Expired - CRAFTSMAN Ratcheting Screwdriver, SpeedDrive $10
webscrounger
Midwest
CRAFTSMAN Ratcheting Screwdriver, SpeedDrive, 2” Double Ended Bits Included, Handle Holds Up To 6 Bits (CMHT68129)
On Amazon, $10.49 at the moment, don't know for how long.
Etchase
Hawaii
Includes 6 double ended bits and speed drive means it’s ratcheting, and turns in the direction you select whether you are cranking the handle clockwise or counter clockwise. SBD has rotator ratchets with the same mechanism. I like mine at the regular price.
Ohio Andy
Columbus, Ohio
Maybe they're dumping them all (before tariffs?🤯). Whatever the reason I have two, like them and think they work just fine. Certainly good for the buck at ~$10.
Honestly, I actually really like that screwdriver quite a bit. Has a decent set of bits. It works well. The back drag is really low.
There is no knurling on the shaft, but the ********* piece at the end of the shaft is knurled quite nicely and you can spin that rather than the shaft. It works really well
My only complaint is that it doesn't have a locked position, so you can just use it as a regular screwdriver
Some time back I did a full review on a bunch of ratcheting screwdrivers including that one. It's somewhere in the forum.
