nadogail
Coronado, CA
Went to the steelyard and bought some steel. The milk crate has a home on the back of my scooter. The metal work is done and painting remains to be done.
I estimate that I can haul 100 pounds and still remain within the 400 pound limit.
200 pounds body weight, 35 pound pounds of accessories and 100 pounds of cargo.
Pictures to follow
nadogail
Coronado, CA
I am certainly glad I have never claimed to be a Weldor, I can make two pieces of steel stick together but h am far from being able to hire out as a Weldor.
My welder is a Hobart StickMate LX, it’s both an ac/dc machine.
I usually plug it into the 50 Amp Circuit and outlet I installed in my workshop u on occasion I have loaded it and my hombrewd generator set into my van and have been self contained for a small job.
smackey05
Massachusetts
Got a new tire on the snowblower.... Probably going to be the last year I use it before I need a new one. The chute is really rusty and the bottom is starting to rust out. Also, the wheel is rusted on the axle so I couldn't get it off to properly get a tire installed on the rim.
I really didn't care much when I was getting the new tire on it.... I'm never usually this rough with something but it is on and holding air... lol
glider
Flint Michigan
Got the new POE security camera installed. No more Arlo batteries for that spot. I'll test it out for a bit before swapping out the other Arlo cameras.
We have four LTS POE cameras feeding a NVR. It has ran for ten years with no issues, then it did. Ordered another LTS NVR and up and running again.
POE cameras are nice but a lot to understand compared to Ring and others.
kbeefy
Harington, Eastern Washington
Spent my birthday installing EGT, Fuel pressure, coolant pressure gauges and a new head unit in my salvage rebuild truck.
These are the only pictures I took.
I also have to do something about the exhaust. When it was moved out of the junkyard the loader forks smashed the exhaust.
I happen to have a used banks exhaust off another wreck so I figured it should probably work.
I cut off the damaged exhaust and did my best to hang the used replacement. Since the measurement points were rather vauge I just eyeballed it with it hanging on the truck...
It looks close enough I could just weld it, there is about 1/8 gap on one side. I have some band clamps arriving tomorrow.
rd65
Granite Falls, WA
Hauled pantry shelving parts into the house/garage. House garage is warmer than shop, the shelves are still too stinky for installation. Attemped to repair wife's office chair. Seat base was cracked where strut mounts. Strut isnt working now, may have gotten it too hot during my booger welding job. Will see if I can locate one cheap or we will replace the chair.
PhantomEB
Medicine Hat, AB, Canuckistan
Went and talked to the local Stihl dealer about my backpack snowblower that’s only a year old…..wanted to try out a new spark plug. They said here try this premixed fuel first, dump out the old fuel first, hell if you want to clean up the spark plug, feel free. if the sputter was still there, bring the empty can in and they will refund me the price of the can.
did it all and checked filters, she fired up first pull and ran like a top at full throttle.
then modified a caster… Nope won’t swivel with the new smaller bolt pattern, screw it and put the new Red 27” bottom tool box in its new home then heaved the top box on top. SPG International sure knew how to build tool boxes back then.
Time to reorganize My tools And put a butcher block top on the 42” with side cabinet.EBA01762-C9A5-44E1-A17F-62B468BAE970.jpeg
LeonardY
Southern California
A friend had made this Schaftboller ornament. But it split open. He used water washable resin and hollowed it out. The uncured resin was trapped inside and it eventually caused it to split open.
Fortunately the resin stayed on the packing foam. Otherwise it would have ruined another ornament.
He was going to make me another one. But since he and his wife just had a baby, I asked if he would just send me the digital model.
ToolsRCool
Plymouth, MI
Hacked together a paintbooth.
This is what's inside. Picture was taken right as I started assembly of said booth.
Your XJ? I know every inch of those, great vehicle. 99' was my daily driver for 14 years, never left me walking home. Ordered it brand new, every option except ABS and auto trans, was a 5 speed manual. Put KJ rear discs on it, bolted right up.
TheClaw
Chicagoland
@kbeefy Those are some nice clean splices. I hooked up a new ignition on my '86 Ducati one year. Had a connector with lots of 18, 22 gauge wires on it. I could not make them as clean as you did. Can you share a close up? Did you use any special connectors?
I've never found a good connector to do this as clean as you did. Mine always end up a soldered mess. With a lumpy piece of shrink wrap covering my incompetence.
Jeff
PWC Repair
Arkansas
It's hard to beat a mid 90's to 2000's Jeep with a 4.0. We had a '95 GCL from 74k to roughly 250k. One of the best vehicles we've ever owned!
ed_
Maine
Yup. I have one that's been torn down as a project for a few years so I bought another one (the one being painted) to drive in the meantime but then it also turned into a project so now I have two project XJs lol
That must've been awesome getting to buy a new one off the lot.
Fix Until Broke
SE Wisconsin
I've had good luck with these for small wires like that. 18 AWG won't fit, but anything smaller will and they're a lot smaller than the "red" versions.
https://www.waytekwire.com/catalog/...-shrink-covered-****-connector-26-22-ga-green
Jeff
kbeefy
Sure. This is how I do it...
Uninsulated **** connectors and shrink tube. You have to find the really tiny ones. I use these.
amazon linky
Normal wire tools arent small enough, these knipex work ok.
Heres an example with 26 ga Blue and something smaller I found laying around.
Also pictured are the heat shrink **** connector similar to the ones @Fix Until Broke mentioned.
Ta-da...
PWC Repair
Arkansas
Clean, clean, clean. Waiting on dash switches.
might as well finish up bolting up the driveshafts and cross that off the list.
I use the solder shrink connectors exclusively. I work on watercraft for a living......I simply CAN NOT have water getting into an electrical splice. You can get a whole kit cheap off amazon.
Just heat carefully and watch the low temp solder melt right into the wire.......piece of cake.
CoogarXR
Decided to test my generator to make sure it's going to run, since it's supposed to be so cold for the next couple days:
Well, it won't start. It's leaking gas somewhere, I don't know if I flooded it or what. I did pull the rope a million times before I noticed the engine switch was "off" (duh, my bad). So I'll let it dry out and see if it will start tomorrow.
I would hope the carb isn't junk already. I just put a new one on over covid, and I always turn off the gas valve and run it until it stalls (so no stale gas is ever left in the carb). I think I last ran it sometime in the summer, so it's not like it's been sitting for an eternity or anything.
Treat that gas with some SeaFoam - I have had gas in my T-bird that was almost 2 years old and it stil passed the Smog nazi's
I have a small Briggs powered generator and I should go through it again as its certainly messed up the carb after at least 15 years of sitting
SMOKEYBEAR
Was in the need of a napkin holder, probably should of just bought one. I thought the nicer ones on the 'web were over priced, them I added up what I roughly have in the ones I made. Put some ideas together, made 3 as I wasn't sure I was going to be successful. I'll have 2 to many after I finish the last one. The one with the thick aluminum cut on a 45 is the one I wanted with the base still in the works, the 2x4 scrap was just a test piece. The other 2 are by products of making the one I had in my head after I was unpredictably successfully making the rod, knob and handle components into 1 piece. I do a bunch of bass fishing ( no tournaments) hence the use/ repurposed lures.
Jay__Dub
Cold Country, Canada
I try to stick to my start once a month rule, as I'm paranoid I'll need it, and it won't go. Especially with the ****** ethanol in the fuel. I'm sure it'll fire up for you tomorrow, or you could spray a little ether in there. Good luck.
rd65
Granite Falls, WA
I try to start mine every couple months, that usually turns into six months. I do put stabil in my fuel, never run ethanol free as it is too much hassle to find it around here. So far it has started up easily every time. Which reminds me I need to run it. I added Stabil after I loaned it to my inlaws after our big windstorm and havent run the treated fuel into carb yet. It is also due for an oil change. Added to my to-do list.
rd65
Granite Falls, WA
Brought the two stained shelves into the house so that stain will finish drying. Put them in the laundery room, it has an exhaust fan. They still reek pretty good. Removed strut from office chair, measured, order a new one, should be here tomorrow. Then I can get that thing out of the garage so I can park inside again. I start back to work Tuesday and dont want to be scraping windows in the mornings. 6 weeks off sure has been great, even if I couldnt really do much of anything.
Wiz02
Southeastern PA
If you don't need to adjust the height, a short piece of pvc cut to your desired chair height works just fine instead of buying a chair strut.
gatewaysysop
Arizona
A few days back, but let's pretend it was today. 😳
Removed the gummy, oily, worn-out Jacob's 'Multicraft' 1/2" chuck from my smaller, 1982 Taiwan-made 'Chicago Power Tools' drill press.
The previous owner had apparently swapped out the original 1/4" chuck and put this over-capacity 1/2" on there. I opted to split the difference and put on a 3/8" Llambrich replacement with the nice fluted collar:
Much better:
The press itself is nothing particularly special, but it has served me well so I figured it deserved an upgrade. 😎
