that does seem quite loose for a head bolt. I am thinking those are 5/16 or 3/8" head bolts, but I guess it depends on engine size, maybe.Well I think the head gasket bolts are not very tight. I set the torque wrench to 140 inch lbs just to see if I could get there. Felt it slighty budge at 120 so theres that. Must be around 115 or so
I have an engine gasket kit. Im replacing everything.head gasket bolts?
you said you were replacing a PAPER gasket which I understood to be the lower CASE gasket on the engine CYLINDER.
The HEAD gasket on a Briggs engine is a metallic-faced sandwich-type gasket - different animal, different torque value.
I was seeing where the torque wrench got too before I felt the bolt move. I just guessed 140 in lbs and set it to that thinking I could complete 140 in lbs before I had to reset it with a higher torque. I felt it move early though. Double checked, 115 inch lbs and they slighty tighten. I was careful. I agree, thats so very loose. I wonder if this has been worked on before.that does seem quite loose for a head bolt. I am thinking those are 5/16 or 3/8" head bolts, but I guess it depends on engine size, maybe.
I think the case bolts will be 1/4".
Confused on the "get there" comment. You should be able to get to 140 inch pounds with one finger, but it's kind of the limit for one finger.
Just so you know, bolt size is not the size of the socket or wrench that goes on it. It is the size of the actual threaded fastener. If you are using a 1/2" wrench it is probably a 5/16" bolt but could be anything.Oh btw, head bolts are 1/2" lmao
Wow, thats good to know. Thanks! Guess im not sure thenJust so you know, bolt size is not the size of the socket or wrench that goes on it. It is the size of the actual threaded fastener. If you are using a 1/2" wrench it is probably a 5/16" bolt but could be anything.
Thank you for your help!@chilly13 - I only work on walk-behinds, and only on the smaller engines that are on walk-behinds, so I don't deal with starter motors or alternators. I cannot address your question on the brushes, other than to say you should be able to procure most any part for that motor, if not from a local lawnmower shop then through jackssmallengines.com or partstree.com
Your "head bolts" are most likely 5/16-18 USS coarse thread, or 3/8-16 USS coarse thread. I am guessing you're using a 1/2" wrench or socket to remove them.
Torque values for head bolts on the pages below. I will be out of town tomorrow.
Yes, I like his videos, good quality. I didnt get it done sadly and have to go do a 12hr shift. Been working 6 days a week for a few months now and my garage and spare room looks like a tornado has destroyed everything. Im having trouble taking the flywheel off, shes pretty stuck. Before I called it a night though, I felt to see how tight one of the case bolts was and let me say, it wasnt loose enough to back off with my fingers but I mean the wrench did BARELY anything and I got it to loosen. Possibly the reason behind the oil leaks to begin with? We will seeI second the idea of watching some videos of a James Condon on you tube. especially testing the generator head since you seem to have some issue with brushes .
Good recommendation, his videos are really good quality. Thanks!set the tools down and watch some of this fellow's work. Probably all your answers will be there. https://www.youtube.com/@jcondon1
The case gaskets are sometimes used to set crank end play, so just sealer could be problematic. It would be interesting to do a trial assembly with sealer and measure the play. I'd certainly trust a good sealant to be less leak prone than a paper gasket.I have to wonder about skipping the paper completely and using a modern sealer.
That's good info, thanks man!To select the correct case gasket, you would want to first assemble it without any gasket, and measure the crank end play. A dial indicator is the easiest, but a feeler gauge can also be used with a little thinking. After you get the side play figure, you would want to use a gasket that will put the side play at around .010.
