How did you "hide" your breaker panel? Post your pics here.
fergie_1977
Petawawa, ON. Canada
If you closed in (hide) your breaker panel...post a pic here.
As usual, I'm coming to u fine folks for valuable input.
I'm looking at replacing the old subpanel in my 24x24 garage.
I'm closing in the walls with OSB (chipboard). I will mount the new panel where the old one is and clean up a lot of terrible terminations.
I want to close in the panel and have it out of sight.
Of course it has to be easily accessible.
Should I just build a 2x4 box frame around it and slap some doors on?
Post your pics here so we can discuss.
Thanks everybody!
Fergie :beer:
Ford12508
Middletown NJ
Make something so it matches the near by cabinets or your tool box. I dont have any pictures and am too lazy to take any, but in my basement, the box is covered with a wood that matches a shelf and the pool table. The door is 1" of molding that has stained glass on the inside. It really looks good, but it costed a decent amount also for the stained glass.
tfi racing
Cedar,BC
Code says you cannot do that. The panel must have (I believe) 3 feet of clear and open space in front of it.
Really?As long as the decorative door swings open 90 degrees and does not impede the removal of the panel cover in any way,it is permissable,at least on this side of the border.
Norcal
Please note that the OP is in Canada, the CEC has many rules that differ from the NEC, 1 difference is that under the NEC a horizontally mounted panel is prohibited, in Canada it is quite common to do so because of another rule......:D
Aceman
Eastern Oregon
Thanks everybody!
Fergie :beer:
I can understand trying to hide a panel in a home, but in a shop?? Are doors really going to look any better than just painting the panel cover to match??
thdewey
Gastonia, NC
Hide.....Really.
Yesterday, I found something proped over the panel and I thought "What the hell was I thinking... Remember that your panel box is a piece of SAFETY EQUIPMENT. DO NOT HIDE IT!!!! If you are getting shocked, someone (who might not be familiar with your shop) will need to find it quick.
Now saying that, you can coordinate the color/design to better blend in in a pleasing way. You could make another outer door that matches as described above but make it oversized and make sure it won't impeed access to the breakers.
Good luck and please post a picture of your finished product.
sberry
Brethren, Michigan
I have a dry erase board covering the one in my office, wall space is at a premium.
reinhardt
being in a shop, i would recommend painting it w/ chalkboard paint. it's metal so u can stick magnets to it, and w/ the chalkboard paint you can write notes on it. best of all, it isn't hidden so it's easily accessible.
that's what i would do anyways.
652plus2
I did this with mine...
The other one too...
trbomax
starvation lake,mi.
Maybe its just a michigan thing. I just looked thru all my building stuff and couldnt find it,But I remember a conversation about it with the inspecterguy.He said I couldnt put a bench in front of it either and very adimant about the "clear space" thing.
sselander
CT
Here in CT, we wanted to put the panel in the laundry room on the 2nd floor for our new home
We were told the code would not allow it (due to clearances), so it is now in the hallway
monstergarage87
Branchville, NJ
Heres mine... built a little box around it out of bead board to hide the wires and painted it the same color. Blends right in but very easy to access everything since the panel cover holds everything on. Cover pops off and the panel slides off.
Stuart in MN
Minneapolis
Yes, you need clear working space in front of the panel, but something like a door or a picture or a mirror on hinges that will open up fully against the wall should be okay as it won't obstruct that working space. It's possible that some inspectors won't allow it, and it's also a reasonable argument that the panel shouldn't be hard to find in the event someone needs to find it right away.
If it were me I'd leave it as is, or maybe just paint the front cover of the panel to suit the decor of the room.
oldgoaly
Shiloh, Il
I built a room for my compressor around the main electrical panel, I have clearance and a quieter shop can't seem to find a pic of the wall of room???
dipper
Rochester, NY
Why hide it? I love looking at clean, planned out installations. Plumbing & electrical can be an art if it's done neatly.
jvitez
Big Sky Country, Canada
Very creative ideas gents. Good stuff.
Personally, I agree with dipper. I like the industrial look. It's what I'm going to do with my garage.
Charles (in GA)
50 mi south of Atlanta
I'm quite proud of my panel installation and show it off to anyone who will look:bounce:
Its a safety feature, kinda like fire extinguishers. You want anyone who comes in there to be able to locate the panel without delay or issue. I have a main breaker in the disconnect outside and NO main breaker in the panel inside, so you really need to know where the main breaker is too.
I cannot see hiding it. NEC says you have to have the area from the face of the panel, outward for 36 inches and a width of 30 inches, and a height of 2 meters, clear of anything. You are allowed to have a door swing open and obscure it, so long as the door can be closed and allow access to it....... provided that it is not the only man door access to the room or area. The panel does not have to be centered in the 30 inches, but must be fully withing the 30 inches of width.
Charles
mmhouse
Desert Southwest
That's funny. Mine is in exactly the same spot with relation to my garage door and I didn't hide it either...really no need to as it's pretty much out of the way.
quick86
Lansing MI
LMFAO! I was thinking yesterday how to hide the breaker in the garage of the house I am buying and thought ... "You know... Off set it with a really bright color and a hazmat or nuclear waste logo..."
Perfect!
ecotec
That panel is a FPE Federal Pacific Electric,since they have a reputation for failing to trip on a overload so the lightning on the the panel is appropriate.:shocking: :shocking: :shocking: :shocking: :shocking:
in my local, my brothers call them "Federal Fireplace".
DzNuts
Funny how on 'Holme on Homes' he finished a garage for a guy and he covered the panel with a cabinet. Pretty sure when you opened the cabinet the breaker was right there, but it might prove that it's legal to cover it with something as long as it doesn't have to be 'moved' or 'removed'. Just hidden behind a door would be alright.
This is only food for thought! I'm not an electrical inspector or even a sparky!
shopnut
Florida
I chose to just make mine go just a little better with the rest of the color scheme in the shop. I still like to have it readily accessible, especially now while I'm still finishing off the place and needing to turn circuits off/on.
Do yourself a favor and spent a little time INSIDE the panel too. Proper labelling right next to the breaker is much easier to deal with...
HarleyArley
Morrow, OH
Mine was a mess with "surface run wiring outside the wall cavity and running in front of the header through the ceiling. Here's a before and after picture.
As to the "you can't do that" crowd... its mine, so forgive me if I do whatever the hell I please. :)
