Gurru
ThanksLarger surface area and clearance for holding parts vertically on the left side of the vise. Wilton corner vises are popular with some woodworkers because of this.
Nice vise! I had one in the past.Just picked up this unused Record 3VS swivel vise off Marketplace for $40. Came in the (very weathered) original box. It wasn't stored properly, so there's some rust on the bare metal that needs to be cleaned off. Excited to clean this bad boy up and put it to use!
I saw another thread on here about that after I bought it! Says Made in England on the box. Can't find a date anywhere on the box.Nice vise! I had one in the past.
Could you please check the box and see if it says where the vise was made? Also, does it mention the company “Irwin” anywhere on the box? Years ago the these vises were labeled as “made in England “ on the casting. Then Irwin purchased Record. I believe sometime later the “made in England” was changed to “Sheffield, England” and at some point manufacturing was sent to Asia. Thanks
That is great data! ThanksI saw another thread on here about that after I bought it! Says Made in England on the box. Can't find a date anywhere on the box.
always thought these had a cool look.Just picked up this unused Record 3VS swivel vise off Marketplace for $40. Came in the (very weathered) original box. It wasn't stored properly, so there's some rust on the bare metal that needs to be cleaned off. Excited to clean this bad boy up and put it to use!
This is the Jan 1932 version of the Improved parallelyes - the instantaneous grip of this type was invented and patented by J Parkinson of Shipley, Bradford, UK in 1884 - called 'Perfect' - I think their patent would have lasted 17 years back then - around 1900 a raft of other makers such as Woden and Record started producing near copies -- the one in this catalogue looks very much like a Parkinsons Perfect from around 1920+ but they didn't make sizes below 3.5 in and the numbering shown was generally used for non-QR Handy vises
Show your vintage lathe? Find it in the sticky I imagine.Any idea where I should post it, anyone interested here ?
For your review & reference.
Cool find!
Post in thread 'Show off your vintage lathe.'
https://www.garagejournal.com/forum/threads/show-off-your-vintage-lathe.438304/post-1087514
Rabbit holesThankyou, I had seen that ,but had just seen the more modern lathes and, looked at the end, not the start of the thread - being slack or more to the point I was pretty much over researching by that point.
Yes, it all started with vices and ended up with me buying a lathe to help with my vice restores.Rabbit holesrapidly become mazes.. check any OCD tendencies at the door to the libraries whether in person, or online.
Oh the woes of hunting info & documents for cool stuff, amongst other cool stuff…
I worked on the Parker #4 again today...
I finished the screw retaining plate...
I need to get a more appropriate bolt.
I also found a piece of 'mystery metal' rod and made a replacement jaw pin for the missing one. I tapped it in place, filed the end to match the jaw angle, then used a ball peen hammer to mushroom the end...
It turned out ok...
Now I need to machine a new handle... if anyone can give me handle dimensions, I would appreciate it... I would like to make it as close to the original as possible.
-Bear
Needed a bit of ”love”.
They are really cool. Completely distinguishable.A friend of mine asked me to help her with this Craftsman vise that was her dad’s. Where do I look to find numbers to Identify and figure out the date for this vise? Also, would this have been Red or another color? Thanks for any help!
Thanks, it does have a 4" jaw and I found the numbersLook on the very nose of the main screw, for the model No, and fully closed, on top of the slide sticking put for the date.
Very desirable vise, likely a 4" wide jaw. if so a 5191, if its 3-1/2" its a 5190
So do the numbers translate April 8 1957. The number looks to 4857, is readable with a little water on it.Thanks, it does have a 4" jaw and I found the numbers
I may be mentioned in the catalogs - I need to me on my pers comp to try to look that up.Further to the late 20's early 30's vice, I got given another today, has the same squarish handle I wasn't sure was original-I am now as both the same and missing the grooved cut like the later models ( grooved cut - 1930 ish to 1969) Todays example is really good for it's history, but that is about it, the static jaw ledge is broken and ledge removed to form a , let's say 'cast in jaw 'Yeah have that page, although, I'm murky with that era think that page is later than 1930's
This is a 1932 MacPhersons ( No Dawns apart from a woodworking in 1933 McPhersons )
This catalogue threw me again, as every other thing I have points to that vice being 1920's
1920's vices - very uncommon - Dawn on the dynamic, maybe a 2000's ish with that also, but that's it all the rest have Dawn on the static.
Got a few ready to patina this week
This is a late 20's,early 30's - the front ears on the static were discontinued around the start of 1930's, no Dawn on Dynamic but doe's have the early dots b/w letters and front ears kinda a in-between model with the size on the static as well. Also note the rear edge on the dynamic and has the non-rounded handle.
Paid $998.99 AUD, 3 hours ago (including $69 freight)
I saw this in your group post. It looks like my "Cole like" junior vise, but with ears. (Edit Oops, mine has ears too) Couple of different flavors out there, search for Cole on this thread for possible ideas
I may have one similar also. I'll have to search my photos - What are the basic dimensions?Anyone recognize it?
Love that red paint! Looks to be an unbranded G ******* Kit vise
