Thank you for sharing these photos--- @Beauregard gave me one of these for GJSS and I love it, but until now I didn't realize that the head detached as a stubby! Amazing!I really like the ergonomics of the Vessel ball grip ratcheting screwdriver. Specifically being able to ratchet with the palm and then being able to spin out the fastener with the thumb and index finger on the lower gripping surface all without changing grip. The ability to convert to a stubby is an added bonus. I kinda wish they made a version where the bit holder part was incorporated into the lower grip so that you could use long bits for accessing tighter spaces. I guess you could always place a longer bit in the stubby portion,
Yes I have come across that issue but it may only be on the 3/8" if I recall. You have to press the button very far deep in. There's a dimension that is slightly off. It may be fine for Tone sockets but I don't own any to check those. I use my Tone ratchet with other sockets. I do not recall that being an issue on the 1/4" model but I should probably check.
Not sure if it applies to your ratchet or not, but I've owned a couple quick release ratchets that had a hard time releasing, and in all cases, when I investigated it a bit I found the issue was caused by the center shaft of the quick release mechanism. On some ratchets, when the quick release button is pressed, the round center release shaft will noticeably stick out the end of the ratchet male square drive. If the socket or extension you are using doesn't have a deep enough female square drive broach, that quick release center shaft will bottom out in the female broach and prevent the ball bearing from fully retracting into the square drive to release the socket or extension. In some cases the issue will make the release of a socket feel sticky or erratic, and in other cases it will make it quite hard to get the attached item off of the ratchet at all, no matter how hard you press the release button with your finger. The only force you should ever have to apply to release a socket, is the force needed to compress the small internal spring and that's it.Used my mini Tone ratchet for the first time replacing some spark plugs, belt, and belt tensioner on my wife's Toyota. I have to say I'm not a fan of this ratchet. It WILL NOT easily release whatever its connected too when depressing the button. Had to switch to my trusty Tekton to complete the job, I found it that annoying.
Anyone else experience this with this particular ratchet?
Good feedback. I think I was using a 2 Tekton's extensions (short & long) and some junkie Hyper Tough flex extension. All of them were getting hung up in the ratchet, that's why I was blaming the ratchet. Come to think about it, even my Tekton 10 mill socket was difficult to remove with no extension.Not sure if it applies to your ratchet or not, but I've owned a couple quick release ratchets that had a hard time releasing, and in all cases, when I investigated it a bit I found the issue was caused by the center shaft of the quick release mechanism. On some ratchets, when the quick release button is pressed, the round center release shaft will noticeably stick out the end of the ratchet male square drive. If the socket or extension you are using doesn't have a deep enough female square drive broach, that quick release center shaft will bottom out in the female broach and prevent the ball bearing from fully retracting into the square drive to release the socket or extension. In some cases the issue will make the release of a socket feel sticky or erratic, and in other cases it will make it quite hard to get the attached item off of the ratchet at all, no matter how hard you press the release button with your finger. The only force you should ever have to apply to release a socket, is the force needed to compress the small internal spring and that's it.
Most of the ratchets I use are quick release style, and I found there are two solutions that will work to stop the problem from occurring. In my case, the issue only happened with extensions, because all my sockets have plenty of broach depth or else they have through-broached female square drives. However, I found there were 3-4 socket extensions I owned that had female broaching that was too shallow which caused issues, so I sold them off and replaced them with a different brand that had deeper female broaching. In the past I have also solved the problem for free by pressing and holding down the ratchet quick release button and then gently grinding a small amount of metal off the end of the round quick release shaft so it no longer extends as far out the male square drive when the button is pressed. The couple times I have used that technique, I didn't have to remove much metal to completely solve the problem.
What is breaking the bank for you? Basically the big 3 in Japan make sockets. KTC, Koken, Tone. I will exclude nepros(ktc premium line) as they are snap-on level prices.
All of them are In the same bracket price. Examples
KTC B3-10P 3/8 short 10 piece is going for 31$
Tone HS312 12 piece is 33$
Koken rs3400m/12 12 piece is 42$
Koken will be the most expensive but also in my opinion higher quality. Granted I don't consider a 10 to 6$ more to be a deal breaker. The priciest sets will be the long as they are in the 60s to 80$ range on all those brands. Just hop on Amazonjp and look up 3/8 sockets sets. No other brands makes Japanese sockets that I know off. So it's only those 3.
Just get, say, the KoKen and order the extra sockets to give you the extra sizes you need. Job done.Hi,
I am considering getting a made in Japan metric 3/8 inch drive deep 6 point chrome socket set up to 23mm/24mm.
Does anyone know if any of the Japanese socket manufactures make a full set up to 23 or 24 mm deep?
I looked at the KTC, Tone, Koken catalogs but it seems the Japanese sets only go to 19mm and then I would have to piecemeal order the larger sizes, which I suspect would add cost. The brand does not matter, I am only interested in made in Japan and if the durability would be equal to or better than Proto, that would be awesome. I will likely order this from Amazon Japan. Once I know a price, I am going to compare the price of a Japanese socket set to a new USA Proto 3/8 set. I would like to get the Japanese sockets to try them out as I think they would be good quality.
I have a 3/8 metric deep and shallow 6 point impact set that I use currently for most tasks. I have a set of 12 points in chrome that I use when an impact socket is to large to fit and I want to get a 3/8 deep chrome set to use that primarily instead of my impact set.
Thank you!
I notice some tools do not ship to the US. For example, the Koken 3/8 deep socket set does not ship to the USA. When I hit similiar items, it shows KTC and Tone 3/8 deep sockets ship to America.Just get, say, the KoKen and order the extra sockets to give you the extra sizes you need. Job done.
Yes, it will add to the cost, you donât get something for nothing. But with the Japanese manufacturers you donât make a huge saving by buying a set. This is another way of saying that they donât load the prices of individual tools.
Be a bit careful with KoKen though - the catalogue page you showed was âsurface driveâ sockets. You probably want the regular, which are 3300M in 3/8 drive metric, and are available up to 27mm!
Does anyone have any advice for that or recommend another place to order?
I had no idea Zoro sold KoKen. I knew HJ Epstein did per reading that on another GJ thread. I am in no hurry to get the sockets as this is a want instead of a need, so I filled out the "notify me when they are back in stock" on Zoro.Zoro is a great source for Koken. They carry most of the Koken catalog and with one of their coupons you get 20% off and free shipping. The orders I've placed with them seem to drop ship from Koken USA/Palmac.
Unfortunately japanese manufacturers don't offer up to that size in kits. Best bet is to get a set and buy the separate sizes. My top choice will be Koken, follow by KTC then TONE last. Owning multiple USA brands to included the proto, I can safely say they are on par. The difference is in the finish. What's your preference? I love my proto, nice chrome and the sizes available in kit up to 32mm. But I don't use sizes from 24 and above so they just sit in the boxHi,
I have a 3/8 metric deep and shallow 6 point impact set that I use currently for most tasks. I have a set of 3/8 shallow 12 points in chrome that I use when an impact socket is to large to fit and I want to get a 3/8 deep chrome set to use primarily instead of my impact set.
Thank you!
Once you find the KOKEN Socket set number search for the vendor that will offer the best price. I have purchased directly from KOKEN a couple of times because they had the best price And shipping.I had no idea Zoro sold KoKen. I knew HJ Epstein did per reading that on another GJ thread. I am in no hurry to get the sockets as this is a want instead of a need, so I filled out the "notify me when they are back in stock" on Zoro.
Great tip on Zoro selling KoKen!
Unfortunately japanese manufacturers don't offer up to that size in kits. Best bet is to get a set and buy the separate sizes. My top choice will be Koken, follow by KTC then TONE last. Owning multiple USA brands to included the proto, I can safely say they are on par. The difference is in the finish. What's your preference? I love my proto, nice chrome and the sizes available in kit up to 32mm. But I don't use sizes from 24 and above so they just sit in the box.
I have the deep Z 6 point from KOKEN, I love their sockets.
Koken 3/8 drive, deep, 6 point | Part Number | Zoro | DRPD | Amazon Japan |
8mm-19mm Set | RS3300M/12 | $115 | $105 | No U.S. shipping |
20 | 3300M-20 | N/A | $15.10 | No U.S. shipping |
21 | 3300M-21 | N/A | $15.10 | No U.S. shipping |
22 | 3300M-22 | N/A | $15.65 | No U.S. shipping |
23 | 3300M-23 | N/A | $16.40 | No U.S. shipping |
24 | 3300M-24 | N/A | $17.30 | No U.S. shipping |
$184.55 total |
Thank you!As a heads up Koken USA is doing a 25% Valentine's/Presidents day sale.
Yes, I purchased from KOKEN USA. If I recall they donât charge shipping, but you may want to confirm.I will likely get Koken for the Metric 3/8 deeps from DRPD after doing an internet search for the part numbers. I just bought a set of Proto fractionals in 3/8 deep. I am happy with the Proto fractional sizes but want to try to he Kokens for the metric 3/8 chrome deep set.
Will do!
When you say you have "purchases directly from Koken a couple of times", do you mean the Koken USA website?
Koken
3/8 drive, deep, 6 point Part Number Zoro DRPD Amazon Japan 8mm-19mm Set RS3300M/12 $115 $105 No U.S. shipping 20 3300M-20 N/A $15.10 No U.S. shipping 21 3300M-21 N/A $15.10 No U.S. shipping 22 3300M-22 N/A $15.65 No U.S. shipping 23 3300M-23 N/A $16.40 No U.S. shipping 24 3300M-24 N/A $17.30 No U.S. shipping $184.55 total
Price comparable to Proto 6mm-23mm set at $195
Sheesh, I gotta up my game - all I ordered was a measly 16mm Z-Series Clip Spark Plug SocketShipping is free. I am waiting for my 3d set of sockets
⌠garagejournal anonymous meetings are now held on Wednesdays. : )
Thank you for confirming!Yes, I purchased from KOKEN USA. If I recall they donât charge shipping, but you may want to confirm.
Good to know, I may have to attend the Garage Journal Anonymous meetings! HahahaShipping is free. I am waiting for my 3d set of sockets
See you Wednesday...Shipping is free. I am waiting for my 3d set of sockets
Iâll bring the beer and the tool catalogsâŚSee you Wednesday...
I'd like to know the black and red bit driver handle on the first picture, 2nd left.Been gathering a bunch of stuff, lots of surprises and a few disappointments. Need to take individual Fotos to show you all.
867-5309I'd like to know the black and red bit driver handle on the first picture, 2nd left.
All I can see is just Vessel brand, can not notice the part number.
Is it have a quick release for the bit?
Also if it possible, I'd like to know phone number of the ******* the photograph on 2nd picture![]()
Aaa, that's the newish vessel bit/nut T driver. Imo one of my disappointments, it's very weak. It also has weak bit retention, the bit just fall off with use all the time. It's very frustrating and annoying. It's a very nice design "look wise"I'd like to know the black and red bit driver handle on the first picture, 2nd left.
Great feedback, thank you.Aaa, that's the newish vessel bit/nut T driver. Imo one of my disappointments, it's very weak. It also has weak bit retention, the bit just fall off with use all the time. It's very frustrating and annoying. It's a very nice design "look wise"
Part number # 400PD2
I prefer the Anex action grip. More traditional 1/4 bit design. Feels more solid due to its inner metal construction. It's not as nice looking as the vessel.
Part number # 3350
That's my wife, currently not accepting offers of any kind.
Was it all in stock?I took advantage of the KokenUSA sale this past weekend but havenât heard anything since. Is it normal for there to be a delay in shipping with this retailer?
In my experience, they are slow to ship.I took advantage of the KokenUSA sale this past weekend but havenât heard anything since. Is it normal for there to be a delay in shipping with this retailer?
The 1/4â spinner was not in stock but all the rest were. I sent an e-mail asking them to send the items as available instead of waiting for the OOS item (to which I didnât receive a response).Was it all in stock?
I placed my out-of-stock order on 2/15 (15/2 if we wanna get real Japanese) and got a processing notification on the 18th.
Nothing since. I still have no idea when it will actually ship, but for this particular order, I'm not in any rush.
