There are portable hand held power shears and nibblers.
14 gauge is one of the standard “medium” gauges the shears can handle in mild steel.
The shears and nibblers can be run against a straight edge
Some types, such as the strip cut shears can even have a parallel fence attached to the shear.
Nibblers and strip cut shears remove material, do there is a certain amount of waste.
There are also power shears with only two blades, that don’t remove a sacrificial material kerf, but those are sometimes limited by how wide a strip can be cut, since they have to bend material up and down on either side while cutting, and this type of shear is more likely to deform material.
For heavier material, 10 gauge mild steel is usually the next step up in thickness from 14 gauge.
www.dracotools.com
Electric shears from TRUMPF for the cutting of mild steel and stainless steel. For fast, precise, burr-free cutting.
www.trumpf.com
This makes nibbling worry-free: spark and distortion-free with a perfect view of the work surface thanks to the chips falling down. Even when nibbling a wide variety of materials up to 5 mm thick, FEIN nibblers remain maneuverable with their compact dimensions. Changing the working direction is...
fein.com
When cutting becomes a curve sport: With FEIN plate shears, even tight radii are no problem. Efficient, precise and trouble-free in any position - even overhead - for fast processing of large surfaces. And all without chip formation and material loss at top speed. This is where performance and...
fein.com
Chips can be tricky. With FEIN slitting shears, only a spiral chip forms. The open cutting head also allows a clear view of the cutting line - for maximum precision and cutting quality. The material remains undistorted and free of scratches. This gives you particularly clean results when cutting...
fein.com
Kett Tool Company
kett-tool.com
Kett is the major US manufacturer of similar tools, although they don't offer a parallel guide system.
Bosch is another good example.
Nowadays, circular saws for metal would also be a good option for long straight cuts.
