welder4956
Birmingham, AL USA
Too wet to paint suspension parts, so I tried to repair the cobbled mess that was the neutral start switch for the Mustang. I managed to remove the old splices, replace them with solder connectors and heat shrink, cover the bared areas with liquid tape, and cover the undercar portion with heat resistant braided sleeve. The new one was delivered as I was repairing the old one, so the repaired one will be a spare.
TurnipTruck
Southcentral Alaska
I ran out of satin white before the last two panels were fit, so I had to unstack and repaint all the painted panels with the same semi flat white just so everything would match.
Definitely a working shop. Or I’m a slob.
I count parts for four major projects and dozens of microprojects strewn about in this candid.
DGersic
DeKalb, IL
Got the shelves in the cabinets finished and installed.
The mid-left one doesn’t get a shelf. The recycling bin goes in that one.
Started working on installing the doors. Found that they are slightly too wide to fit the holes in the face. So I set up the router table again and trimmed 1/8” off. Have to touch up the paint, but it’s on the inside (partial inset) and won’t really show much.
I meet a friend for lunch on Fridays. Got to the restaurant, and SWMBO called to tell me that the ceiling in the kitchen has a water spot.
I just repainted this ceiling last year, after a water spot. That leak was fixed. This is a new leak.
Spent some fun time in the attic. It’s only about 3’ high, and a joy to navigate. Marked the wet spots with a quick shot of red paint.
Guessing that it’s the flashing around the roof vent. Got a pan under the drip. It’s a small drip.
Need to do something about that vent ”support” too, one of these days.
larry4406
Northern Virginia
Is that your range hood duct in the attic venting thru the roof?
If so, you should insulate it. We have problems here in Northern VA where in summer months, humidity condenses on the outside of the duct which is exhausting inside chilled air from the AC (even through range/cooktop is running). This condensate then runs along the exterior of the duct finally finding a low spot and dripping into the house.
In the winter, the opposite occurs. Water vapor in the inside of the duct (from cooking vapor and inside humidifier) condenses and runs down the interior of the duct, finds a spot to leak out, and same problem.
Make sure your hood has a back draft damper at the appliance. Many installers take them out thinking that the flapper on the wall cap or roof vent is adequate; its not and you want both.
Old Man Roger
Palm Coast Florida
Cleaned the rear suspension and then the engine compartment. Received the heads back from the machine shop where all exhaust valves/guides were replaced. Intake valves/guides were good and did not need to replace these. 5 valves per cylinder….. All jewel like!
IMG_6045.jpegIMG_6044.jpegIMG_6041.jpegDSC_0016.jpegDSC_0014.jpegDSC_0012.jpegDSC_0006.jpeg
Thanks for taking a look.
Ya, it’s got a hemi :badteeth:
DGersic
DeKalb, IL
Make sure your hood has a back draft damper at the appliance. Many installers take them out thinking that the flapper on the wall cap or roof vent is adequate; it’s not and you want both.
Yes, range hood vent. Been like this since a remodel about 20 years ago.
PhantomEB
Medicine Hat, AB, Canuckistan
Upgraded to some USB plug ins out there to clean up the wall outlets. Needed to be able to plug my wireless charger out there for days like this where I need to have my iPhone fully charged while on call
today is clean up some more after bronco time with wiring. Need to put daily in for the deep freeze coming in.
Jay__Dub
Cold Country, Canada
Man I got to get with the program, I didn't even know usb in outlets was a thing. Still using my blackberry.
I have a growing number of USB devices, and with a USB charging point/power source, and the way better batteries available, you can do so much besides a phone:
Flash lights, small work lights, portable fan/light/charging stations combo, GRMS/FRS radios, adjustable power supply for my nickle plating, Aquarium air stone bubbler for agitation during plating, the list keeps growing.
I don't have these yet, but you can charge an electric tooth brush via USB powered charge station, rum small water pumps, charge Arc lighters, etc...
You don-t need to use a lighter socket adapter either they make them pure USB or a USB lighter socket combo.
For camping/remote, I setup a solar charged UPS battery with a lighter socket and that is my "Off grid/No car" recharging station.
Solar panel keeps this charged and can charge a lot of USB devices:
Skyman
Central Maryland
So what did older adults do when 2 door cars were popular? Younger folk did the climb.
How about older folks who don't have the upper body strength to pull themselves up into a vehicle with a tall curb height? These vehicles are very popular today.
I got up on the wrong side of the bed today, just ignore my bitching. I will keep fingers away from keyboards until my mood improves.
Nearly all two-door sedans that have a back seat have longer doors than would be used for the front doors of a comparable four-door car. Access to the back seat of this 2-door Blazer is a challenge for anyone who's not as nimble and skinny as a teenager. The doors are the same as were used on the S-10 pickups, and the passenger's seat doesn't move or fold forward nearly far enough to provide reasonable ingress/egress. Driver's seat is worse. It's pretty pathetic, actually. But it does have three pedals for operation, which was a requirement for me. Me no likey slushboxes.
CoogarXR
Fixed the wife's Shark Steam Mop. The internal heater had a calcium buildup and it blew the hose off trying to push through it. Cleared out the crustiness and blew it out with my compressor, and she's steamin' again. The mop that is, the wife isn't steamin', she's happy!
Fixr
SW VA
Haven't heard that in a while.
There are times when I get tired of the 3-pedal purists whining about automatics even daring to exist and would like to challenge them to drive a 4 inch deck screw sideways through their left knee and leave it there for a few years while still driving manuals and beating their chests while dragging out more "millennial" memes from decades ago.
nadogail
Coronado, CA
One of our favorite tenants came to visit us, we discussed her continuing with us for another pair of years.
She wants some things that I feel are completely reasonable and I will have my vendor set up an appointment to measure.
Her carpet has gotten worn and we both feel that Vinyl Plank will be an excellent option.
Fixr
SW VA
Good tenants are a pearl of great price.
kaymccampbell
Upstate New York
My hip, knee, n ankle moved me from stick to auto. I bought the Burg to relieve carpal tunnel. For me, clutches are no longer a joy. I'll miss em, but the joy of still being able to drive beats out that little tweak of being in full control.
Fixr
SW VA
Full disclosure: I could still enjoy a full day in a Miata if I had one, but jockeying half a dozen semi-tractors around repeatedly a few times while the boss spent all day figuring out how he wanted the parking lots arranged really took all the fun out of clutches the last year before I retired. Can't float gears under those circumstances. And doing all that painful clutch work didn't make my **** even one foot longer.
Wiz02
Southeastern PA
I agree, having a skill doesn't mean that you should sneer at those who don't have that particular skill.
That being said, executing a smooth heel and toe down shift gives me a real feeling of accomplishment that paddle shifts don't.
ed_
Maine
The XJs coming along nicely. Had a new windshield installed, and I've gotten most of it's issues resolved at this point. The CEL due to the NSS finally went out too. The original paint is pretty smoked but I did a quick polish to make it shiny to match the new paint today.
The new paint on the quarters / roof is slightly darker but it's a good enough match for a 213k mile XJ lol
I've got new 30" tires / rear disk conversion waiting to be installed.
Fixr
SW VA
Not skill. As I said, drive that screw through your knee and get back to me about how much fun heel&toe is.
Hell, my knee isn't that bad. I can still enjoy driving a car with a clutch, although there are newer technologies that actually work better for going fast in a car. But the contingent of assholes here who pretend that severe knee pain is no excuse for driving an automatic have long ago has long ago stopped being clever. We have a shitload of old folks on this forum who no longer get their rocks off by fighting blinding pain just to be able to claim to love three pedals more than life. It's not funny or convincing any more and it doesn't enlarge your orchids. Enough, children. The world is changing. The cars are getting faster and better. Try to keep up. Or get a horse & buggy.
dwasifar
Installed new front speakers in my wife's Forester. Morel 6.5" coax. They sound so much better than the Kenwood speakers they replaced. I have never seen car speakers age so poorly.
Edit: here are some pictures of the old speakers.
Interesting how the coating has faded off the mylar tweeter. Look sharp and you can see the wire right through it.
Fixr
SW VA
When you say 3 pedal purists I hope you are not talking about model t owners since the transmission is controlled by 3 pedals
That was my dad. He's been dead since about 1993. Things have changed since then. There are folks right here today that insist that the only true way is something like a four speed rock crusher and a leaky Holley. Gets old after a few decades.
There are a shitload of other options besides top-loaders and power glides. But a whole bunch of people can't move beyond those because they are terrified of man-buns. And think they are still up-to date.
Whatever. I'm tired of the hate for anything new. Pull your heads out, fellow Boomers.
kaymccampbell
Upstate New York
I'm a boomer. My 8 speed automatic Escape is a far cry from my Powerglide Chevies. It's quicker, smoother, more economical, more comfortable, and tows as much. No complaints.
