6 gauge wire. Usa made vs ?
alex2929
I need 350 feet of 6 gauge wire. I think I am about going to have to buy a 500 ft roll. When looking at Lowe’s I noticed they had some made in the USA and some not. Any thoughts?
mm08822
The cheaper version is only rated as thhn at least accordingly to Lowes description. If correct, then it can't be used outside or underground.
The more expensive is rated as thhn/thwn-2 which can be used outside and underground in conduit.
mm08822
I can't find anything on southwire website for anything other than thhn/thwn-2.
So yeah, Lowes description is lacking....not the first time and not the last time. HD is no better.
Consider supply house if only 350' is what is needed.
Are these 2 seperate recepts?
cgrutt
Appears to be the same wire. I'd venture to guess somebody made a pricing error or perhaps they have excess inventory of blue and they're trying to move it. My lowes shows 195 units of black available to ship and 5000+ of blue. The price of the black seems closer to what other vendors sell it at. I'd buy the blue at that price if you could make it work.
PCustoms
VT
Can blue be used?
cgrutt
Can blue be used?
IDK, maybe that's why its so cheap. I've taped the ends of wire before with the color it's supposed to be, for example taped white wire black when connected to switch. No idea if that's permitted or not.
sparky 1971
Central Iowa
Already been answered, but thanks. For some reason I thought there were some restrictions due to 3 phase
There is the unwritten rule that 208 is black, red, blue and 480 is brown, orange, yellow but that isn't in the real code book. The only other requirement that I can think of is that the high leg of a 240 delta has to be orange as well as the "B" phase.
If I'm in a building that doesn't have 480, I use all the colors for 120/208 three phase or 120/240 single phase. I do try to stay away from pink because it sometimes looks like red to me.
mm08822
That 5000+ inventory could be the whole answer for the sale price!
finn
The UP, God's country
I found the best price for UF was on eBay or a vendor in southern Illinois. I needed a non standard length and they were the closest to fulfilling my needs, and cheaper than the box stores.
I think they dealt with spool cutoffs, so non standard lengths.
I suspect they would also carry what you need.
