RickP330
KMScott,RickP
I have seen early Parker meatballs having the threaded steel spindle cast inside the meatball. I have some pics while repairing a Reed 109 meatball that was casted. Also see the Reed 106 handle end with the steel handle end cast inside the cast ball ends. The spindle on the Reed had a flat teardrop shaped so they would not spin when used .
Then along the way a weld was done trying to weld steel to cast. Check to see if your meatball is cast before talking to your welder. Most vise makers friction welded the spindle to the meatball when both are steel. I’m sure your meatball will hold up for many more years even if it’s loose.
Thank you so much for that. That is EXACTLY what I was looking for and hoping what the situation was (and why I love GJ). As an engineer I have a saying that my favorite solution is to do nothing.
I agree with you; I'll just use it as is. And if it breaks, I'll deal with it then.
I suspect you are right, the end meatball may be cast, but there is what looks to be a turning center machined into end. I'll study it a little more tonight. Thanks again.
Rick
