Dollar Bill
I have an old Craftsman 1/4 HP split phase induction motor (113-12100) that I float between several belt driven buffer/grinders and would like to change the rotation by using a DPDT switch with center off. As the motor is portable, the DPDT is more desirable than the much larger drum switch. The motor has a yellow wire and blue wire and a terminal board with poles labeled 1 and 4. The blue and yellow leads can be swapped between poles to change rotation. Is what I'm proposing even plausible and if so, a simple wiring sketch would be greatly appreciated? Thank you for any help you can provide.
Terminal Box and DPDT Switch (Terminals Are Not Marked)
