Thanks!I used to know thread allowances from Plumbing shop in high school, but I forget that .
try searching IPS thread allowance , you should be able to find a chart
I agree that this is the best plan.On second thought, I believe I'll wait 'til the new boiler arrives so I can fit it in place.
Looking back on that cut, it's amazingly straight for a Bosch recip and a 65-year-old dude.
This is the best I've found:
https://www.hosemaster.com/resources/technical-information/thread-allowance
I seem to recall it being more like 1/2 the OD of the pipe... but I'll trust the chart.
I figure if I round that 15/16" up to one inch, X 2, I'll make up for the 1/8" kerf of the recip saw. Unless I have that backwards... draw a picture first....That chart looks accurate. I don't think I've ever put threads on 2 1/2", but the other sizes sound about right.
Wow, that's a blast from the past. Back when high school still taught tangible skills that could be used to earn a living.I used to know thread allowances from Plumbing shop in high school,
You mean like reading, writing and 'rithmatic?Wow, that's a blast from the past. Back when high school still taught tangible skills that could be used to earn a living.
I took woodshop when I was in the 7th grade back in the early 60’sBut, yeah, shop classes should still be on the curriculum. Wood, Metal, Automotive, HVAC, Electrical, etc.
I'm doing some stuff with 3/4" black pipe and needed to know how far a cap would screw on. I screwed the cap on, marked the pipe, took off the cap, and measured. I came up with .5485 on my caliper. I should have realized there was a chart for this. The above link shows .55 for 3/4". Not bad for these old eyes! Thanks for the link. It will be useful for other sizes.This is the best I've found:
Seeing how the NPT seal is designed around a specific number of turns, and the NPT thread pitches repeat a lot, it makes more sense to me that the allowance would be mostly based on the thread pitch, and not so much the OD. Seeing the way 1/4" & 3/8" are almost the same, as are 1/2" & 3/4" and 1" all the way through 2" clump up when dies are shared makes sense to me. Though I'll admit I've never done any NPT work that required this level of precision....I seem to recall it being more like 1/2 the OD of the pipe... but I'll trust the chart.
No. Oriented fiberglass.Is that asbestos?
Which is why I've decided to do the fitting with the boiler and pipes in place. The best way I've found to eliminate math errors is to eliminate math.Seeing how the NPT seal is designed around a specific number of turns, and the NPT thread pitches repeat a lot, it makes more sense to me that the allowance would be mostly based on the thread pitch, and not so much the OD. Seeing the way 1/4" & 3/8" are almost the same, as are 1/2" & 3/4" and 1" all the way through 2" clump up when dies are shared makes sense to me. Though I'll admit I've never done any NPT work that required this level of precision.
