Mitrelock bits
Lumpy102
Ontario Canada
I have had large and small mitre lock bits for several years, and haven't used them except for a few times when they were new, and would like to use the small one on an upcoming project. I remember having all kinds of issues getting them set right, There's a balance between height and protrusion from the fence. Does anyone have a method or can point me towards a website that explains it well?
Thanks
LeonardY
Southern California
Thanks
Youtube.
Here's the Lee Valley instructions for the locking miter bits.
CMT's
The setup is the same for any brand.
Ohio Andy
Columbus, Ohio
Typically the set up is tricky because you need the perfect but height and fence distance.
I bought the micro jig version because it has a "flat" on the bit at the center line. Micro jig audio sells the "fit finder" that auto magically finds the half thickness that you then use to set the bit height.
Next I lay a straight edge on the board and set the fence distance so that the straight edge just kisses the miter bit.
I generally have a perfect fit every time. I choose the system because I thought it would have the easiest setup regardless of board thickness.
Firebrick43
West central Indiana
That made absolutely no sense until you see the video
