Need to cut 2 3/4" radiator hose
johninct
I need to cut 2 3/4" radiator hose and want a nice clean cut. What tool should I use?
Copymutt
Colorado
I’d grab a cut off blade in the angle grinder after establishing a true circumference line.
pbon
If you could put a sleeve of some kind inside and cut that as well, that could help, and a ring or at least tape around the outside as a cut guard or line. I have not yet succeeded in what the OP is attempting….
NUTTSGT
Northern Central Ohio
We had a saw similar to a RAS but the arm would swing rather than slide. Those were the old saws and later they added some Dewalt miter saws both with a single edge smooth blade. Both saws used water to keep the rubber from building on the blade.
I probably cut close to a million pieces of radiator hoses in my day.
unslow1
Illinois
If you put something in it to hold it stiff I bet a wheel style cutting tool would work. I know the ones I have for cutting conduit are larger than that. Think a brake line cutter but much bigger. More like a pipe cutter.
NHtoolguy
Gilford, NH
I have often used a worm-drive clamp as a cutting guide for a utility knife. You do have to loosen and reposition the clamp once to clear the worm screw housing. It isn't hard to align the clamp to the partial first cut to complete it.
Wamsutta
Amarillo, Texas
What you do is get one of those utility knives with the fully extendable snap off blade.
Extend the blade all the way out and GREASE both sides of the blade. Clear silicone grease is perfect if you have it.
