Wow!! Having to take suspension apart to change spark plugs and spark plugs didn't last long back then. Thought it was only new cars that had crazy clearance problems!!Those and most GM cars used 13/16 bolts through the frame and control arm shaft. Most of the bolts were wedged with knurling into the frame. If you had to replace the control arm bushings or the arm itself you had to remove those bolts. The knurling on those bolts then would not keep the bolts from turning and had to be held since the nuts them self were lock nuts that would turn the un-staked bolts. That wrench would make it a one man job instead of two man. On some of those cars that control arm had to be removed to actually change the spark plugs as there was no clearance under the air conditioner otherwise. The best way to remove the bolts was with socket, 24 inch extension and breaker bar, about the only other way was to remove the engine.
On Vega V8's you had to pull engine to replace all of them. And was recommended every 6,000 miles with leaded gas. . My parents had a 65 Ford that the right front fender had to come off to change heater hoses. Cars were terrible to work on from day one I think. During the depression my granddad bought a car and had 34 flats on the way home, they had to cut their shoes up to get pieces to put in the tire to protect what was left of the tube. See through tire, but you carried all the tools, materials and pump to fix them just about daily with nobody being able to afford tires during the depression in rural TN.Wow!! Having to take suspension apart to change spark plugs and spark plugs didn't last long back then. Thought it was only new cars that had crazy clearance problems!!
Just gotta know how to choose your battles!On Vega V8's you had to pull engine to replace all of them. And was recommended every 6,000 miles with leaded gas. . My parents had a 65 Ford that the right front fender had to come off to change heater hoses. Cars were terrible to work on from day one I think. During the depression my granddad bought a car and had 34 flats on the way home, they had to cut their shoes up to get pieces to put in the tire to protect what was left of the tube. See through tire, but you carried all the tools, materials and pump to fix them just about daily with nobody being able to afford tires during the depression in rural TN.
My buddy had a Dodge truck with a monster straight 6, and you could stand next to the engine to work on it. Which was good, he was too short to reach it from outside the fenders, barely from the grille side.My '62 Dodge D100 w/318 had enough room in the engine compartment to bolt a large carry toolbox to the top of one wheel well, half close the hood and walk three-quarters of the way around the engine. Nice when rebuilding the heads in a campground in Moab in an October blizzard. One time I was glad of the heat an old incandescent drop light threw off.
5' 6" myself. Not only could you stand to either side of the engine, but pass in front of the radiator (I was slimmer yeah all those years ago)! It was only the firewall that prevented 360 access. This was Chrysler's "baby V8", so shorter than a "monster straight six". IIRC, the six-cylinder version for my truck was the slant-six--another legendary engine.My buddy had a Dodge truck with a monster straight 6, and you could stand next to the engine to work on it. Which was good, he was too short to reach it from outside the fenders, barely from the grille side.
Chevy Vegas never came from the factory with any kind of V8, only 4-cylinder engines.
You may be confusing them with the Chevy Monza, which DID come with a V8, and spark plug changes on those were...stressful, although you only had to unbolt one engine mount and lift one side of the engine.
Still a pain in the ***.
And they stopped using leaded gas in the US by 1975, which is the year of the first Monza.
Monzas never required leaded gas, and Chevy never recommended spark plug changes every 6000 miles for them.
But I get your drift.![]()
Granted it was still around; leaded gasoline wasn't completely phased out in the US until 1995 or 96.Yes, new cars were designed to run on unleaded gasoline in 1975 because of catalytic convertors, but leaded gas was still around in the 1980s, even in the NYC area.
It hasn't been fully phased out. Light aircraft fuel is still nearly all leaded.Granted it was still around; leaded gasoline wasn't completely phased out in the US until 1995 or 96.
But by the end of the 70s all new cars were required to run on unleaded fuel only. A V8 262 Monza in 1975 would have required unleaded fuel only; in fact, it would have been unlawful to try to put leaded fuel in it.
The notion that GM would officially recommend/require leaded fuel for a mid-70 V8 is just silly.
Which cars?On some of those cars that control arm had to be removed to actually change the spark plugs as there was no clearance under the air conditioner otherwise. The best way to remove the bolts was with socket, 24 inch extension and breaker bar, about the only other way was to remove the engine.
