600SL
OK as far as I know the radiant heating system is all up and ready to fire up. Propane lines are leak tested, antifreeze is filled but may still have a bit of air in it. My only real problem is that I have no understanding on the settings required for this. The only setting I changed from the defaults is 5:St was changed to off. I turned that off because I called customer service and that is what they told me I needed to do along with leaving the valves open on the DFW ports, in order to run the unit without DHW.
So basically both zone thermostats are turned off and ready to hit the switch. But I just want to make sure I'm sake to fire it up and is there anything else I need to change in the setup.
The attachment show the settings page, I'm having trouble with and the complete installation guide.
