Garage door window covering
stricht8
What can I cover my garage door windows with so as to get light in but keep prying eyes out? I was thinking about spraying some of that frosted glass stuff on the windows. Does that hold up against moisture and condensation?
7echo
coastal Georgia
I cut some frosted plexi to set in the window. Works great and is easy to do, as well as being easy to remove when needed.
stricht8
How did you affix it to the window so it doesn't fall out when the overhead door opens.
stricht8
Actually, I could screw it to the wooden part of the door. I'm starting to like that idea.
urgti
wayzata minnesota
They make frosted glass film you apply like window tint. I put this in my bathroom on the lower portion of my double hung window.
Greatbear
Columbia/Fulton, MD
I use the prismatic diffuser plexi used for drop-in fluorescent lighting. It's easy to cut and pretty cheap. It can be held in place with small velcro pads on the corners that will allow you to remove the pieces for cleaning. It does not block light from coming in, and actually helps scatter it around the shop. It also totally obscures the contents of the building.
PCO6
Newmarket, Ontario
This isn't perfect but it works well for me. I cover my garage door windows from the inside with four 1/4" masonite panels that are white on the inside and black on the outside. They are up at all times when I am not in the garage. They are down when I want natural light during the day and up at night when I am working in the garage. From the outside, you can not see that the garage lights are on when I am working inside at night. The panels fit into a plastic lattice slot along the top edge and are fastened with velcro along the bottom edge. It takes about 30 seconds to remove or install all 4 panels - no tools involved.
PCO6
Newmarket, Ontario
^^^ Here are the materials I used. The total cost was about $25 so it was a pretty inexpensive solution.
johnny
LI NY
I had this made up, you can see in if you put your face up to the window, you can see out with no issues.
Munich77
Silver Spring, MD
That stuff works great, is cheap and easy to apply. I used it years ago at my parent's place to cover up a glass window.
DIC
I used the frosted film .....Holds up good ...Its been there about 25 years
