PugetDude
C'mon, man!Now you guys are just adding work for me to add work. I want to keep this simple. It's just to shake cans and save my arms.![]()
Style points do count also!Now you guys are just adding work for me to add work. I want to keep this simple. It's just to shake cans and save my arms.![]()
I can not believe that you are going to cheat your grandson out of the wonder of discovering the magic that is hiding inside a paint can. I still remember when I finally cut a can open to see what was really rattling around in there! Besides, he’s young, in a couple years he will be able to shake all the paint cans grandpa needs shaken!
This way I can pre-program the timer so when I put a can in the shaker and turn it on, I can walk away and know it will shake for a few minutes when it shuts off.
Great idea for a can shaker, and that bore in the base for the motor looks perfect.
Any way you can add some steampunk elements to your design? Definitely for style, but also make them functional -- your grandson will love it!![]()
Great project, Mike!
I am with you on the program and walk away, I also find my self using rattle cans a lot these days, the quality is really quite good with the right prep, temperature and technique. Plus, when I need to "shake" myself, I find myself wondering around trying to find a way to be productive during this seemingly, "non-value-add" time of the project/process.
Funny you mentioned looking for other things to do while shaking cans of paint Mike, I do the same thing, wandering around looking for something that needs to be put away or moved to another location. Anything but waste time doing NVA work.
I did a test last summer when working on my son's WJ of a longer more thorough shake of the paint can vs. the shorter version I was "actually" achieving, and the finish did vary depending on the time spend shaking so there is something to be said about more thoroughly mixing of the solids into the carrier of a longer shake interval. Even though I "thought" I was shaking the cans enough, I obviously was not.
I don't see shaking the cans as NVA because that shaking affects the quality of the finish. Seems to be a direct relationship there, poorly shaken = poor finish. Although I do see it as time that I'd rather be doing something else......
This begs the question though, what aerosol paint are people using? I used to use Krylon, have literally shot cases of it, but in the last couple of years I've been disappointed with it. Tried "Steel-It", not impressed as it didn't hold up for very long. Rustoleum seems to be hit and miss. Maybe I'm doing it wrong, but their nozzles plug up badly even when 'cleared' upside down after every use. Recently I got a can of Eastwood's "Chassis Black." Still testing it.
This doesn't surprise me at all!
I have a buddy that is basically a life long body guy, has owned shops on/off and now close to retirement works at a dealer....but, for years he has been amassing his "retirement fund" in the form of a old Honda motorcycles, and as he was restoring one years ago and I saw him painting the frame with VHT Chassis and Rollbar paint, I gave him some $hit, to which I was quickly schooled on how good that paint is due to having a built-in self etch primer and then proceeded to tell me about how long to shake, etc., That said, it is very curious how good of results you can get when the conditions and recipe are correct.
I am highly confident it will exceed expectations and I am looking forward to seeing how it turns out...you may even inspire me! I am actually typing and thinking about how I could build a stand for a sawzall, mount it under my shed roof so I can shake and walk away.....![]()
Mike,
are you building a version of Robert Cowan's Paint can shaker?
Jason
For those of you wanting a satin/matte black, look no further than John Deere Blitz Black. It's still my go to for anything less than a gloss finish when it comes to black. I keep a quart to spray out of the gun and always have a couple of aerosol cans handy.
The entire engine bay of my Z28 was sprayed with it when I did the LS swap, that was 2011'ish...when sprayed off or wiped down, it still looks as good as the day I sprayed it. The engine side of the firewall in the '49 GMC was also sprayed in BB...fantastic stuff, very durable and WILL NOT chalk.
For all other colors, depends on its intended purpose...but for general use, Rustoleum 2x has been a good performer for me.
Looks to be the stuff...
For me it isn't so much trying to be productive as it is to do an effective job of shaking the aerosol can. I actually bought the reciprocating saw shaker for three reasons:when I need to "shake" myself, I find myself wondering around trying to find a way to be productive during this seemingly, "non-value-add" time of the project/process.
mixkwik.com
I have a 90+ year old neighbor that swears by heating up his can of paint before applying. He says he uses a bucket of hot water to soak the paint can in for 10-15 minutes. Anyone else pre-heat the paint besides the hypersonic shaking of the mixing ball?
I try and put them out in the sun for 15 minutes or so. I try to rotate the can halfway through.I have a 90+ year old neighbor that swears by heating up his can of paint before applying. He says he uses a bucket of hot water to soak the paint can in for 10-15 minutes. Anyone else pre-heat the paint besides the hypersonic shaking of the mixing ball?
Wouldn't want to see him playing out of character..Uh.... I think a survey would show that all of us agree that was a necessary step.![]()
There's a right and a wrong way to do things. Counterbores for Socket Heads is the right way.Wouldn't want to see him playing out of character..
They are indeed a must.Agreed Travis, they just look more at home sunken in a hole.![]()
I believe we need some "samples" as proof. . . Snickerdoodles or Molasses.
