JEFFREYWisconsin
- Joined
- Oct 9, 2021
- Messages
- 380
I was thinking the same.That’s pretty clean, your hired!
Do you think not having it vented to atmosphere will impede the flow of brake fluid from the caliper?
I dont think that motorcycle master cyl can pump that much air inside the bottle to stop the flow... but i might be wrong. In can i need a vent its easy to grill a hole and install a tire valve with removed core or something like that.
I use a 60ml syringe w/an adapter I made from a screw type wheel schrader valve w/o its valve core, and a short length of 1/4" plastic tubing to do a reverse-bleed of my non-ABS motorcycle brakes, and hydraulic clutches.For motorcycle applications you may be okay due to the low volume of fluid, or ratio of fluid to air. It may still try to compress the volume of air a bit and create some unwanted backpressure when bleeding however.
I have a hook in the shed for each chain size, right under the saw that uses it.Spent afternoon trying to get the chainsaw situation organized. Saws in three locations (shed, shop and lakehouse).
Husqvarna 455 rancher (20”) and a 235e (16”)
Echo 58v they discontinued it. Charger went bad so at time cheaper to order new 56v saw. Later found a used charger. 16” bar
Two Echo 56 volt. 18” bar.
Echo pole saw power pruner. 10”
Dewalt 12” 20v. Have two I bought on clearance. Keep one at the lakehouse.
Keeping bars and chains sorted is confusing. Grab a saw along with spare chain and go. Usually end up with wrong chain. In woods I’m not going to sit and file chains. That’s a skill I **** at and have no desire to improve. Save them for the saw shop sharpener.
Just eBay ordered some colored plastic boxes. Going to organize colors by bar and chain sizes for each of the saws.
Does the underwear have to be old? If so, is there a preferred/recommended age/vintage?You don’t need to press for grease boots if you have a really big socket and a pink persuader
Proven - There’s not much you can’t fix with tools from USA, beer from Mexico and an old pair of Duluth underwear
Where'd you get your flake?No garage just a shed. Threw some flake down on a tool box for work. First time doing it. Threw what was left over on a stack on box and old welding hood
It'd be funny if it wasn't that the world is so tragically effed up, and this is just the tip of the iceberg.Just another day in paradise.
USPS lost a second package of mine this month, and the customer wrote to me all upset about it. It's insured, but it's still a pain in the ***. I have to grovel to my customer as if it was me who screwed up, then I have to fill out forms, refund the customer, and then wait weeks to be reimbursed by USPS, just to end up with some of my money back and still have a dissatisfied customer.
Sometimes I think I should just sell local only. Then I get messages like this (actual message just minutes ago):
Why... Just why? MF is 200 miles away. Read the &^*&^ AD!!
Sorry, just wanted to *****, lol.
AmazonWhere'd you get your flake?
Is HoK selling online finally? Premixed or dry? Linky?Amazon
In the day, when adding AC, we never tried to preserve the glove box. Instead, made an easily removable flat metal box, with a pocket to hold the papers upright. Sometimes just added the pocket to the door, and dumped any pretense of a glove box. The more room you can make yourself under there, the better.Removed the current head unit, as well as the hacked up glove box door it was installed in to. Measured and pondered how to fit the new glove box in over the A/C condenser box. Measured and pondered how to fit the new hidden head unit.
Ive had seats in cars, and seen a few bass boats with those colors.lolNo garage just a shed. Threw some flake down on a tool box for work. First time doing it. Threw what was left over on a stack on box and old welding hood
I know... People are just so. damn. dumb! I just can't stand it anymore. People think they need to let every little thought in their empty-*** heads be projectile-vomited out of their mouth (or their keyboard) for all to hear.It'd be funny if it wasn't that the world is so tragically effed up, and this is just the tip of the iceberg.
One time I bought something in ebay, for a mustang.I know... People are just so. damn. dumb! I just can't stand it anymore. People think they need to let every little thought in their empty-*** heads be projectile-vomited out of their mouth (or their keyboard) for all to hear.
Just today I had some other ****** write to me about one of my ebay auctions, telling me how wrong I am about specifications. I replied with a screenshot of the manufacturers manual, confirming my listing. I mean, if you're gonna "correct" me, at least be correct, lol. And better yet, if you're not gonna buy my items, how about just shutting the F up? Eh?
Sorry. I'm in a bad mood again, lol.
Thanks you, sir.The dog is awesome.
I hang my saws on the wall and have a nail next to each one for their specific chains with one of the original boxes.Spent afternoon trying to get the chainsaw situation organized. Saws in three locations (shed, shop and lakehouse).
I have a plastic box labeled "dull" that i put them in when its time. Like you, I'm not good at sharpening them. I've done it, but they don't seem to stay sharp so I take them to the chainsaw place to be done correctly. (bonus, my favorite bakery is next door).I use a 60ml syringe w/an adapter I made from a screw type wheel schrader valve w/o its valve core, and a short length of 1/4" plastic tubing to do a reverse-bleed of my non-ABS motorcycle brakes, and hydraulic clutches.
It's the quick way to bleed them if you don't have one of those pneumatic systems. Yes, I have a Mity-Vac, probably 40+ years old, the reverse-bleed syringe is faster. Bubbles rise, so the air in the system is pushed-out by a stream of brake fluid from the syringe. Some like to tie-back the master cyl handle overnight. I find that unnecessary doing a reverse-bleed. Just beware over-filling the master cyl chamber and spilling corrosive brake fluid onto your paint.
Note the crystallized brake fluid in this motorcycle clutch slave cyl. The bike only had 10K mi on it and looked great otherwise. Fresh F & R brakes' fluid, and the hydraulic clutch too.
Replaced a 50 ft air hose on an overhead shop retractable reel, after the hose got several small splits. Works great again.
Out w/the old, in w/the new left, below. Returned to service, right, below.
My li-ion battery charger for my Craftsman 19.2V tools took a dump. I replaced it w/a compatible one off Amazon prime. It got hung on the wall above the workbench w/a fancy french cleat bracket.
I had to use a T10 Torx screwdriver. My HFT Pittsburgh screwdriver set had just the one to disassemble the charger case so I could attach the new charger to the old french cleat base. Couldn't have done it w/o the screwdriver set from HFT on-hand. I could have caught the tool truck and bought a T10 Torx from Snap-On for $23.
Yeah, this was a non-running first generation VMax, and both of those happen to be 'my weakness.'Mixing certain brake fluids can cause that crystal ****.
I had one of those a 2+2, '86, w/the voice 'door is ajar' ("when is a door not a door?"). It was the most highly-optioned one not a turbo. It had 70K mi on it when I sold it. 3rd owner, I was. It was a gorgeous car, metallic grey.Looks like someone has an 86 300ZX NA
When I have the lower end buttoned up on the build stand. Will flip it over and put it on the run stand to be finished up. Radiator and electrical comes off.Wow, what a nice run stand. Maybe I need to build a stand for my engine while I've got it torn down and can measure stuff easily.
Humble brag? Ok whos the kid so we can cheer him on as a GJ kid.lolSon went off to NHL team
HF sells a decent chain sharpener. I've got one, and it paid for itself in a few sharpenings.I hang my saws on the wall and have a nail next to each one for their specific chains with one of the original boxes.
I'll have to check it out. Of course then I'll need to find a new excuse to run by the bakery for a bear clawHF sells a decent chain sharpener. I've got one, and it paid for itself in a few sharpenings.
