thetruck454
- Joined
- Apr 7, 2013
- Messages
- 101
I'm building a unistrut hoist and hanging it from my trussed garage roof. It will be used to work on power sports, like suspending a motorcycle when replacing forks/shocks or to lift the back end of a snowmobile up when taking out the rear skid. I know it's not favorable to hang weight from the bottom cord of a truss, I climbed up there plenty of times when I was wiring and insulating. That's placing a good 230lbs concentrated on a single spot and didn't have any issues nor did it flex enough to crack the sheetrock below.
If I take 10' P1001 unistrut and span over the bottom cord of 4-5 trusses, then I use 3/8 rod spaced every 2' down through the sheetrock to another 10' P1001 inside the garage. I would then have my trolley hoist hang front that. I would think it would be very rigid and distribute any weight on the lower set of P1001 up through the 3/8 rod and across the P1001 that's spanning over the bottom cord of multiple trusses no matter where the trolley hoist is. I was even thinking of taking a 2x4 and connecting the bottom cord to the top cord right next to where I span them with the P1001.
P1001 has a uniform beam load of 3130lbs at 2' span which is the spacing I'll have the 3/8 rod. Now take 50% since I'll be point loading with the trolley and that's 1565lbs. That weight is more than any Snowmobile/motorcycle/ATV weights entirely. I would think I am not riding on the edge of safety?
