I have an old 'Drill press' that you put your drill motor in similar to the guide you have. I have used it in places where you would normally use a mag base drill but instead use clamps like you show. Works for aluminum and wood where a mag base will not...
Wow!
I forgot that those existed. Probably haven't seen one since the 80s.
I have one of those somewhere with a waster Craftsman 3/8 corded drill still in it. I also have a translucent Black & decker plastic one that acted as a chip catcher if you were drilling overhead. It had notches & vees to saddle irregular shaped items. I seem to remember that mine was branded Craftsman, but it is a B&D. If it wasn't so cold-I'd go out to look for them.
Am I the only one who thinks it's insane that very, very few handheld drills include any sort of reference surface or feature to keep you aligned and square to the work? It's all swoopy rubber and plastic ray gun greebling, nothing to help you eyeball a halfway straight hole.
No, you're not the only one! I like the ones that have a level bubble in them, or at least a place to put one. They seem to be hard to find, though.Am I the only one who thinks it's insane that very, very few handheld drills include any sort of reference surface or feature to keep you aligned and square to the work? It's all swoopy rubber and plastic ray gun greebling, nothing to help you eyeball a halfway straight hole.
At one time Craftsman put a bubble level in their drills but it didn’t last very long.My Dad had an even crappier version where you just strapped a drill in with hose clamps, and I suppose you just had to do your best to square up and align the drill bits.
They probably cost-cut it out, or it seemed to "homeowner" and not "pro" enough.At one time Craftsman put a bubble level in their drills but it didn’t last very long.
That's what I bought mine for. Worked great and now it accumulates dust.Seems useful for drilling into a door.
I totally have the by eye thing down.
But does it work in both directions? Plumb AND square?Bosch makes drills with angle detection. Tools come with 45 or 60 degrees, but if you get the bluetooth thing on it you can use the app to put in whatever angle you want. It has an LED light on it that is green when you're at the angle and turns off if you drift too much.
Kind of neat, but I still prefer the jigs in this thread.
It is kind of like popping a pimple in the middle of you back. You just can't do it yourself.Kinda ironic using it on a milling machine though.
