I've got a few of my own already. The "little" ones are nice for campfires and turkey fryer stands.These would be little guys. The blades range from 16-20”.
Ya want one ? I can take orders and make a bunch.
The Wishek ones are 25ish diameter and weigh around 60lbs![]()
Thought I recognized that sidebox.Thanks to a friends help with the wiring and plumbing the Transair lines, I finally have compressed air.
The compressor was delivered about two months ago, but due to a multitude of reason, we just got it wired and hooked up this evening.
Makes 24cfm @ 175psi. Fills the 80 gallon tank from empty to 170psi in about 4 minutes.
No leaks in my redneck cooler/water separator, the Transair plumbing or the three regulator/filters at each drop.
The green light on the exterior of the tool room tells you the compressor is energized, the red one tells you the Milwaukee and Dewalt chargers are energized so I don’t forget to turn them off at the end of the night.
Yes, it takes a systemized approach to avoid “Garbage”.Gravity *****
Looks great! I insulated my garage and installed the mini-split here in Phoenix a few years back and it was a game changer. Only issue I've had is the plastic line cover on the outside of the garage melted in the extreme heat and doesn't look so great now. Still haven't decided what to do about that.
Thanks. Time will tell on the line cover. It’s sure going to get a test as it gets the full blast, west, summer sun. I don’t know what kind of plastic it is but I always paint any plastic out here and it seems to help especially when the material is PVCLooks great! I insulated my garage and installed the mini-split here in Phoenix a few years back and it was a game changer. Only issue I've had is the plastic line cover on the outside of the garage melted in the extreme heat and doesn't look so great now. Still haven't decided what to do about that.
The magnets are strong enough that they slide instead of releasing when bumped. However I also did not straighten out the hooks just in case i did bump into them I didnt' want to be skewered. I definetly wish my roll away had more shallow drawers for stuff like these.Yeah, me too.
what kind did you get?Worked in Lightburn. Adjusted the new chainsaw.
Like most of my small yardwork machines, Stihl. I chose the MSA-70, as it uses the same battery lineup as the Kombi unit I purchased a couple years ago. It's about as quick as my MS-170, with none of the noise, vibration, or stink. We'll see how it does over the long term.what kind did you get?
You're a good Dad.My daughter brought her 2017 VW Jetta over last night, her brake light was on. 61K on the car. I told her to pick up some front pads and brake fluid. Pulled the front wheel, those brakes were fine. Pulled the rear wheels, yep, those pads very thin. I hadn't worked on a VW since 1984 (Golf Diesel). I sent her for those pads, while I pulled the caliper. As soon as I had the caliper off, I knew a tool was needed. I called her to grab a brake caliper repair set loaner, but she'd already left the store. I put the wheels back on to finish the job today while she was working.
Today I used the tool to wind in the piston, but it was difficult to get it turning. I hit it with more brake cleaner, came back and it screwed in easily, installed new pads and put the wheel back on. On the drivers side, not so lucky. The piston wouldn't budge, even after cleaning. I kept trying to screw it in, but only managed to slightly bend the support plate on the tool. Now, the tool was wedged in place. I opened the bleeder valve, but that didn't help. The reverse position from the other side made it impossible to get leverage with a wrench to unscrew it. I considered cutting the tool,but she would have lost $70 on the loaner set. I googled the problem and the VX Vortex showed a lot of similar issues. One guy pulled the caliper, so I did the same, mounted it in my vise and then removed the tool. The piston then easily screwed in by hand. Put it all back together and drove it back to her house. Yikes, wasn't expecting to spend three hours on rear brakes!
I had one as my desk once upon a time. I really liked it. Definitely lives up to the "tank" name.Welp...Today I wrestled the Tanker desktop from the garage (where I disassembled the desk) up the narrow stairwell to my "new to me" office... I got two of these Tanker desks from a business that was closing and if I could get them gone they were mine... even got the keys...
Spent the better part of the day bolting the top down, deep cleaned the desk with Pine Sol and lubed all the drawer rollers...
Found my old fluorescent desk lamp that fortunately still works...
The desk top is some kind of rubber, kind of mildly soft, maybe a early vinyl (not linoleum)...
Love the SS corner protection detail...
Finished... For now... Next week I'll start on the second Tanker Desk... Rinse and repeat...
These things are really built well... If you ever get the opportunity of snagging one, grab it...
I can't find any date of manufacture, but I'm guessing mid century modern 50's-60's maybe...
I think they were the de rigueur secretary desk for the office work force... I think the military used a bunch of these...
Sat behind one of those at more than one job as electrical engineer.Welp...Today I wrestled the Tanker desktop from the garage (where I disassembled the desk) up the narrow stairwell to my "new to me" office... I got two of these Tanker desks from a business that was closing and if I could get them gone they were mine... even got the keys...
Including taking it upstairs?Next week I'll start on the second Tanker Desk... Rinse and repeat...
Yeah...Including taking it upstairs?![]()
