Lousy Lumber
wbrian63
Houston, TX
We're working on a project to finish out the space that used to house my workshop. The deal is the landlord orders the materials to spec, and we do the work.
The order was large enough to make it easier to have it delivered. He purchased material from a local lumber yard. Knowing that a for-delivery order is going to be picked by the lumber yard staff, I asked him to order 15% extra on all the dimensional lumber and make sure he could return what we didn't use.
I should have told him to order 50% extra.
I requested 72 2x4-8' stud #2yp, and 35 2x4-10' stud #2yp. With the 15% overage, that meant 82 8-footers and 40 10-footers.
As soon as the banding was removed from the 8' 2x4's, I knew we were in trouble. Banded lumber is going to have some spring when released from the bands, but it shouldn't fly apart...
We have 21 8-footers that are going back as unusable (25%), and 27 10-footers (67%). The only reason why the reject % isn't higher with the 8-foot sticks is we were able to use some of the less-deformed units cut down to make blocks and shorter studs where required.
For the life of me, I can't understand how someone can even attempt to sell the **** we received. This is stud-grade material, supposedly. That means (to me), it should be able to be used as a stud...
I know the trick about making a diagonal cut in a 2x4 and running a screw into the edge of the board bridging the cut to pull the stud into alignment. However, you can only safely do this in a minority of the boards in a structural wall. (None of these walls are structural.) Some of this **** would be bad enough that a 12' wall would require straightening of 75% of the sticks.
Stud grade means exact length. 8' should be 96 inches +/- 1/16". 10' should be 120 inches +/- 1/16". When checked, the lengths varied somewhat, but not enough to matter. However, on a single board, what you got for length depended on where you put the hook and where you pulled your line. I don't think there was a single board that had a close-to-perfect 90-degree cut on the end...
The amount of deformity of the material is truly tragic.
About 6 8' 2x4's had a 1" bow along the edge. Turn it edge-on to the floor and you could almost slide another 2x4 underneath at the peak of the bow - WTF??? Some of those bows occurred in the last 3 feet of the stick...
Many many of the 8' 2x4's had noticeable bow along the face. This is still usable for building walls, so long as the edge is true. If the board winds up at the edge of a sheet, you just pull it into line as you fasten the sheet. If it's mid-span, who cares, other that the deviation in the lumber isn't structurally sound, and makes it hard to find the stud once the sheathing is up, since the center-to-center dimensions aren't accurate.
I saw a few that had every possible flaw contained in one board: excessive wane - less than 3/4" usable edge for nailing, bow on both face and edge in excess of 1/2", twist enough to make it impossible to get a flat nailing face for the sheathing.
There were a few that looked straight along the edge and were usable, if you didn't mind the fact that the end of the board finished 1" to the left of where the start of the board was. I'm talking about an "S" shaped bend - to the left 1", the back to the right 1", so the two faces of the board are parallel, just offset...
On many boards, the difference in density between the spring and summer growth rings was dramatic. Trying to drive a screw through a summer ring in the face almost required a pilot drill, or a hammer to get the screw started. Building walls and attempting to attach a stud to a sole or cap plate in the proper position as marked was sometimes an exercise in futility. How can a board move 1/8" laterally when you drive a screw??? As you pull measurements from one stud to get the next placement, 1/8" errors can quickly add up to major misalignment. Of course, I make my measurements for an entire sole-plate-worth of studs, then transfer those marks to the cap plate. However, if the last stud, once installed, is 1/8" to the right of where it should have been, if I use that stud to pull the marks for the next sole plate, all of the studs in that plate will be 1/8" to the right of where they should be. Have that same problem again in the new wall, and the 3rd wall in the series will have all the studs 1/4" off of where they should be...
There were some that had so many knots right at the end that you couldn't drive a nail or screw without shattering the end of the board.
We spent over an hour just culling the lumber so we could work. We divided the 8' material into 3 stacks - usable, 2nd quality (good for shorter lengths and blocking) and **** (barely good enough for firewood).
When I go to the lumber yard, if they won't let me pick my lumber, I go elsewhere. However, recently, it's getting hard to find enough usable lumber in a unit. I recently culled thru nearly 100 2x4's at a local Home Depot before I found 30 that were usable as-is. Even then, a few went banana on me once left alone at the shop. Now, when I buy large counts of 2x4's, I stack them in a bundle at the shop and put a couple of ratcheting straps around them until I'm ready to use them.
I've yet to see finger-jointed studs here in TX. I've seen some examples of it, and I frankly can't wait. The solid dimensional lumber available today, regardless of price or grade, is ****. It's gotten bad enough that if I know I need near perfect lumber, I buy much larger than I need and mill it myself. A lot of the larger boards (2x8 sometimes, and 2x10/2x12) are actually quarter-sawn and can be ripped down into very stable smaller units. You just pay a premium for the larger material.
End of Monday rant...
bgott
Houston, TX.
I used to buy used lumber for my rental units. It was all new lumber that had been used for staging and bracing and such on construction sites. A lot of it hadn't been used. The clean-up crews would load the wood up and haul it home to sell out of their yards. $1 for a 12' 2x4 ain't a bad price. There was a lot of finger jointed lumber in those piles. I have no idea where they were getting it, if you look around you should be able to find the sellers.If you don't mind spending the money you can buy kiln dried lumber. They start out with a better grade of wood before they dry it so you get some nice boards. They use kiln dried lumber in mobile homes, the way they build them and with the time constraints involved they don't have the time to jack with crappy lumber.
Falcon67
Merkel, TX
Agree. My grandfather would be sick if he saw the stuff we had to work with these days. I may be building a new garage soon and this is a scary deal. I would most likely go to one of the older yards in town for a bulk order than to HD. I've seen some decent 2xs at HD lately, but that is unusual. Heaven forbid you should be trimming out your house (3/4 done) with 1x lumber - I'm having to rip down almost everything to get usable pieces. Gaak!!!
drmoonshine
Oxnard, California
I'm sorry about the lousy lumber but their are two that should know about this and on is you landlord. Tell him that you need better wood and also give a call to the yard's manager.
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
They probably just loaded your order out of the reject pile at the yard. A one time bulk buy without a good possibility of repeat business is asking for a load of ****.
If you want good lumber steal some from a government jobsite. I have seen government workers use absolutely straight & clear dimensional lumber for concrete forms. The kind of lumber that normal people have not seen for 30 years.
OccupantRJ
Eastern North Carolina
I buy my materials only as fast as I can nail it up, it has gotten so bad. I handpick every piece about 7 pm at Lowes for the next day. The established lumber yard here has worse wood than Lowes.
Brew62
I used to buy my good lumber at Carters and if I needed just a few boards I would get them at Lowe's, since it was a bit more convenient. The Carter's in my area went out of business so I'm stuck buying everything at Lowe's which is mostly ****. You have to sort through a ton of boards just to find a few that will work, and you better use them fast before they twist.
If you want to build a round barn or a Dr. Seuss house then they have the right lumber for that.
I think a lot of it has to do with how fast they grow and harvest the trees these days and the way they are cut and dried.
adam728
I just helped a buddy with a project this weekend, he had 22 treated 4x4's. I believe we picked 9 straight ones out of the pile, and used 5 other mildly warped/twisted pieces to finish up. The rest were horrible. One piece looked like a freaking bannana as he carried it across the yard. Set it on the concrete and it was up about 4 inches in the center with both ends on the ground. Good stuff.
Bull
It gets discouraging, having to spend so much time in the lumber piles at Home Depot or Lowes, sighting everything and trying to find the straight(er) pieces. I just wanted 10 2x4x8s the other day, and it took me a good fifteen minutes to find ten decent ones. My wife knows how to pick lumber, but she must have been in a hurry a few weeks ago. Came back with some 2x4s that I needed to pad out a wall. A couple looked like Twizzlers, twisting this way and that. I didn't want to have to stop working to go back to the store, so I used a couple of them. I regret that now. They just don't sit right, and I don't know these tricks about making diagonal cuts and all that.
mmhouse
Desert Southwest
You say your ordered #2 grade lumber. Typically studs are Stud grade, not #2. Also, usually what yards carry is #2 & better, not just #2. #2 would be a lower grade than #2 & better for pretty obvious reasons. I wonder if the yard picked out #2 for you? Unlikely but possible. What do the grade stamps on the individual sticks of lumber say? Are there any in there marked #1 or Select?
Also, if you want precut studs then that's what you need to order...precut studs which will as I said typically be Stud grade. If you order #2 (or #2 & Btr) you'll get a little extra length on your boards. Were your studs marked Stud or #2?
That said, it sounds like the stuff you got was pretty bad. There are yards that care about the quality of the material they sell and will order higher quality or from mills that they know sell better material. You may want to look around your area for such a yard in the future (if there are others available). They certainly won't be the cheapest though and that's probably what your landlord is looking for since he isn't working with the stuff.
FWIW, and I know this wasn't the problem this time, if you keep your lumber pile covered with those covers that come on the lumber to the yard it will keep it much straighter. It doesn't take long for the sun to warp a board when it's just hitting it on one side.
steven083008
Raleigh, NC
Why is lumber so much worse now than in the past? Is it cutting practices, drying, what they start w/, what? Just curious because although I have noticed the quality drop, I have no idea why.:confused:
W
wbrian63
Houston, TX
My typing mistake with the #2. The boards we got were marked STUD. That was the first thing I checked when I noticed how many didn't have square cut ends.
I'd actually just requested #2 or better, but the lumber yard he used says they only stock Stud-grade material as the #2 has gotten really bad.
Makes me wonder what the #2 looks like.
The cause is the way the lumber is grown and harvested. All of the land used to feed the lumber industry in TX have long since been cleared of old-growth pine. Everything here is coming from really small trees that grow really fast.
The demand is such that mills get away with selling this ****. Additionally, the builders are using it - I just can't figure out how you can build a house with lumber of the same quality we received and have the damn thing stand up straight - for long...
Landlord is taking the rejects back for credit and will supervise the pulling of the replacements. I expected the cull to be bad, but I didn't expect over 50%.
W
wbrian63
Houston, TX
Strangely enough, we ordered 5 2x4-8 PT for some work that has to be done in contact with concrete. They're straight as an arrow and flat as a ... - you get the idea.
Now - 4x4 posts - don't get me started. I've had perfectly good, solid fences tear themselves to pieces as a once straight 4x4 starts to twist days after installation like it's a freakin' barber pole...
When we had to replace about 100' of fence after hurricane Ike, I went with 2-3/8" sch 40 galvanized pipe for the poles. The cost of the poles was about 2.5x what I would have paid for 4x4's of the proper length, but 2+ years after installation, that fence is straight and true... Wish I could say the same of the pickets...
Kev442
Wi
I waited 2 years to let the fill settle in my pole building. Glad I did. Several pressure treated 6x6's have twisted 20-30 degrees. Hard to believe that's possible. Would've cracked the concrete all the hell.
nate379
Palmer, AK
That is what is in my house. I had never seen that before. 2x6 and 2x8s.
Try Bison. I am 99% sure they have finger jointed studs. That is what was used in my house and almost all the studs were good.
http://www.bisonbuilding.com/
Steve
When I built my trusses I needed 12ft 2x6s for the top chord. I went through almost 2 pallets at Lowe's to get about 20 of them that were fairly straight. Some in the pile would have been barely ok to use as firewood even.
mmhouse
Desert Southwest
Lumber pressure treaters often (not always) use a higher grade lumber. Since they are basically infusing it with water (containing preservatives) if it is not a higher quality it will go crazy. Also, since it is a value added product (i.e. costs more in the end) it makes sense to spend a little more for the better raw product.
4x4 posts are usually cut from what's left over after all the 'good' wood is cut off the outer edges of the log. Look at the ends of most bundles of 4x4's and every one will contain the 'bullseye' or center of the log.
mmhouse
Desert Southwest
As wbrian63 states, one of the reasons is that we've gone from large log to small log mills in much of the country since the old growth timber is either gone or largely protected.
Another reason is that more mills do more sorts on the lumber than they used to. For instance they will sort out higher grade material for treating plants, decking material, etc. There was a time that they sorted higher quality lumber for Japan, I don't know if they're still doing that. Some mills will also offer 'proprietary' grades to retailers or others which are visual sorts (better looking stuff which is also often higher grade). There was a time that #2&Btr (#2 and better) lumber contained the #2 and most of the 'better' stuff that came from the log. More and more of that 'better' stuff is now going elsewhere.
So between smaller logs with less high quality lumber and more of the high quality material being sorted out you end up with lower quality lumber than you used to even in the same grade.
One more factor is that storing lumber in heated buildings like Lowe's and Home Depot do will cause it to warp and twist more as it dries out in these environments. Keeping it in bundles outside under open sheds is much better for it. Ironically, these are the retailers that get most of the proprietary visual grade material. So they take the better looking stuff and store it in a way that ruins it.
You can find lumberyards that care about the quality of material that they get and have the clout with the mills to get it. I suppose another strategy would be to somehow figure out how to get to the H.D. and Lowe's material as soon as it gets to the store so it hasn't been stored inside for too long.
esmith2039
Kansas City KS
Tell me about it took me ten minutes to pick out 2 treated 2x4's last weekend. Even those weren't straight but somehow manage to get 2 that were slightly bent the same. Worked good enough for the gate. I didn't think to check the treated 4x4's but I know the regular Grade 2 2x4 looked good. Even the 15 fence slates all had mildew on them.
Busted_Knuckles
Northwest Illinois
Great thread, Ive been buying allot of lumber for the last 6 months, first load of dimensional was delivered by a local yard, which caused me to have to get it myself, same thing you guys have found ( I got dumped on!). That yard keeps all their stock outside.
Recently, at my local Menard's (they keep most of the dimensional lumber outside), I have found the lumber to be unbelievably straight, I was buying 50- 10' 2x4s, they where so straight and nice, I went back into the store and doubled my order. Just figured it was a fluke and they wouldn't be that nice next time I went back, I have had trouble just prior to that there as well, digging through Id say 4 boards for every board you would want to take.
redman43
Lake Stevens, WA
Same here. Went to HD last night to pick up 4 2x4x96 for a workbench I'm building. Had to look at nearly 20 just to find those 4. It's horrible.
7echo
coastal Georgia
Yep, lots of construction lumber is lousy. Not just the boards, 'tho. We have had some plywood that would de-laminate after making a few cuts. Imported from China.
I worked on a project this summer that used a lot of steel studs and that stuff was nice. Some walls were 16ga, heavy stuff for steel framing. When I build my new shop I am planning on using steel. Straight, bugs don't eat it, goes together fast.
Busted_Knuckles
Northwest Illinois
I believe, well I heard that Menards has their own mills.
They might, I have noticed the un-opened stock at my store (the packaging) almost every bunk is a different brand, so they are sourcing from all over. Of late, most of sheet goods is LP from a Michigan mill, but I have seen all the big mill names and most of the small ones Ive never heard or seen before.
The other shocking observation, the Menards I go to, is a newer "super" Menards (bigger than HD and Lowes), Im there 3 or 4 times a week. I am either the only one in the back picking up lumber, or there might be one other customer. Scary empty.
I can remember a couple years back, loathing going there because the parking lot was full, I didnt even want to stop, Id wait till 8pm to get lumber, just to avoid the crowd. Im even there on the weekends and the place is empty... just scary
W
wbrian63
Houston, TX
I was working at the shop this afternoon (not this job site, our actual shop), building the rack to hold sheet goods.
I needed a 2x4 about 60" long to create the "curb" to keep the bottom of the sheets from slipping off the rack. Dug through some of the offcuts that are in the lumber rack and came across a couple of 2x4's that we pulled out of the storage building where the equipment was stashed while the shop was being built-out.
That storage shed was used to store an old Cadillac that I finally got smart and gave away to someone that would appreciate it more than me. The car had been in there a long time - probably 5 or 6 years, and I built the shelf that this lumber came from when we put the car in the shed.
So - that 2x4 is probably 6 or 7 years old. It was just standard stock - I'm sure I bought the cheapest stick I could find, as every piece had to be cut to custom fit into the confines of the storage building.
Relatively knot free, and nice and straight. Edges were rounded from the mill. I ran it thru the jointer to true and square one edge and it came out arrow-straight. Compare that lumber with the **** that came in the other day is like comparing caviar to stale toast. And that's just in the last 6 or so years...
I think we did pretty well with the lumber we purchased for the build-out of the shop. Bought it all from a local family-owned lumber yard. My dad bought lumber from this same company (same location) when he was in his teens racing homing pigeons. He just turned 72 on Sept 30. We had a few banana-boards, but nothing that couldn't be cut into shorter sections for blocking, etc. But as noted by MMHouse, this is a "real" lumber yard. Materials are stored outside under cover.
That being said, we did restack and band-clamp the dimensional lumber at the end of each weekend - just in case...
One thing I noticed tho - that's was very surprising. We paid premium $ to get 3/4 T&G YP plywood for the floors. $18.40/sheet vs 15.35/sheet for OSB T&G. The top layer of this stuff is SOFT. We have decent sized casters on the scaffold, which weighs about 250# empty, probably 500# with me on it, and I can still see the "ruts" that it left in the surface of the wood. That same scaffold is now at the job site - our old shop - that was built about 7 or 8 years ago, also with 3/4" T&G YP flooring, and it leaves no grooves. The old stuff held the floor paint like iron. Behr premium floor paint, 2 coats over a single Behr recommended latex primer. 250# cabinet saw sat on painted floor for 8 years, and didn't lift the paint when we moved it out. New space, same primer, same paint, same application method. Moved our portable chopsaw stand the other day. It has 2 legs and 2 wheels. The legs come to a rounded point probably the same diameter as a golf-ball. Pulled up two patches of paint right down to the wood about a nickle in diameter... I thought it was the paint - now I'm thinking it's the wood....
My dad lives part time in San Miguel de Allende, Mexico. It's high desert there, so not much wood is to be had. Most everything is masonry or metal. Far better deal...
srmofo
SW ohio
I am just finishing a fence and I easily returned over 50% of the treated lumber they delivered. I only have about 1/3 pickets hung and returned 36 out of the 150 or so Ive hung. Got my delivery fee back (45 80#concrete bags wasnt happening in my truck) and it cost me 2 hours. Not a bad trade I guess. HD hasnt hassled me too much about the returns ...yet. probably one more trip to return some pickets.
you should see this 4x4 I stuck in the ground true. Left on vacation and when I got back, that SOB warped on one side and pulled it 3" from my line.
nate379
Palmer, AK
I bought a bunch of PT at Lowe's this summer and for some reason some of the board (2x8s mainly) were super heavy and others light at as a twig.
mmhouse
Desert Southwest
Treated lumber is typically not dried after being treated (some is if used for decking or other specialty uses). It will lose moisture and weight with time and as it is exposed to the air. The longer it's been since it was treated the less it will weigh.
Now if some of it had been kiln dried after treatment and some not that would make a HUGE difference, but that's probably not the case.
7echo
coastal Georgia
Whenever possible I like to use kiln dried PT lumber, the stuff mmhouse mentioned. It is almost always more straight. But, it is more expensive so not a good choice for a big project.
viper86
Lincoln, NE
My understanding is that almost all PT lumber is southern pine because it can be treated more easily and uniformly. Other species must be incised or perforated in some fashion to aid in the penetration of the treatment.
As far as lumber quality goes, I have no issues with Home Depot's quality here. At least at 8' lengths. It takes a bit more time to find a good 10' or 12' length, but it's much better than what I've seen at the Menards here. Never looked at Lowes here though.
hilld
Vancouver, WA & San Juan Island, WA
It is definitely a regional thing. Here in the Northwest, you can't find any southern pine, all of our stuff is Douglas Fir. When I wanted some southern pine, I had to special order it.
