Thanks. For some reason have a lot of the right size bolts for the 123 block. Machined one pin to fit in the non threaded holes.That's a nifty bending set up. What have you got going on with the hinge at the back of your vise?
Thank you. I hadn't recognized the 123 block. Very clever! Love the vise.Thanks. For some reason have a lot of the right size bolts for the 123 block. Machined one pin to fit in the non threaded holes.
The vise is a patterns maker vise. It's adjustable to all sorts of positions.
My 308 at 47 years old still smells amazing every time that I open the door, definitely the real deal leather.The switches & vents are plastic, everything else is wrapped in leather, or aluminum.
They also put a "soft touch coating" on those plastic surfaces which turns to goo. That's frustrating.
It is actual leather, not the synthetic leather other car manufactures use. It smells amazing...and its 20 years old.
Nope. Cracked (both before and during removal). Same with front panel, front storage box, spare tire cover, propane tank cover. Remarkably brittle.The rear panel looks good. Does it have a similar front panel in good condition? I've seen those have value because they are so easily ruined and near unobtainium.
Yours / friends' equipment, or a side hustle?Opened a Jeff's Happy Jungle Box. Replaced the carburetor on a Stihl weedblower. Cleaned the sparkplug and air filter on a Husky weedblower. Both patients survived.
Thank you. I love being out there and enjoy puttering, organizing and cleaning almost as much as working on projects...your shop looks like what I think a shop should look like, it's like a cool movie set shop, I love it.
Trade of labor. I need to rent his cubiche. This gets me the help I want without the agent fee.Yours / friends' equipment, or a side hustle?
Renting a Cuban person can be problematic, especially if you cross state lines.Trade of labor. I need to rent his cubiche. This gets me the help I want without the agent fee.
I would suggest joining FerrariChat, the best forum for information about buying and maintaining these cars. FC has subforums for each model as well as classified ads. I have been a member since it's beginning (member #13 or so). Excellent source for DIY work although if you can afford to attend Cavallino these days you probably have others do all the work for you. I quit going there when the event was sold to another promoter and the ticket prices quadrupled. They also used to have vintage Ferrari track days and races at the nearby Moroso track for a mere $30, it was the best value in the Ferrari world. Some photos from Moroso back in the 2000's, the sound was worth the price of admission alone.I was looking at the 308's at the Cavallino. They look like a fun, achievable way to enter the classic world. We are considering one for the next toy! Maybe an early carb'd euro model.
Yeah, me too.Oh I'm knocking them off first day.lol
Renting a Cuban person can be problematic, especially if you cross state lines.![]()
Some days are like that.Got out the tile saw to cut a tile to a complex shape that fits around a countertop. Only took all afternoon and broke three tiles until I got it to fit.
take stain like the rest. Oh, & I cancelled the trash pick up which worked out to $15.00 for every kitchen trash bag30 years ago trash compactors were the rage.Wrapped up the integration of a $50.00 GE trash compactor into existing oak cabinetry.
Required GFCI outlet, bust through the wall behind it as it was deeper than the cabinets.
Work up replacement trim and a false door to cover the stainless. Just noticed one piece of oak didn'ttake stain like the rest. Oh, & I cancelled the trash pick up which worked out to $15.00 for every kitchen trash bag
Gravity *****30 years ago trash compactors were the rage.
My brother's had a "vent" hole in the plate at the bottom that the ram pressed the trash into. Guess where all the smegma went when the bag is torn (which seemed to always occur) went?
I put my chargers on a pushbutton timer. The max is 4 hours, and then they're off. The only ones that charge that long are my big Stihl batteries.Thanks to a friends help with the wiring and plumbing the Transair lines, I finally have compressed air.
The compressor was delivered about two months ago, but due to a multitude of reason, we just got it wired and hooked up this evening.
Makes 24cfm @ 175psi. Fills the 80 gallon tank from empty to 170psi in about 4 minutes.
No leaks in my redneck cooler/water separator, the Transair plumbing or the three regulator/filters at each drop.
The green light on the exterior of the tool room tells you the compressor is energized, the red one tells you the Milwaukee and Dewalt chargers are energized so I don’t forget to turn them off at the end of the night.
