reader2580
I have a solar ground mount rack made out of hot dip galvanized steel. The manufacturer supplies special C-profile nuts they custom make. They are galvanized, but not sure if they are hot dip galvanized.
The recommendation is to use stainless socket cap screws with these galvanized nuts. The problem is the stainless bolts gall/seize inside the galvanized nuts. I need to remove the solar panels to replace with upgraded panels, but I know most of the socket head bolts will be seized. The manufacturer is getting me new nuts, but this is the last time as they quit making solar racks. How do I prevent the galling/seizing so I can get the bolts out of the nuts next time. They did say that flash galvanized bolts/screws could be used, but no idea how to get those.
This is the nut.
This is the nut.
