Wamsutta
Which is better; Teflon or Graphite?
You gotta have the valve fully open to have the stem extended up all the way don't you? Aren't you supposed to wrap the entire stem?Fully shut (or fully open if machined to have a backstop) should slow the flow enough to allow you to repack, especially if it’s just rope and not rings.
You angle cut the beginning of the square section Teflon rope and wrap it around the stem a couple times to fill the stuffing box, assuming you dig all the old packing out, tamping it down with the stuffing box gland follower. This is also assuming it’s an OS&Y (Outside Stem & Yoke) with two bolts holding the follower down, and not a giant threaded bonnet. A little baby 1-1/2” valve could have either.You gotta have the valve fully open to have the stem extended up all the way don't you? Aren't you supposed to wrap the entire stem?
Sounds to me like you just found that little five minute fix that requires re-plumbing the entire house.Main water shut off gate valve 1-1/2". Made out of solid bronze. Age is somewhere between 60 and 70 years. Wish I could just replace the whole valve, but the steel pipes connecting to it are corroded in place. I tried measuring the stem diameter a few minutes ago and my 12mm wrench fit on it the best. 11mm is too tight and 7/16 is too loose. 12mm just right. My next venture is seeing if the stem is replaceable. It's got wrench flats to loosen the stem assembly, but I don't dare unless I'm sure.
Oh I know that. I've had a trench dug in the front yard for years. I need to replace both the water line and the sewer line.Sounds to me like you just found that little five minute fix that requires re-plumbing the entire house.
If the galvanized iron pipe is that corroded, you're not too far from some major failures.
What difference does the diameter of the stem make, if you are repacking it?Main water shut off gate valve 1-1/2". Made out of solid bronze. Age is somewhere between 60 and 70 years. Wish I could just replace the whole valve, but the steel pipes connecting to it are corroded in place. I tried measuring the stem diameter a few minutes ago and my 12mm wrench fit on it the best. 11mm is too tight and 7/16 is too loose. 12mm just right. My next venture is seeing if the stem is replaceable. It's got wrench flats to loosen the stem assembly, but I don't dare unless I'm sure.
What I'm thinking is I should try to find the correct size seal instead of using the packing string all the time which doesn't stop the leak completely. Right now I have a slow drizzle which is better than spraying all over the place.What difference does the diameter of the stem make, if you are repacking it?![]()
Did you try to tighten the packing nut?What I'm thinking is I should try to find the correct size seal instead of using the packing string all the time which doesn't stop the leak completely. Right now I have a slow drizzle which is better than spraying all over the place.
If I tighten the packing nut too much, the leak turns into a squirt and goes straight up the valve stem. I'm using Home Depot packing string. I think the Ace Hardware packing string I used last time is probably better quality. Next time I'm going to try the graphite instead of the Teflon. I would love to replace the whole valve put the pipes connecting to it are heavily corroded and aren't going to let go of the valve without crumbling apart and creating a bigger problem.Did you try to tighten the packing nut?
W seriously, how many decades is that packing material been in there?
When I worked for a plumber occasionally, we’d have to repack them because they had not been turned maybe in 30 years
I tried what you’re considering, but all valves are not the same as new valves
Are you pre soaking the string?If I tighten the packing nut too much, the leak turns into a squirt and goes straight up the valve stem. I'm using Home Depot packing string. I think the Ace Hardware packing string I used last time is probably better quality. Next time I'm going to try the graphite instead of the Teflon. I would love to replace the whole valve put the pipes connecting to it are heavily corroded and aren't going to let go of the valve without crumbling apart and creating a bigger problem.
How much string are you adding?If I tighten the packing nut too much, the leak turns into a squirt and goes straight up the valve stem. I'm using Home Depot packing string. I think the Ace Hardware packing string I used last time is probably better quality. Next time I'm going to try the graphite instead of the Teflon. I would love to replace the whole valve put the pipes connecting to it are heavily corroded and aren't going to let go of the valve without crumbling apart and creating a bigger problem.
