The "Titan" models certainly do. Can't speak to any others.Do most of these bit ratchets hold the bit pretty well?
Thats a pretty substantial point you make there BrandonV.Do most of these bit ratchets hold the bit pretty well? The only one I used (forgot the brand) twice when I either accidently dropped it or put it down the bit fell out and of course per Murphy's Law went down into an elevator shaft where I had to go into the pit to retrieve them (no fun).
Already have it@BlakeTheCarGuy , you need to buy the Icon bit ratchet set at HF! Highly recommended.
I bought one of these a while back just for tight space work. I used to have a similar set that included some metric sockets but it think it was on board a bike that I sold. Not exactly a hig( end ratchet but it works and packs very small.
Finally a ratchet I can put in a drillWera released a smaller Tool Check with/for their “Advent calendar” late in ‘24. While I do live in a world with an abundance of bit ratchets, including the original Wera (shown here for size reference) I couldn’t resist the set and opened a door each day through December.The novelty is a bit ratchet head with 1/4” hex shaft. So you can even make it a “long” handle ratchet - for a set & ”on the go” not too bad, I guess.
Kind regards,
Olli
I have that and despise it. Always switches directions too easily when using it. That doesn't happen with yours?
I’ve only used it a couple of times and don’t remember that problem.I have that and despise it. Always switches directions too easily when using it. That doesn't happen with yours?
Mine is nice, but I have not abused it. The price is goodDo yourself a favor and buy one of these
That is nice. Well worth it. Low back drag.I have a 3-piece set that was made for Craftsman long ago, guessing by Lisle. One straight, one angled down, one angled up. While I've gotten plenty of use out of them, the back-drag is pretty horrible. I'd be keen to know which of the numerous offerings that have been posted in this thread stack up with regard to back-drag.
back in the day the set was made by Kastar which later changed its name to Lang Tools.I have a 3-piece set that was made for Craftsman long ago, guessing by Lisle. One straight, one angled down, one angled up. While I've gotten plenty of use out of them, the back-drag is pretty horrible. I'd be keen to know which of the numerous offerings that have been posted in this thread stack up with regard to back-drag.
Yes, it does, and the grips are indeed black. I had a senior moment (happens too often anymore) when I typed "Lisle." Meant to say "Lang," which is who I've presumed the set was made by. Thanks for the correction. They're decent and useful, but I wish they had about 1/10 the back-drag that they do have.back in the day the set was made by Kastar which later changed its name to Lang Tools.
Does your set look like this set but with black handles?
SKU : 5278 - 7-PC. Ratcheting Screwdriver Bit Wrench Set
Manufacturing professional tools since 1932www.langtools.com
I have the Lang 3 piece bit ratchet set and they are Ancient tech and a bad, outdated design!
Stay away from buying them!!!
www.jbtools.com
There is a huge difference between the Lang bit ratchets. The fine-tooth ratchets are quite good. The laminated ratchets ****. In fact, all laminated ratchets and ratcheting wrenches ****.Even the newer fine tooth models? Looks like Blue Point sources theirs from Lang.
Lang Tools 7-Piece Fine Tooth Bit Wrench Set (5220)
Get reliable access in tight spots using Lang Tools 7-Piece Fine Tooth Bit Wrench Set. This set combines unique wrench designs with common bit sizes, offering fingertip control and ratcheting action.www.jbtools.com
My bad. The good Lang bit ratchets are laminated. However, it's not just three flat pieces of sheet metal riveted together with a coarse tooth sorry excuse for a ratcheting mechanism. The ratchet works pretty well and has reasonably low back drag. It has less back drag than the Snap-on dual 80 but more than my Victorinox bit ratchet.I have the newer high-tooth models. I think they're technically still laminated, just not exposed? Some kind of edge-banding going on, anyway. Maybe not as sturdy as a solid ratchet, but does it need to be?
I like the thumbwheel more than I thought I would. Really think the magnet should be stronger.
Pretty serviceable overall. Selling a three-pack instead of making it a flex-head was kind of a funny choice.![]()
I bought mine by itself without a multi-tool or bits. It's been a few years since i got it, so I don't recall the source.That Victorinox ratchet looks very attractive because of its size, and being Swiss-made, I would expect its back-drag to be very low. I looked around a bit (no pun intended) and didn’t find a source for it as a standalone item. I only saw it included in a package deal with an expensive multi-tool similar to the Leatherman.
VIC 3.0306 is a small kit with the ratchet and 6 bits only.That Victorinox ratchet looks very attractive because of its size, and being Swiss-made, I would expect its back-drag to be very low. I looked around a bit (no pun intended) and didn’t find a source for it as a standalone item. I only saw it included in a package deal with an expensive multi-tool similar to the Leatherman.
hausoftools.com
https://www.knifecenter.com/item/VN...-9B8YAqN6wKbE1KhUyMWO1JOiOUqm73WJVOITVsulvNSP
Posted on page 1, twice:
Victorinox Part Numbers
Model numbers are as follows:
Victorinox
Bit ratchet: 30342
Extension Bar: 30344
Pouch with bits and angle wrench: 33340
I actually got the VIM version of the flex bit ratchet since the reach is a useful thing on Mini's, old BMW's and other PITA cars I seem to work on, and was surprised that the 1/4" adapter is slightly shorter and has a very-slightly shallower shoulder that adds up to about 1.3mm shallower profile with the same socket.
I tend to throw it in my travel kit with the PowerTorque sockets for a really-shallow option. Saved our butts when a buddy of mine had the alternator belt let go over 100 miles from home and the Icon/PowerTorque setup was the only thing we had that could get to the tensioner.
