jd5000
I bought an old Wissota bench grinder. The grinder is fine but is missing the side guards. Could I cut out a piece of acrylic/plexiglass and use that for some side guards?
-Plywood has a chance of catching on fire so I wouldn't use that either. Davefr had it right, trace the outline on a sheet of steel or aluminum (which is easier to cut/drill) and drill the mounting holes. Knock off the sharp edges with a file, paint, and it will not only be safer but also look professional. It's a nice grinder you have there, might as well make it look good too.What about making them out of plywood? Would that work? Any other ideas?
You are confusing two VERY different materials....
-If it's safety that concerns you then no. Polycarbonate/Lexan/Plexiglass can shatter easier than you think, depending upon thickness and stress raisers. When it shatters the shrapnel edges will be like knives...
Lexan is used in forestry equipment windows and gets hit with branches all day. Optioned for skid steers for safety of rocks hitting it, like with a bush hog or fecon mulcher-Not knowing the size of the motor:
-If it's spark control then it's decidedly not as good as sheet metal. Sparks will soon begin to cloud the transparency and it will look like an amateur home-shop effort.
-I'm not knocking you for asking I'm just trying to steer you into a safer solution than Plexi. Ask yourself why OEM doesn't use plastic sideguards? The larger the motor the greater the risks. JMO
-As a former mold maker I'm well aware of the fact that they're different materials. You're stating technical definition but ignoring the context of my reply. I purposely lumped them all together for the benefit of the OP, or anybody else reading, that probably wouldn't know the difference of one plastic to another. The fact that the next suggestion was for plywood certainly supports that theory.You are confusing two VERY different materials.
-Yes, I've made many safety shields from Lexan that would survive impact. Despite the impact resistance of the material there's still a tendency for fracture propagation at stress raisers. For an unskilled person to try crafting a guard from Lexan there's a good chance several stress raisers would be present in the form of poorly drilled holes and sharp edges. Furthermore, the OP is not likely to know one plastic from another and substitute whatever is available. I don't like to offer advice that I think may lead someone to injury and I'll attempt to offer a safer solution.Lexan is used in forestry equipment windows and gets hit with branches all day. Optioned for skid steers for safety of rocks hitting it, like with a bush hog or fecon mulcher
Also used in race car windshields... maybe not now, I haven't followed NASCAR in ~25 years.
