Plastic stapel repair guns
jabberwoki
puyallup wa usa
Anybody got one?
Trying " prolly in vain" to not get any chinese ****.
Was also wondering about the availability and interchangeability of the staples themselves.
J
jabberwoki
puyallup wa usa
seber
Deep East Tx.
I have one and love it. They are all made in China and all the staples are interchangeable. Mine has a pistol type handle but if I were to replace it I would get one with no handle. One thing I have found is just before you let go of the staple, give it a slight twist to bury it in the plastic.
CJM8515
i have one made by astro, works well. i use it a lot and it has served me well. i also have a HF plastic welder and q bond glue set up. with all of that i can fix most plastic anything
Dan in Pasadena
Pasadena, CA
I have one of the staple type welding repair kits. I use the stainless welding mesh more often, as I have found the repairs to be more durable.
Resurrecting this thread:
Search for "Plastic Repairs" and these plastic welders came up. This stainless welding mesh is interesting too. I assume it's metal window screen and a flat tipped soldering iron?
I was hoping to find Super Glue + baking soda repairs. I have a Keter folding work table leg that broke. The legs are aluminum but slide into a plastic sleeve that is the mounts/pivots it to the table. The plastic broke RIGHT AT the joint between sleeve and pivot portion.
Either of these metal/weld fixes looks superior to ordinary epoxy or the cyanoacrylate/baking soda fixes. Any experiences to relate?
Kurt4440
Western New York
Without seeing the broken section of your Keter work table it is hard to make a recommendation on your specific repair.
My general recommendation concerning plastic repair is to weld and use the stainless steel sheeting for reinforcement. If you have enough room to build up the weld, the repair can be stronger than the surrounding material.
I would practice on some scrap material prior to working on something of value. This kit should be helpful, and for only $15, you can learn a new skill.
Dan in Pasadena
Pasadena, CA
Thanks for the encouragement. I already ordered the $31 kit and it has some of the mesh included.
Here's the close up of the broken part. As you can see, when I hold it in position it's almost impossible to see the break. I'm thinking I'll use Super glue or epoxy to hold the two halves together. It's polypropylene plastic. Then when that dries I'll weld in the mesh or staples - which ever I can make fit best.IMG_4932.jpegIMG_4931.jpeg
zendriver
Indiana
Never paid much attention as i thought these “staples” were just st bent wire put into an old school soldering gun
Been doing my plastic repairs with a cheap pencil soldering iron and steel wool reinforcement
Now I have something elss I need to buy :lol:
seber
Deep East Tx.
Glues will not work on polypropylene.
