comedyman809
one of our facilities had an accident, and im trying to nail down exactly what they mean by "port a pak"
here is the email i received...
A
Incident Report has been filed at the Syracuse plant and is being distributed for your notification only. You will receive additional notification when the investigation of this incident is complete.
PLANT LOCATION: Syracuse
DATE OF INCIDENT: 10/02/2010
INCIDENT SUMMARY: RECORDABLE INJURY -- Restricted Duty
INCIDENT LOCATION: Finishing Feed End
JOB TASK: Maintenance
DESCRIPTION OF INCIDENT: Struck By
DETAILS: Employee was doing repair work on the Feed Section of the 303 Langston Flexo. The work involved the removal of a double sprocket that opens and closes the machine sections. The sprocket needed to be removed to replace the bushing in the machine side frame which was worn. As employee was attempting to remove sprocket with a hydraulic porta-pak the jaws/ arm on the attachment snapped. With the hydraulic porta-pak under pressure and the jaws positioned between the sprocket and machine side frame, the unit released and struck employee on his right forearm.
sounds like a hydraulic puller to me, any thoughts or ideas what exactly is a "porta pak".
i have never heard anyone refer to a puller as a " porta pak"
A
