Offset Brush Hog
trbomax
starvation lake,mi.
We need one this year on the trail system,but I was haveing difficulty finding onr for less than $8000,which is not acceptable.Then I got to thinking about the really tough one I had out in the woods.A few hours later a plan came together and I was hammering out new bracketry.This will offset the mower 14" to the right while keeping driveshaft geometry at accepatble angles. Here it is tacked up,tomorrow I'll get it welded and mounted for a test mow!
larry_g
oregon
The only thing I see that may be a problem is that the right lift point is very near the center of the mower deck and may cause the deck to 'flop or rock' side to side. Consider two rear wheels spaced near each side, or a counter weight near the left side.
T
trbomax
starvation lake,mi.
Snowmobile trails?
We just run teh tucker and drag right over all the junk that is in the way :bounce:
Michigan is funny about that,we are paid to brush every year,they want NO brush or punji sticks within the trail ROW,which is 15' BTW,how many hrs on your tucker toy? We had one 2 yrs ago that was the biggest pos on the trail. We spent over 15 grand keeping it running the last year we had it,mostly track and driveline related.It broke springs on a weekly basis.
To ands the other question,it wont rock because we drag it right down on the ground,pretty brutal,but it works.
nate379
Palmer, AK
One we have looks alot like the one in your photo actually. Don't remember the model #, though it is a JD.
Called a "Tucker" because in the 80s and real early 90s they used an actual Tucker brand machine. Worked really well but it had a 600-700 cu in gas engine and it was hard on parts... and gas!
T
trbomax
starvation lake,mi.
That tucker toy we had was so bad they bought it back. The one in the avitar is my trusty 8120t,5400 hrs and still strong.Sadly its up for repalcement so this might be our last season together!
Did get the mower on and tested,had to steal the driveshaft off of my auger because the mower one was 25" short!Seems to work good.
T
trbomax
starvation lake,mi.
Couple pics of the finished product.Saturday it will get to mow about 35 miles of trail edge.It looks like its crooked with the 3 pt,and it is,only because the arm extensions were not retracted and latched.After looking at it and useing it a bit,I could have moved it over another 6 inches.
OccupantRJ
Eastern North Carolina
You could rotate the gearbox several degrees, and reduce the driveshaft angle. Then you could offset it even more, since the angles you have are already acceptable, right?
T
trbomax
starvation lake,mi.
Yep I could,but it is what it is for this year. What I'd REALLY like to do is mount it on the side of the loader (up front),drive it with a hyd motor off the pto,and hinge it up/down.That way I'd have 4 axis control, up front where I can see!.
fergus
Yolo County CA
Nice work man. Thanks for sharing. Its great when you can tweak something you already have for another purpose.
OccupantRJ
Sounds like a plan to me! Ever seen this wood splitter?
DaleK
East-Central Ontario
Nice! If you do have to leave it where it is next year, I'd get another gearbox at a wrecker and turn that one 90degrees, put the new one straight behind the PTO shaft.
T
trbomax
starvation lake,mi.
Driveshaft angle concerns go away when you use hydraulic drives. But then leaks and hoses become a problem...
Hydraulic IS the way to do it,I just didnt have time. I think I'll just build one next summer that will attach to the loader arms,swing up/down 90 degrees,and slide out 2 or 3 feet. Drive the whole thing from a pto pump /tank mounted on the 3 point. I'll build it to mount on the JD 7730,that tractor just sits all summer anyway.
Busted Bolts
NewEngland
Another idea next year is to fab it up like a mower conditioner, instead of hooking it up to the bars, make a center pivot link with an arm and use a hyd cylinder to pivot the offset. you wouldn't have to worry about the weight offset as you are only towing it. If you could add dual rear caster wheels, and carry it down the road straight and angle it when you do the trails. Look at the JD 625 MOCO for ideas. I'll look for a pic
T
trbomax
starvation lake,mi.
The wife and I were out replaceing signs a few days ago and the club to the south of us was useing this. I think I'm in love and got to have one!Same tractor as mine,but what a kick-*** brusher!!He let me give it a run,joystick controled and will run right down in the dirt,never leaves a punji stick.At $13000 its a sweet deal.I have a 3 pt power unit,if I could pick up a hyd driven mower,I could fab the rest, but I'd like it better on the front end.
