I know right?? But, it's actually a customer ski. Going all brand new with fresh overbore, new carb kits, pump attention, and a few other things is still WAYY cheaper than a new 'DOO.As someone that has looked into SkiDoo crankshafts.... I'm sorry for your wallet :O
Yea. Very true. I've decided to keep my 800 skidoo and add an 850 to my trailer. Between the 800 parts prices and the challenge to find the parts, it's worth me getting a newer "used" snowmobile.I know right?? But, it's actually a customer ski. Going all brand new with fresh overbore, new carb kits, pump attention, and a few other things is still WAYY cheaper than a new 'DOO.
I have further secured it with steel wire. We shall see how well that cheap dolly holds up. I tightened all of the wheels prior to everything else.You'll be bolting it. Compressors like to walk.
Did some chain sharpening at work last week. No cleaning or oiling for these. Guys here like to do almost as much trenching and they do tree cutting. These were mostly the very small Stihl 1/4" pitch pole saw chains.I had a stack of chains to sharpen so I got to work cleaning them. A strong pour of Simple Green and a good hard brush to clean the crud off along with a super custom chain washing board make short work of this mundane task.
Once they’re sharp I soak them in a pail with some light penetrating oil, 2-stroke oil and some 0w-20 for a few hours. I hang them to drip dry and stick them in a ziplock the next day labeled with size and grind specs.
Toggle universal switch, or just a blade style.Glued the second side pieces together.
Drilled the first set of legs for dowels, glued and clamped.
Finished up the upgrades to a couple of wren houses.
Dad made these years ago. They got new perches, a coat of paint, and the left one got a shingle to cover up what’s left of the plywood roof.
Then started surgery on my shop vac.
The power switch has failed in the “on” position.
It looks like a standard rocker switch with that little paddle thing added on for the giant red buttons. Going to try to track down a replacement, first, before hacking something else in to make it work again.
Impressive cleaning skills there Josh!Finished another Weber restoration. Newer one this time Genesis ii S-345. Did a full breakdown repaint with black high temp paint on the metal parts and black high temp plastic paint on the plastic parts for a full color change. Wire wheeled out the cookbox and lid end caps and center piece. Added all new 304 SS parts in the cookbox.
Thank you Larry. I enjoy itImpressive cleaning skills there Josh!
I’m interested in any cool sound and video cards you pull.Took the Miata out for a drive. Came home and washed it and did a quick interior wipe down with some 303 protectant. I truly hate washing cars.
Started disassembling a couple of old desktop computers. The newer one being from 2003. Keeping the fans and power supply's, recycling the boards at work, rest goes in the garbage.
What paint do you use? I had mine blasted and painted several years back but turns out the guy must have used some cheap paint and applied a thin coat. I need to replace the boards so considering cleaning/sanding/painting when I do. Would appreciate pointers on how you did yours.Plugging away at the trailer rehab. Got it all painted, got the axle and suspension in plus other misc. parts. Started fitting the deck boards then once they were good i coated them with some diesel/oil mix. Next up is final install of the boards, install the lights, a little touchup paint and new tires.
For now I have it zip tied on, should it misbehave I will drill and hard mount.
Made a real mess Saturday in the garage
I wouldn't know what they were when I pulled them. I can post some pics of various boards when I have them all out if you like. I dont know diddley about computer insides.I’m interested in any cool sound and video cards you pull.
What happens in the shop stays in the shop.- Mounted (2) fire extinguishers in the shop
I need to do that! Spring is right around the corner and have several downed trees that will be ready for bucking and splittingI had a stack of chains to sharpen so I got to work cleaning them. A strong pour of Simple Green and a good hard brush to clean the crud off along with a super custom chain washing board make short work of this mundane task.
I usually wait until I have a bunch to do then tear through them all at once. A buddy dropped off a couple to sharpen and I did the five that were hanging of my own as well. I really enjoy sharpening chains. It’s easy work and makes me smile when a different grind I tried out works out for the better.I need to do that! Spring is right around the corner and have several downed trees that will be ready for bucking and splitting
yeah, I think I have 2/3 for each of my 3 saws hanging in the shop. Its nice to have several so if you have a long weekend of cutting, you can just keep going....I usually wait until I have a bunch to do then tear through them all at once. A buddy dropped off a couple to sharpen and I did the five that were hanging of my own as well. I really enjoy sharpening chains. It’s easy work and makes me smile when a different grind I tried out works out for the better.
It will outlast the vacuum.
My garage air compressor power switch left the chat long ago, since it has a regulator I plug it in, when finished with work I just unplug from the extension cord. Switch is bypassed![]()
The fishing rod holders did not work well. Not enough grip on the coaming lip and they kept popping off. I'll need to design and 3d print something.
Half off is a pretty good deal.I have an irrational desire to fix things if possible.
ShopVac doesn’t have parts, but they did offer me 1/2 off buying a new vacuum. That doesn’t appeal.
A replacement rocker switch from mouser.com is about a buck. Will need minor modification.
I was thinking maybe gluing on some thick foam pads.I'm thinking custom "pads" on the clamp in particular for the screw to grip the rail corner inside on two surfaces, plusr the outside to follow the contoure of the rail.
