Proto and Tekton Socket Comparison
Dankotaru
7000' ASL
The rear axle on my motorcycle (S1000RR) is retained with a 34mm nut, which is a size understandably not included in the 200-some piece Craftsman socket set I bought way back in 1999 and still makes up most of my current socket assortment. As a guy with a pretty active Zoro account for work, I simply ordered a 1/2" drive Proto socket and have been happily using it for every chain adjustment, sprocket swap, tire change, etc... for the past 2.5 years.
I do about 10-12 track days a year with this bike, and I take a collection of critical tools with me to the track for adjustments and the occasional emergency repair. Unfortunately, the world has despicable scumbag thieves who take advantage of unattended tools in the parking lot while the owner is out on track dragging knee, and as such, the tools I take with me to the track are cheap and not a huge issue to replace should they be stolen. The most expensive tool I bring with me is actually the Proto 34mm socket.
So for the upcoming season I decided to get a cheaper option to throw in with my track toolset, and it's also nice to have redundancy. I found an inexpensive Tekton socket on Amazon, and figured since this is Garage Journal, I'm probably not the only one who would be interested in comparing the two sockets.
First thing I noticed is that the Tekton is smaller and lighter than the Proto. I didn't bother to weigh them, but the extra heft of the Proto socket is fairly substantial when you hold them. The base of the Proto is wider, the socket is taller, and it's just a bit thicker than the Tekton.
The chrome on both is nice, with no real difference between them. The broaching depth is also about the same between them, and both feature radiused corners with the now common 'flank-drive' type internal flats. The Tekton socket has a shiny clear coat applied to the interior that the Proto lacks.
The drive inserts on both sockets have beveled edges and clean, even ball detents cut into them for retention. The Tekton has radius cuts on the drive square, the Proto does not. You can see the extra heft in this end of the Proto.
I'm really impressed with the Tekton socket. I know a lot of people on this forum have recommended them, and this is my first example. While I am not about to torture test them, I'm sure both will easily handle whatever I need from them, and the Tekton is a great price with a great warranty. I've been thinking about replacing some of my old 1/4 drive G1 Craftsman sockets, and while I've been happy with all my Proto purchases (even had a nice experience replacing a busted 1/4 drive extension) I'm also impressed with Tekton sockets, especially for the price.
Fedwrench
Valley of the sun
One thing to consider if replacing American made 1/4 drive sockets with Tekton, Tekton's 1/4 drive shallow sockets are taller Tekton uses an overall length of one inch whereas, most American made 1/4 drive shallow sockets are 7/8 of an inch long.
D
Dankotaru
7000' ASL
Hey, thanks for the insight, that's good to know. I'm also considering Koken sockets, since so many folks rave about them.
I like all the Proto stuff I've picked up over the years, and if I were to replace all my old Craftsman 1/2" drive sockets it would be with Proto sockets, no question. They're a nice upgrade from my old G1 C-man, and just plain beefy.
But my 1/4" stuff doesn't need to be beefy. Which got me thinking about just getting the Tekton. I like that they go up to 15mm, and the warranty on them is reportedly really easy should I bust one. But my biggest goal for replacing my old Craftsman 1/4 sockets is to get something with better fit and possibly lower profile for better access. So knowing the Tekton 1/4 drive sockets are a bit deeper than standard is good info. I might order a 10mm Koken Zeal socket just to check them out.
^ Yes.
But.... to get around that.... the "Power Torque" GM4234 9-piece metric "low profile" metric socket set sells for $15.99 at O'Reilly's.
File date on the photo is Sep 30 2023, so my buddy has had these for just over a year and hasn't complained about them yet.
Tekton makes a decent socket. Just not as short as the Proto.
swsman
Earthbound
Look into Astro Nano 1/4" set, low profile compared to Tekton and your current sockets. No skips there as well.
I also own a lot of US made Craftsman sockets in 1/4 and 3/8, they still get used frequently.
In addition I picked up Astro Nano 3/8 Metric set, and a Quinn 1/2 Metric set which is a copy of Astro itself.
No need to upgrade my 1/4 drive sockets for now.
^ I suggested the El Cheepo "Power Torque" because the OP said he only wanted to take cheap tools to the track. Less money = less grief when they're stolen.
I bought those for a buddy of mine after somebody mentioned them here (probably in the "Show us your new tools" thread) - he was in a bind on some deal where he couldn't get AT the fastener because of clearance issues.
swsman
Earthbound
I missed that. Astros are reasonably priced, nothing outrageous. I imagine if they steal anything OP is hosed, likely the whole tool set will be gone.
mikey03
i was doing some research on Tekton sockets on their site and found something I don’t like
i am thinking of replacing my deep chrome 3/8 sockets for my mobile kit with impacts
so i wanted to see the size difference. The impacts are a little bigger which is to be expected but I found something disappointing. idk the technical terms but it looks like to save money they share the same socket blank across a few sizes.
15 mm chrome is 0.82 inches diameter
16 mm chrome is 0.86 inches
15 mm impact is 0.94
16 mm impact is 0.94
same for other sizes
18 chrome is 0.96
19 chrome is 1
21 chrome is 1.1
but for impacts
18 19 21 are all 1.1
so i hate to say they are cheaping out because it’s a value brand but it looks like there impacts are sharing some base blank or whatever it’s called across a range of sizes. Which means the 18 mm socket that got 1.1 diameter is going to be much thicker wall compared to the 18 mm chrome of 0.96
but at the higher end of the socket blank like 21 then both chrome and impact are 1.1 no size difference
so I’m a small bit disappointed tbh but it’s not the end of the world
mikey03
Overthinking. I wouldn't worry too much about that.
I’m using them on a vim magrail that’s already capped out on space with the chromes so if I switch to impacts for this mobile box then I will need to drop a few sizes to make them fit
nicks78camaro
Pittsburgh, PA
Magrail for mobile tool kit? I'd think that would stick to everything. I'd buy the Tekton that come on a twist lock rail. Done deal.
Fedwrench
Valley of the sun
18 chrome is 0.96
19 chrome is 1
21 chrome is 1.1
but for impacts
You would be better off replacing chrome deep 3/8 drive with 3/8 drive semi deep impact sockets like these:
dnschmidt
Phoenix, AZ
I HATE PROTO. Well, actually not really but they were the starter drug of my tool addiction. The local auto parts store in my neighborhood in Pittsburgh (Bloomfield) had Proto tool boards covering the walls of the place. I never was big on candy but I sure took a liking to tools and those bastards got all of my allowance money which, I guess, was a good thing as I was too broke to get into drugs. Dope never had the appeal of a Proto ratchet to me. My father was an example of bad parenting as he really liked Proto tools as well and did nothing to discourage me. Other than this one little thing pop was a great guy and taught me everything so I can't complain about him too much.
mikey03
Yea for inside a small metal toolbox. Also even with the twist lock rail they got a specific length so wider sockets means I can fit less on them
Kscardsfan
The Little Apple
That's one of the best ones I've seen on here in a very, very long time now.
NHtoolguy
Gilford, NH
I spent most of my youth north of Pittsburgh and remember that Cranberry Auto Parts stocked Proto too, as well as Bonney. I spent a fair amount of my meager funds there.
