bad_idea
I am looking for a laser level for home use. Something I can use in the shop or in the house. What do you all recommend?
Short answer: Yes they work. Longer answer: I use lasers DAILY in my profession as an interior carpenter. The cheap lasers while low on aesthetics are actually well built, have features that my expensive lasers do not have (like a remote control) and a 4th axis that is only 3/4" off the ground. My $800 Hilti will only get to about 5" off the ground which when working to a base that is 4" doesn't do much. Most all of the Class 2 lasers have an accuracy of +/- 1/8" at 33 ft. The Heupar electronic laser target makes these lasers useful outdoors and adds about $50 to your costs.Sub'd to see more....
I have a Dewalt self leveling 2-axis, green, and it's been good enough but I have definitely yearned that 3rd axis a few times. I have seen a lot of recommendations for the cheap/amazon 3-axis for prices that seem too low to be real (like $40-cheap). I wonder if the laser quality is the same, if that's a thing(?) Are all lasers of this grade (class 2) the same in the daylight, thickness at distance, etc?
60' is a lot to ask of a pendulum self-leveling laser level. If I put my $25 laser level in the center of a 20' room, the beam offset will be within the thickness of a heavy pencil line, but that's only really 10' from the level.I bought a upper tier huepar and for building work have been very disappointed in it's ability to self level. Seems to be within factory spec or right on the line, so maybe I was asking too much. But for leveling on a 60 ft wall it has about half an inch of variance depending on where I set up my laser. Seems to be sensitive to absolute level of the device. Stated spec is +-3mm/10m. So 6mm off over 10m which is not good enough for a lot of trades. Probably fine for hanging a cabinet if set on a level base.
I'm in the market for a 3 axis version that will project a beam on the walls and ceiling.
I keep seeing new DeWalts on eBay that are less than half a new one anywhere else. These are counterfeits I'm assuming. This is an example: https://www.ebay.com/itm/286167223891?_trkparms=amclksrc=ITM&aid=1110006&algo=HOMESPLICE.SIM&ao=1&asc=279093&meid=9468fae4a80340389b198bee80c1f172&pid=101875&rk=4&rkt=4&sd=167182690124&itm=286167223891&pmt=1&noa=0&pg=2332490&algv=SimVIDwebV3WithCPCExpansionEmbeddingSearchQuerySemanticBroadMatchSingularityRecall&brand=DEWALT&_trksid=p2332490.c101875.m1851&itmprp=cksum:2861672238919468fae4a80340389b198bee80c1f172|enc:AQAKAAABQOqalcCsb07ituDYLOrUrH2eG1DBUcAU1siB%2B881ennut1KqikNJ--C2JmJJYbnGBSq9s1cAaLR3u1P2GFHP6cOkMtiQrPwhnArZTi0NFnCkYNs9wPMPnRY0lLYAH0ZUZHC0PUU1fHypd4iQtUvfzVENcH3Rth76QZkQXmR8D04L1j1Q50yq1f5RLI6HxcWPxtwbLBnC%2F7gGxyyrRNblT4Ikk0Ip0vD2RUZHdZFMQkWWfIhXbhdbLrDyOHRABM00knHlTBM0NAob8lHjQDA%2BB2ulOnfreSTtDjsFOgdj4tFd5uEUBNhtb%2FBUZ712RMKzpMqwUrJDR9eVh%2FwdXr0cQq%2F1puu9jwcAvPc64wl7Qj9SlwwGPNR5Cyk4IO6c3Z2dlseVHMxd9nTyuGqws7uLXtGDQXrb9WshPak3pwLmOf91|ampidL_CLK|clp:2332490&itmmeta=01JN5AR88W4NTV0F7AVYTFQTEN This one is almost $500 on Amazon.
Has anyone purchased one of these?
Just to project a line. Most cross line lasers do this now. Just turn them on with the remote or buttons, but don't slide the switch the unlocks the gimbals....Also the ability to set pitch out of level to match existing construction can be a useful feature...
I can override my rotary self-leveling with the push of a button +/-. I can fine tune it and dial it in to my desired pitch without touching the unit. I understand cross line gimbals can be locked but are you saying some of these non-rotaries will do what I stated above?Just to project a line. Most cross line lasers do this now. Just turn them on with the remote or buttons, but don't slide the switch the unlocks the gimbals.
