pull the truck back under the lift and use the lift to raise the bed. Is that an option for you?.
Swanny1953
Lucas, TX
HogDude - I have a spreadsheet with all the specs for each vehicle, including the DOT code for all the tires. While a lot of the sets are over 10 years old, they all get regular exercise to prevent flat spotting and I try to pay attention to them regularly.
Cam - certainly something to investigate as it would probably be easier lifting from 4 points on the bedsides with the 4-post rather than fighting the inevitable balance concerns that would come with using a single lift point with the gantry crane. Thanks for the suggestions.
SilverJimmy
Prescott/Flagstaff, AZ
Do it way the Pros lift one…
Lift it safely and damage free!
Bob Heine
Boca Raton, Florida
Gary, be very careful. Just removing the scratch might lead to replacing the six universal joints in the drivetrain. Wiping off the grime can turn into a lot of time and Mothers polish. The unnamed idiot who was just going to wipe the shafts and brace clean may have gotten carried away. It's a disease that I suspect has no cure. A lot of places provide treatment, including Griot's, Mothers, Jay Leno and Chemical Guys but none of them offer a cure.
Axle Universals 11.jpg Driveshaft Universals 15.jpg Driveshaft Universals 19.jpg
Swanny1953
Lucas, TX
Bob - I'm not quite that AR!!! I have a Corvette buddy who is, though - he polished the after axle part of his C5 SS exhaust system!
I will do some cleaning up when putting everything back together as the suspension is a "drop out" and wasn't cleaned very thoroughly prior to install.
Swanny1953
Lucas, TX
Mike - that was definitely a surprise to me. I didn't think it was that hard a lick as the Vette tracked straight right after the impact. But I guess hitting even a smaller deer at 75 MPH, something has to give. The bodywork certainly did, but the upper A arm being severed like that indicates more force than I thought I experienced in the moment!!
Swanny1953
Lucas, TX
Well, our time at Barrett-Jackson has come to a close. We arrived on site Wednesday a little after 2 PM local time. I had gone through the Wednesday docket, and there were a couple of cars that I was interested in. The first one was already in the staging lanes, so my buddy and I got a chance to get a good look at it - a really solid build. I ended up being the high bidder, so within about an hour of arriving at the auction, I had another car to add to the collection.
It's a 1934 Ford Cabriolet, original Ford body (steel), with LS1/4L60E. Although it's an older build, it has the required modern amenities - A/C, Bluetooth stereo, power windows. It's a steel body with suicide doors and a rumble seat. There’s surprisingly (at least to me) a lot of legroom in this thing. I got a chance to meet the owner by chance on Thursday and he gave me some good G2 about the operation of the car.
Now, for Reliable to get it to Texas . . . . . . . .
Swanny1953
Lucas, TX
I did bid on a 2nd car, a nicely done '41 Willys coupe. It was also on the list of cars I would like to have. It was only slightly later on the docket. When it came up, I did bid on it, but dropped out just before the winning bid. Who knows much higher it would have gone had I stayed in!
There were a number of other cars that I put into "My Garage" in the Barrett-Jackson app, but all of them ended up going for much more than I was willing to bid, including a Chevy II Nova that went for $700,000. Granted it was a very nice build, but that's just stupid money and the owner/builder had to be dancing all the way to the bank!!!
It was sure fun to watch Rick Hendrick by matching C3 restomods, a '63 Split window ($990k with premium) and a '67 convertible ($935k), both done by Jeff Hayes customs. Then he topped it off by buying VIN 001 of the 2025 Corvette ZR1 for $3.7 million. The arena was pretty electric!
If you've never been to a Barrett-Jackson auction, particularly Scottsdale, I highly recommend it. In my buddy's words, it is he Super Bowl of car auctions! You don't have to bid to have fun, and there is lots to see besides the incredible automotive art they attract every year.
Blackbyrd
TN
It's on my car bucket list! Knocked out SEMA in 2019, but Barret Jackson is something I wanna experience for sure!
Congrats on the new addition!
Xti04
Congrats on the 34. Theres a 36 3 window Ford coupe in my parents garage that my dad is never going to restore. Its got potential to be something cool but he isnt gonna mess with it. I guess it will be up to me to get something done with it.
Swanny1953
Lucas, TX
Thanks. SEMA is also on my list. I have a car builder buddy working on a Camaro for SEMA and says he has a ticket for me this year. We’ll see.
Congrats on the 34. Theres a 36 3 window Ford coupe in my parents garage that my dad is never going to restore. It’s got potential to be something cool but he isnt gonna mess with it. I guess it will be up to me to get something done with it.
Thanks. Looks like you have something to look forward to!!
TX4runner
Houston, TX
Congrats on the new additions. Looks great A/C and Bluetooth are great touches for Texas. I can on today just to see if anything was going to be following you home 😁
Blackbyrd
TN
@Swanny1953 dont make the mistake I did trying to squeeze it all in, in 3 days. It made normal big carshows not as fun for a while haha, but you won't regret doing it that's for sure.
Swanny1953
Lucas, TX
Congrats on the new car in your stable Gary.
Gary, I really like your '34. Congratulations on your purchase, and thanks for sharing.
Mike in WI
Thanks, guys. Our PHX trip is getting cut short as Lori picked up something at BJ and we're headed back to DFW this evening. Can't wait for Reliable to get the car to DFW!
Swanny1953
Lucas, TX
She picked up a car of her own or furniture/memorabilia?
By "picked up" I meant some sickness. Woke up Sunday with a hack and runny nose. We were supposed to stay with her cousins through Thursday, but he has some pretty significant pulmonary/respiratory issues and was "scared shitless" having her in the house. Rather than move into a hotel for 3 days, we changed our reservations and flew home last night. It *****, because we were really looking forward to our time with them.
Swanny1953
Lucas, TX
Gary, I went to the Florida Barrett Jackson in April a decade or two ago. Really glad I didn't have a bidder's number because there were some stupid good deals I would have happily gone into debt for. Also went to a Kissimmee, FL Mecum to see one of Mark's (@IGO2XS) masterpieces.
Bob - I think there were some decent deals to be had earlier in the week. I'm kinda upset with myself for not going at least one more bid on the Willys, as I think that was a pretty good deal at the hammer price. By later Friday and all day Saturday, the things I was interested in sped right past my comfort zone!!
