Being real honest I don’t need this but it would be real sweet and if it doesn’t exist I’m open to drilling a hole and trying to modify one as a fun project.
i want to be able to use a tekton multi bit screwdriver as a 3/8 drive nutdriver. But none of the socket adapters I seen have the ball bearing detent thing. Maybe I can drill a hole in one and put something in there like that to lock it in place. This is for a small mobile toolkit to maximize options with a small number of tools.
if nothing exists what could I stuff in a hole drilled in a regular socket adapter that would give it some friction? Idk how to get a ball bearing in there I’m guessing it’s a very precise hole just smaller than the ball bearing and you put a small spring inside and then use a press to force the bearing in. I don’t got access to a press.
Maybe I can just shove some plastic piece in there for some friction. Maybe melt some plastic and let it harden and then file it down to be about the ball shape on the original kind. This isn’t going to be something I use regularly.
gonna post some pics of the two
