These are bull nose clamps. https://www.google.com/search?q=bul...JEAAYgAQYogSoAgiwAgE&sourceid=chrome&ie=UTF-8
lg
no neat sig line
The bull nose clamps I've seen have a ball at the tip or rounded tips. These have tapered tips that overlap.These are bull nose clamps. https://www.google.com/search?q=bul...JEAAYgAQYogSoAgiwAgE&sourceid=chrome&ie=UTF-8
lg
no neat sig line
Yup. Nose clamps for a bull have rounded ends.These are bull nose clamps. https://www.google.com/search?q=bul...JEAAYgAQYogSoAgiwAgE&sourceid=chrome&ie=UTF-8
lg
no neat sig line
You have to get it to put it's head through a fence first by giving it some tasty feed, then grab it's nose and fix the clamp. Easiest if the fence has a yoke built in, to close up and hold it's head.I can't imagine walking up to a bull and putting something in it's nose.
They're stuck into the nostrils of the critter to lead it around--also known as a "persuader". Farm animals have it rough....I saw them listed for leading bulls somewhere, again thru a nose ring, to keep your distance. I’m no rural expert, so take that into consideration when trusting my reply.
Ever use the bucket trick? Drive a hog in reverse?I can see the hog catcher. Many times, we lassoed one back leg and pull. He goes nowhere.
Thats why we pulled and kept pulling. But that's the bad part about pigs. They learn fast.Ever use the bucket trick? Drive a hog in reverse?
PS: A hog can go VERY fast in reverse.
I will stand corrected...........Yup. Nose clamps for a bull have rounded ends.
The blacksmith made whatsit clamps could be used on the end of a bull pole, but those usually have a spring clip. A pole is used when the bull already has a permanent ring in it's nose. Leading it with a pole is safer than using a lead rope on it's ring as it enables one to keep the bull at a distance, also to keep it's head up which prevents it charging at you.
As my teenage daughter once replied to somebody who questioned how she could control a huge animal, she said: "I'm not controlling the whole animal, just it's nose, I can take the end of it's nose wherever I want and the rest of it won't be far away".
Could this be wire for electric motors? Like a spool for some kind of winding machine. Just what comes to mind.Well, I looked at a lot of sites for a tie wire dispenser like this but haven't yet found a match. Also considered wire stitching machine dispensers or bobbins but none like this. I'm just guessing at the name Geronimo. German seems to short for the space but I'm sure there are other companies starting with Ger. A couple more pics of the wire dispenser open. The cases fit together very tight but the pin spanner got a good enough grip to open it.
From the amount of whaling upon it's suffered, we had some tough horses and mules back then!Heller Bros. "Buffer" or "Clinch Cutter" for trimming hooves and cleaning nail holes.
Misused.From the amount of whaling upon it's suffered, we had some tough horses and mules back then!
Reckon?Misused.
