Running wire to an outside welding area?
mpire
Florida
If I have 220 in the garage and I wanted to run a wire into the ground to a covered concrete pad about 25 feet away, would this be dangerous? I was going to stick a water tight box to the corner post. Its a small covered concrete parking pad big enough for one car, 4 wooden posts, and a metal roof. No walls. I figure its a good place to practice welding if there isn't much to catch on fire.
Should I just use an extension cord?
Tell me why this is a bad idea.
Buckgnarly
VT
Bad idea if you want to weld with gas. Stick or Flux core good, but any wind will make gas welding tough.
Chuckster in NJ
Hunterdon County NJ
For the amount of welding that I do I just use an extension cord and roll it up when I am done…….. I am sure you can do better on the price if you go to your local electrical supply house.
mpire
Florida
I know very little, a friend is teaching me when he has time. I am getting dramatically better with a grinder, that's for sure. However, if I don't practice I'm not going to learn.
The extension cord is looking like the way to go.
cvairwerks
Within hearing distance of Texas Motor Speedway
Stick welding out there isn't going to be much of a problem, as long as there is little to no wind. Trying to do MiG or TiG with any wind at all is going to be an exercise in absolute frustration. If either of the last two, you would be better off buying a couple of portable welding curtains and working just inside the main garage door,
alfredeneuman
Fullerton, CA
Bert_
NW Iowa
You almost certainly don't need #6.
10-3 cord will run many (most) welders. A #8 will run pretty much anything that uses a 50A plug.
I regularly run my 200A inverter welder on a 50' #12 cord. Just no reason to drag a big heavy cord around.
sparky 1971
Central Iowa
You can one of these for less than you can make an extension cord for or you can buy two of them for less than what it would take to bury the wire, and a helluva lot less work.
Joemctag
Outside raleigh nc
I was going to make one, but bought a 40’ online cheaper. Went with 6 ga., but it’s heavy and 8 ga, would have been fine. I’m running a 120/240V stick welder ( inverter).
Standard 6-50 plugs .
MovingAlong
1) Not dangerous if you follow code.
2) I'd just use an extension cord.
3) Because you live in Florida. Outdoors is hot/sticky/wet, mosquitoes, open walls means no arc flash shielding for others eyes, materials will probably be stored elsewhere, welding table probably elsewhere, rods/hood/jacket/gloves stored elsewhere... Lot's more pieces to welding than just the welder, you get the idea.
You are correct about wanting a space that is safe though. Ignore the reasons listed in #3 above, drag the tools out there and get to work! :thumbup:
larry4406
Northern Virginia
I make a few cords a year for guys. Generally this is how I make them. Usually get a cover just to make it look pretty. This is my cord for my welder, 50' #12 SO cord
Bert - that looks very nice.
What is the proper term for the fitting that secures the cable to the metal box? I need to redo my welding cord end and like this.
Bert_
NW Iowa
Honestly couldn't tell you the official name. I always just ask for an O-Z Gedney iron cord grip.
The range in size of cord they accept is pretty small. So you need to know the diameter of the cord you are using.
I usually use a bell box for the receptacle. There are better ways but the bell box and flush receptacle are reasonable cost and fairly durable.
larry4406
Northern Virginia
Strain relief cord connector seems to be the best description after some googling of your suggestion. Appears the orange store near me carries them.
manwithtools
Lebanon, TN
@larry4406 Another term widely used for them is Cord Grip Body or simply Cord Grip, also called Cable Glands or Strain Relief, naming is very regional and trade specialty dependent. For instance, an industrial electrician is far more apt to use these than a commercial or residential electrician and will be familiar with their use and application.
I've become more likely to use this nylon body style; they typically accommodate a wider range of cord sizes for a given part number:
Nylon Cord Grip
Bert_
NW Iowa
Nylon Cord Grip
I thought everybody knew what a cord grip was. I assumed Larry wanted to know about the metal one in my picture?
Don't use plastic cord grips for something like this. They will get broken. Maybe a plastic Woodhead might hold up but then your halfway to a good iron one that will last forever.
sparky 1971
Central Iowa
I get these at the local supply house and keep a couple of each on my truck. It takes the guessing out of what size rubber grommet is needed.
3/4 hub
1/2 hub
Bert_
NW Iowa
3/4 hub
1/2 hub
Those look decent. Local electric supply here carries AFC. I'll have to see about getting some.
Joemctag
Outside raleigh nc
if it has a 6-50p how are you running it on 120v 6-50p is wired to L1,L2, ground, no neutral, 240V with the cord. The welder can be taken to jobs with 120. It comes with an adapter.
Also, these welders typically sense whether you plug them into 240 or 120, so no need to flip any switch on the machine.
theoldwizard1
SE MI
I make a few cords a year for guys. Generally this is how I make them. Usually get a cover just to make it look pretty. This is my cord for my welder, 50' #12 SO cord.
You can use SJOOW if you are under 300V. Insulation is not as thick.
Crazyjake8493
Upstate NY
When I started welding I made a 25ft extension cord with 10/4 SOOW and 6-50 ends. Still have it but once I started welding outside more (and got sick of running the extension cord under the garage door) I added a dedicated 6-50R on the exterior wall of the garage by the driveway. I still use the extension cord to get farther from the garage, or for wheeling the TIG welder around inside the garage.
