With the cost of lacquer thinner, maybe..Single-use guns? It would save on clean-up time.
There are 3...
Primer
Base
Clear
So that's a used wrench? Best way to find some of these formerly common tools.
I often carry a 1/2-7/16" DBE for valves and such around the brewery. The DBE is better for these as they often have tight clearances around the fastener. My old Crafty long-shank has very thin box ends.
Had to order it. The industrial supply in my neighborhood is big $$I've recently started filling gaps and starting my good metric collection with Proto. Granddad's were Craftsman, Thorsen, Proto, and SK--plus Snap-On and Mac oddballs (mostly hydraulic line wrenches).
I paid $7 or so for my USA 7/16 (provided, it was a nicer ASD wrench)--not bad, personally. Heck, the Taiwan Craftsman Overdrive (which, best I can tell, work the same as ASD and Knucklesaver) ones are about that. On another note, the mine supply near me is cheaper than Zoro.
I like to keep DOEs in my "upstairs" (but used for everything around the house and when I'm away from the shop) toolbox as well as the vehicle boxes--they take up less space, and are far better than adjustables. Especially considering that for the most part, 2-3 each in SAE and Metric handle most of the stuff I work on regularly. Ironically, two of those in SAE are 3/8-7/16 and 1/2-9/16./
That reminds me, I need to call and submit the order for those sizes in SAE and Metric at the mine supply.
No it’s new. Ordered from Zoro.So that's a used wrench? Best way to find some of these formerly common tools.
lol - if they don't show back up for a while:okay I give up... what's IN the "Craftsman 1/4" drive Compact Tool Set" ?? what are we getting on that one?
Nice!
I'm getting a full metric set of ASD from the mine supply, but they don't have them in full sets. Thus, I'll have to probably do the same.
I've got the rolls from the '60s, but they came with incorrect wrenches ( HTD Japan-made Metric--which so far, are my good metric wrenches) and the vinyl has hardened, thus they aren't great for daily use.
Not sure if this qualifies as a tool, but it's certainly tool-related:
I've had to use my NOCO GB40 jumper twice this week and it *****.
Replacing the battery in the parking lot of the parts store made me realize that my little road tool box is not well organized! I have full sets of metric sockets and end wrenches and I used an old bicycle 8-9-10 Y-tool and 4" Proto adjustable to change out the battery as it would take too long to completely empty then re-fill the tool box... at 20 degrees F. Maybe I can't really get away with one little tool box....
I just leave the wrenches strategically placed under the hood to make it easier for next time.Not sure if this qualifies as a tool, but it's certainly tool-related:
It's the tools that find the moving parts that bother me. WHANG! and a dimple appears in the hood--distracting while driving.I just leave the wrenches strategically placed under the hood to make it easier for next time.
If they fall/disappear, well they were obviously defective and grounds for warranty.
Just to be clear, I'm 100% kidding.![]()
To be clear, the "road box" for my Toyota Corolla is this:sub organization helps a lot. my small road kit is carried in a small tool bag. most of what's in the bag is then put in other bags or rolls. There's a wrench roll, 8-19 (and two 10s). three bags hold sockets and ratchets -- one with 1/4 metric, regular and deep, plus a ratchet, universal, and a couple extensions, one similar 3/8, plus another bag of 'oddball' sockets (sae, spark plug, torx, maybe some random others). sockets are on Ernst rails, double sided. there are a couple screwdrivers and three or four pairs of pliers (one 10" visegrip, channellock 420s, dykes). an inside pocket has a small headlamp and spare batteries. I have another small bag that holds road electrical stuff-- test light, clamp multimeter, bunch of test leads and jumpers, some fuses, pair of crimp pliers, assortment of connectors, shrink tube, butane torch.
What is in the box at the top? I can't tell if they are tweezers or what. Thanks
Yep, 10 piece tweezer set.What is in the box at the top? I can't tell if they are tweezers or what. Thanks
Damn. I remember when chainsaws came with those. I don't recall which brand had which, but some were like yours and some had the pumps in the delivery end, so you just stuck 'em into the hole in the nose of the bar and pushed.
I'm building a small subwoofer box to hide in my trunk, so I had to buy some new tools.
Ratcheting crimpers and heat shrink tubing for wire ferrules.
Digital protractor and angle gauge purchased from McMaster-Carr.
A budget friendly Skil table saw with a 10" Diablo 60T blade and a Craftsman 6 amp corded jigsaw.
